[Cdma Razr][Ics] Rom | Axi0M Cmplx | Ics Leak | Modifier | By Droidth3Ory
140 replies to this topic
#21 wulf
wulf
    Themer
  • 929 posts
  • Twitter:@Wulf_X1
  • LocationMidwest
Posted 08 April 2012 - 04:27 PM
This is good.
But there is another thread about ICS leak Modifier. Some ppl might get confused, lol.
[Script]-Th3Ory's-Cmplx|Ics-Leak|Modifier
#22 mugsy77
mugsy77
  • 235 posts
  • Current Device(s):RAZR MAXX
Posted 08 April 2012 - 04:41 PM
This is good.
Lol he beat me to it by 20 mins! :-)
I only checked rom section if anyone posted. Well, both do the job and point to droidhive post so no damage there:-)
#23 wulf
wulf
    Themer
  • 929 posts
  • Twitter:@Wulf_X1
  • LocationMidwest
Posted 08 April 2012 - 04:43 PM
All good, thought there was two versions for a minute, lol.
#24 jmill75
jmill75
  • 20 posts
  • Twitter:jmill75
  • LocationOhio
Posted 08 April 2012 - 05:42 PM
I have tried 3 times now, rsd'ed back to stock and went through the process to keep root, each time it shows rooted when i first boot up the leak but no go. What the heck am I doing wrong.
1. rsd to stock
2. root, download ota rootkeeper and backup root
3. download and install ota updates, there's 2
4. install leak files and boot up
5. check ota rootkeeper and it says rooted but no luck
help
#25 Mystery252
Mystery252
  • 15 posts
  • Twitter:Mystery252
Posted 08 April 2012 - 05:52 PM
1. rsd to stock
help
Are you temp. unrooting before installing each update then restoring root after?
#26 mugsy77
mugsy77
  • 235 posts
1. rsd to stock
help
Read this :-)
#27 stephens7414
stephens7414
Posted 08 April 2012 - 06:20 PM
I flashed this and it seams to be running even smoother then before. I have not noticed any hiccups yet good job.
#28 romligno
romligno
  • 8 posts
Posted 08 April 2012 - 08:42 PM
There is an ICS specific bootstrap, DO NOT USE ANYTHING ELSE!
i used regular bootstrap worked fine. i wasnt aware of the ics bootstrap.
#29 wulf
wulf
    Themer
  • 929 posts
  • Twitter:@Wulf_X1
  • LocationMidwest
Posted 08 April 2012 - 08:49 PM
One of the reasons to use IC bootstrap is so you can make/restore nandroid backups. Regular one causes issues when doing those.
  • PillClinton likes this
#30 romligno
romligno
  • 8 posts
Posted 08 April 2012 - 09:00 PM
ok. i understand thanks!
#31 looneytuned29
looneytuned29
  • 90 posts
Posted 08 April 2012 - 10:53 PM
Only issue ive found so far is sq lite editor doesnt work. Says checking databases till not responding comes up. Any suggestions would be great.
#32 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • Twitter:530SharksFan
  • LocationNorCal
Posted 08 April 2012 - 11:11 PM
I just checked it out after I saw your post, I am also having this issue.
#33 lownslow200sx
lownslow200sx
    OSE-DEV/THEMER
  • 355 posts
  • Google+:Lownslow200sx
  • LocationRocky Mount, NC
Posted 08 April 2012 - 11:19 PM
After I flashed I'm having issues with Root Explorer. Anyone els having problems ? when I try to multiselect and delete all it gets stuck saying delete in progress but no luck it never deletes and I have to force close it myself had no problems before I flashed this.
#34 superrelaxx
superrelaxx
  • 921 posts
  • Twitter:jasNwa
  • LocationSeattle, Washington
Posted 09 April 2012 - 12:42 AM
Root Explorer would hang until I forced stopped the app and cleared cache/data
#35 cvhovey
cvhovey
    Post Traumatic nOOb Disorder
  • 185 posts
  • Current Device(s):Moto X Dev Ed, Moto X Retail, Nexus 7, Droid Razr Maxx, Droid X, OG Droid
Posted 09 April 2012 - 01:14 AM
I had same problems metioned above with sq lite editor and root explorer. Other than that, it was running smooth ... until I went into recovery the 2nd time ... it hung. Then things went downhill from there. So RSD back to .173 and restored back to RAZRX.
Droid Razr M XT907 B/L Unlocked - Stock Rooted
#36 osnoozeo
osnoozeo
  • 108 posts
Posted 09 April 2012 - 01:15 AM
Everything is good cept motocast does not work now
#37 superrelaxx
superrelaxx
  • 921 posts
  • Twitter:jasNwa
Posted 09 April 2012 - 04:03 AM
Motocast works for me
#38 spikefloyd
spikefloyd
  • 14 posts
Posted 09 April 2012 - 04:47 AM
for the root problem what worked for me and it is in the instructions make sure you update the binaries in the superuser app,I also was having hanging problems which is when the app is trying to aquire root after the update no problems with root
spike
#39 UnknownIntention
UnknownIntention
  • 43 posts
Posted 09 April 2012 - 05:23 AM
Everything is looking good B)
#40 Krazr
Krazr
  • 90 posts
Posted 09 April 2012 - 06:24 AM
I've been running this since last night and it's working great!
