All of you are having problems most likely because you froze apps on the leak and then flashed this script over it without defrosting them. Maybe Im wrong but sounds like it.
This is exactly why I had a problem. Fixed easily.
Posted 10 April 2012 - 10:29 AM
Posted 10 April 2012 - 11:46 AM
Posted 10 April 2012 - 11:50 AM
I'm gonna say you're wrong for about 65 to 85% of us.....I was on stock 173 unrooted before the leak b/c of the soak, then I got tired of waiting and flashed the leak, all I did was re download all my apps through the Play store b/c Tibu wasn't working for me at that time. It could be the rom, it could be the script, but I do know prior to the script I never had a problem with Script Manager and Root Explorer.
Posted 10 April 2012 - 12:05 PM
Posted 10 April 2012 - 12:29 PM
Posted 10 April 2012 - 02:19 PM
Mine was slow and laggy before i installed this. Example before while on leak only, when scrolling screens it was slow and would catch but not after i installed script. Didn't notice any bloat removed and like i said earlier sq lite doesn't work but I'm sure it will be resolved. All in all great job.
Posted 10 April 2012 - 02:28 PM
I got the frozen M this morning after a hard reset. No other problems. I did update busy and su before install.
Posted 10 April 2012 - 02:53 PM
That is exactly a flame post. The first two questions would have been just fine.
Posted 10 April 2012 - 02:57 PM
Posted 10 April 2012 - 04:28 PM
Posted 10 April 2012 - 07:18 PM
Posted 11 April 2012 - 08:01 AM
Posted 11 April 2012 - 09:42 AM
Agreed. First two questions was all that was needed. The rest is just complaining.
Posted 11 April 2012 - 11:25 AM
People aren't allowed to complain?
Posted 11 April 2012 - 11:33 AM
Posted 11 April 2012 - 02:11 PM
Complaining can usually be tolerated, but whining is another story...
Posted 12 April 2012 - 04:57 AM
Posted 12 April 2012 - 05:01 AM
Posted 12 April 2012 - 08:07 AM
Yeah, I guess complain was not the best choice or words. But to be honest, if you are installing a custom Rom for free that someone else put in the time and effort, I would say no, complaining isn't a right. If you don't like the Rom or modifier, try something else.
Posted 12 April 2012 - 08:11 AM
