[Cdma Razr][Ics] Rom | Axi0M Cmplx | Ics Leak | Modifier | By Droidth3Ory
140 replies to this topic
#81 Guest_BDH_*
Guest_BDH_*
Posted 12 April 2012 - 10:32 AM
A lot of you guys need to figure out the difference between complaining and posting issues. I'll admit, I haven't had one single issue with this script, but that doesn't mean nobody will have issues. Some of you need to understand that just because we have the same phone, doesn't mean they will react the same when we flash the same thing to it. Every device reacts differently when you flash something to it. Sit back, relax and if you can't help fix the issue or contribute to the conversation then move along and post somewhere else.
#82 trikotret
trikotret
    Droid Elite
  • 1,461 posts
Posted 12 April 2012 - 10:58 AM
What I did is posted my issues and moved along. Restored backup :D
#83 MOlaxer1126
MOlaxer1126
  • 35 posts
  • LocationNew Jersey
Posted 12 April 2012 - 05:39 PM
does nyone have some screenshots of this leak? just wondering cuz i have Axi0m [R] B20 AoSp and i want to try it but dont know if ill like the different look. like ik it doesnt have battery mod and stuff, i just wanna see what it looks like.
#84 kaplac
kaplac
  • 102 posts
Posted 12 April 2012 - 05:41 PM
it looks exactly the same as the stock leak. all the mods are behind the scenes
#85 Platinumwolf
Platinumwolf
  • Google+:Joel Wheeler
Posted 13 April 2012 - 06:52 AM
Flashed this yesterday, and been running it ever since. I'm quite pleased with it, and everything appears to be working.
#86 JungleKing76
JungleKing76
  • 446 posts
Posted 13 April 2012 - 07:09 AM
Agreed.. but I am confused on your take off the post in question. Lol. Not that it really matters as we all have differing opinions and definitions.
Posts like the one by Trik are straight and to the point and are valid constructive input to help point out issues.
However, the original "complaint" in question by tucs provided no help in exactly what issues he/she had. Saying things like "more bugs than my back yard" helps no-one. Also, he claims the entire thread is all about problems with this script but that is not accurate and its the reason his post was labeled as a flame post. Prior to his post there were more than 50 posts and only about 5 were reporting problems. So, yeah, claiming the entire thread is all about bugs was a flame attempt.
#87 fastfoodfred
fastfoodfred
  • 172 posts
Posted 13 April 2012 - 12:55 PM
Does it still limit the camera to 5 mp?
#88 flashman2002
flashman2002
  • 104 posts
Posted 13 April 2012 - 02:19 PM
When I go to the stock camera settings it says 8mp or limit to 6mp for widescreen.
#89 fastfoodfred
fastfoodfred
  • 172 posts
Posted 13 April 2012 - 05:27 PM
Cool. I liked it better than the ics leak.
What about the camcorder and hdmi mirror?
#90 zero
zero
  • 86 posts
Posted 13 April 2012 - 07:52 PM
Can anyone post a mirror link for the zip file? Link hasnt worked in 2 days.
  • hgildar likes this
#91 Guest_BDH_*
Guest_BDH_*
Posted 14 April 2012 - 12:53 AM
It's not an actual ROM, it's just a script.
#92 flashman2002
flashman2002
  • 104 posts
Posted 14 April 2012 - 05:15 AM
Go to his website. It will be easier for you to do so.
#93 squeezy
squeezy
  • 16 posts
  • LocationSouth East Ga
Posted 14 April 2012 - 08:29 AM
Link seems broke there also.. anyone got it?
#94 mugsy77
mugsy77
  • 235 posts
  • Current Device(s):RAZR MAXX
Posted 14 April 2012 - 12:43 PM
A member on droidhive, evan30, posted a mirror. I have not tried it.
#95 Justibasa
Justibasa
  • 37 posts
  • Twitter:@justibasa
Posted 15 April 2012 - 05:48 AM
Just wanted top say thanks for this DT. Enjoying an awesome phone thanks to you and this script. Looking forward to everything coming out in the future.
#96 nexus351
nexus351
Posted 15 April 2012 - 06:26 AM
Just saw that droidth3ory posted a new ROM (script) over at droidhive for leaked RAZR ICS and thought I would share... kudos to dt!
Here are features for first release/version:
FEATURES:
ICS Roboto Clean Font
FULL INIT.D Support
CMPLX Script Set (Speed, Fluidity, Battery Life, RAM Management)
Max FPS (240)
Cron
Force Home Launcher in GPU (Software)
Disable Kernel logging (Speed)
Max JPEG resolution to 100%
SD Read Speed
Zipalign At Boot
Kernel Tweaks
Shorter Ring Delay (Connect Call Faster)
Proximity Sensor Hack (Light Up Faster)
You have to be on leaked RAZR ICS. Viscous's instructions can be found here:
Once you are on leaked, then follow ROM instructions.
droidhive link:
short url:
cdma or gsm ?
#97 flashman2002
flashman2002
  • 104 posts
Posted 15 April 2012 - 07:16 AM
This mirror does work.
cdma or gsm ?
I would say just CDMA, but if he has created anything for GSM it is possible it may work. I would not take the chance though.
#98 STiK
STiK
    STiK in the Mud
  • 304 posts
  • LocationEverett, WA
Posted 15 April 2012 - 09:49 AM
Has anyone figured out yet what is causing some of the root apps to crash when using this?
#99 SoLongSidekick
SoLongSidekick
    YOU WILL HAIL!
  • 687 posts
Posted 15 April 2012 - 09:57 AM
cdma or gsm ?
Almost guarantee it's only CDMA.
Shameless promotion for Tapatalk v2 on some mobile device
:-D :-D
#100 flashman2002
flashman2002
  • 104 posts
Posted 15 April 2012 - 11:18 AM
I haven't had any apps crash when I installed Complx. Both of my phones now are running great. I had issues with root when I put ICS leak on my wife's phone yesterday because something happened to my root, but once I finally got flashed back and redid the process I was GTG. Are you sure it is due to complx and not your root itself?
8 user(s) are reading this topic
0 members, 8 guests, 0 anonymous users
