[Cdma Razr][Ics] Rom | Axi0M Cmplx | Ics Leak | Modifier | By Droidth3Ory
140 replies to this topic
#101 STiK
STiK
    STiK in the Mud
  • 304 posts
  • LocationEverett, WA
Posted 16 April 2012 - 04:53 PM
I haven't had any apps crash when I installed Complx. Both of my phones now are running great. I had issues with root when I put ICS leak on my wife's phone yesterday because something happened to my root, but once I finally got flashed back and redid the process I was GTG. Are you sure it is due to complx and not your root itself?
Yeah I've done fresh fastboot/updates a couple of times. The only apps that seem to have issue that I use are Root Explorer and Sqlite Editor. They both work fine until I flash this then they both start crashing. Root Explorer is usable as it randomly crashes and sqlite editor won't finish loading the databases so it is unusable. Both work fine without these mods installed. If I have time I will poke through this thing and see what he has going on and try to find a fix.
#102 icemans2k02
icemans2k02
  • 9 posts
Posted 16 April 2012 - 06:07 PM
I have used this on three phones and mine twice. I just made sure when installing the leak. I would flash back to stock, root, backup root, then update, restore root, then flash this. I never went threw and installed any apps or debloat anything. Made sure I kept it simple and did what I needed to do. So far so good with no force closes or battery life issues whatsoever. Good luck!
Sent from my DROID RAZR using Tapatalk 2 Beta-5
#103 looneytuned29
looneytuned29
  • 90 posts
Posted 21 April 2012 - 02:00 PM
Just out of curiosity how do i uninstall thisif i choose
#104 trekie4ever
trekie4ever
  • 285 posts
Posted 21 April 2012 - 02:29 PM
Reflash the leak.....
Sent from my DROID RAZR using Tapatalk 2 Beta-6
  • nobe1976 likes this
#105 trekie4ever
trekie4ever
  • 285 posts
#106 STiK
STiK
    STiK in the Mud
  • 304 posts
Posted 21 April 2012 - 02:54 PM
Haven't seen any posts from DT anywhere since his tragic family loss. Hope he is doing well.
#107 claps1775
claps1775
  • 596 posts
Posted 21 April 2012 - 05:39 PM
I just flash the file as the droidhive.com stated. It went through the install fine. Then the reboot was good and the 91 app upgrade as well. I do not see anything different. For example, I still have amazon kindle. What is the bloat ware was talked about that the file was getting rid of? I am lost. It seems the same before I flashed the file. Did I miss something?
#108 theonlycosmic
theonlycosmic
  • 470 posts
  • LocationCalifornia
Posted 21 April 2012 - 05:47 PM
Okay so many people have reported errors and such. I have done all instructions and even removed bloat/.odex files. I have also put in my own build.prop lines and am running smoothly. Sq lite editor is fine for me even after installing this.
#109 claps1775
claps1775
  • 596 posts
Posted 21 April 2012 - 05:51 PM
Now my Titanium Backup patch4x will not work. Says there is no root. I unstalled it and installed it. Still no dice. I have root protected too.
#110 s.cooper
s.cooper
  • 36 posts
  • Google+:unionshane@gmail.com
  • Locationsioux city ia
Posted 21 April 2012 - 05:52 PM
I need info!!!!! Ive read around and trying to determine if my. 173 will work for a ics rom on my new maxx....keep reading need. 6.12.17x and cant find the right info.....HELP-ROOKIE CRACK FLASHER DOWN!!!!!!!!!!!
#111 claps1775
claps1775
  • 596 posts
I am going to flash my backup and try later once this is fixed.
#112 superrelaxx
superrelaxx
  • 921 posts
  • Twitter:jasNwa
  • LocationSeattle, Washington
Posted 21 April 2012 - 05:55 PM
if it's stock, hell to the yea
#113 claps1775
claps1775
  • 596 posts
Yes 173. Will work and has to be unmodified too. Fallow the instructions and you will be fine. I did a rsd back to stock stock and updated to 173. Then did the flash. Hope that helps you.
#114 s.cooper
s.cooper
  • 36 posts
Posted 21 April 2012 - 05:57 PM
So im golden and flash away im stock brand new outta the box?
#115 theonlycosmic
theonlycosmic
  • 470 posts
Posted 21 April 2012 - 06:17 PM
I have removed almost all blur and stock apps/.odex files and have added in bulid.prop tweaks yet I am perfectly fine and get no FC.
#116 sd_N
sd_N
Posted 21 April 2012 - 06:59 PM
One of the reasons to use IC bootstrap is so you can make/restore nandroid backups. Regular one causes issues when doing those.
Yes.. regular Bootstrap is a no no...took me 3 tries at restoring to figure it out.... :blink:
All good with ics bootstrap
#117 Guest_BDH_*
Guest_BDH_*
Posted 21 April 2012 - 08:49 PM
The version of bootstrap wasn't the issue. It was the "su-backup" file that needed to be deleted to restore a nand. Pretty sure the other bootstrap would work as well, I'm not going to test it though.
#118 theonlycosmic
theonlycosmic
  • 470 posts
Posted 21 April 2012 - 10:17 PM
If that's the case then why not just use the new ics bootstrap for .173 base if the problem was the su-backup
#119 Guest_BDH_*
Guest_BDH_*
Posted 21 April 2012 - 10:23 PM
I'm not saying the ICS bootstrap can work on .173.
I'm saying the older bootstrap "might" have worked with ICS.
#120 leviwg
leviwg
    News Writer
  • 563 posts
Posted 22 April 2012 - 05:36 PM
will this be a step stool to a 1 percent battery mod? has anyone come across one for the leak? ive tried to look but all i got is the circle battery that shows percentage.
a what? an android? whats that?
