[Solved] Erased system
2 replies to this topic
#1 asteroid69
asteroid69
  • Current Device(s):Motorola Razr Maxx XT910
Posted 27 April 2013 - 07:49 PM
When i was in Safestrap i erased the stock OS, but i dont know how the hell can i restore ICS 4.0.4, i'm living with another rom, another partition,  so wanted help por this, because i have a lot of time with my mistake. Thanks
#2 asteroid69
asteroid69
Posted 27 April 2013 - 08:00 PM
 I tried to fix it with a Fastboot but in only got worse, now i'm in AP Fastboot Flash Mode (S) (Flash Failure). Help please
#3 asteroid69
asteroid69
Posted 28 April 2013 - 09:43 AM
Solved, i downloaded a Fasboot, from here
 you can check if you have an UMTS, check, and use the RSD Lite to flash it, and thats it!
