Help me please
Droid Razr xt912
11 replies to this topic
#1 blackice33
blackice33
  • 6 posts
  • Current Device(s):droid razer xt912
Posted 28 April 2013 - 10:49 AM
I rooted my phone today and was trying to install aokp_spyder_jb-mr1_build-4 and everything fell through right. But when I rebooted it stays at the red M logo it flashes off then comes back on to the logo screen again and stays there. What does this mean and can it be fixed? By the way I tried to install jellybean 4.2.2 with aokp and its not letting me get into cwm to recover my back up data.
#2 Gus
Gus
  • 41 posts
  • Twitter:gus194
  • LocationHouston, Texas
  • Current Device(s):XT1053 Moto X Developer Edition, Droid Razr, Samsung Galaxy S Advance
Posted 28 April 2013 - 12:25 PM
You're going to have to boot into AP Fastboot and use Matt's Utility to take you back to Stock.
#3 blackice33
blackice33
  • 6 posts
Posted 28 April 2013 - 02:17 PM
I tried now my phone is stuck in status code 0 I don't know how to get out of this the message above it says boot failure.
#4 cmh714
First that needs to be in Slot 2, second try and wipe
#5 blackice33
blackice33
  • 6 posts
Posted 28 April 2013 - 02:32 PM
My phone is stuck in AP Fastboot Flash Mode (s) (Boot Failure) and won't charge what can I do to get it to charge so I can run RSD Light
#6 cmh714
Posted 28 April 2013 - 03:04 PM
Theres more info youre not posting. Please post the whole screen. If your batteries dead, you may need a Factory cable from Team Blackhat, if you cant get into CWM, and not sure even if you could get to CWM if you could charge. The majority of us here use Safestrap, which allows for charging in that Recovery.
And while you could use RSD you may be better off with Matts utility. Regardless, need to see more info and get the battery charged.
#7 blackice33
blackice33
  • 6 posts
Posted 28 April 2013 - 03:28 PM
Ap Fastboot Flash Mode (S) Boot Failure
0A.77
eMMC Info 16G
To return to normal mode - First press power ket to power down
Device is LOCKED. Status code: 0
Battery Low
Cannot Program
Connect USB
Data Cable
Invalid CG OTV (CG: system): Invalid SP Data
Invalid CG HAB (CG: system, status: 0x004E)
This is what it is saying
#8 cmh714
Posted 28 April 2013 - 03:36 PM
OK, thats a bit better from the information perspective. Youre gonna need to get a charge as fastboot wont take a flash with Battery Low.
Get one of these, but your dead in the water until we can get a charge to the battery.
There are some other battery tricks that may work or not. See the 2 threads on Battery near the top:
  • neckchop likes this
#9 cmh714
Posted 28 April 2013 - 03:38 PM
Also, what carrier are you on and are you in the US?
#10 blackice33
blackice33
  • 6 posts
Posted 28 April 2013 - 06:48 PM
thank you I got my battery charging now and setting my phone back up now.
#11 blackice33
blackice33
  • 6 posts
Posted 28 April 2013 - 06:49 PM
Verizon
#12 tucstwo
  • Google+:tucstwo@gmail.com
Posted 30 April 2013 - 06:33 PM
Ok, so now like previously stated, you should get a hold of Matts "Razr Utility" and get your phone restored to stock, so you can start fresh.
Also tagged with one or more of these keywords: Droid Razr xt912
