[HELP] Porting a boot animation to DROIDRAZRHD
18 replies to this topic
#1 RaSuRaDoRa
RaSuRaDoRa
  • 132 posts
Posted 27 April 2013 - 02:42 PM
Can someone please port this boot animation to fit the droid razr HD . i cant figure it out at all :/
Original thread for the Bootanimation :
EDIT: Thanks to MarkusMcNugen for the help!  * His DL Link if anyone else wants the Animation
#2 ZKK007
ZKK007
    That Kiwi Guy
  • 1,687 posts
  • LocationDallas, TX, USA.
Posted 27 April 2013 - 04:07 PM
You need to change the desc.txt file. It should read:
720 1280 25
p 1 0 part0
p 0 0 part1
The 720 1280 is the HD resolution
I didn't open the images, but you might also need to change them to the HD resolution of 720x1280. I would change the desc file first and if that doesn't work, resize the jpg files.
When you zip the "bootanimation" folder, it needs to be on "storage" compression mode.
I hope this help!
  • RaSuRaDoRa and zooyork0721 like this
Donate? Click on signature :)
#3 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
  • LocationDecatur, MI
  • Current Device(s):Bionic
Posted 27 April 2013 - 05:53 PM
I got this man. lol. You should have PMed me or given me a minute to get back to you. Ill have it for you in a bit.
  • RaSuRaDoRa likes this
#4 Guest_BDH_*
Guest_BDH_*
Posted 27 April 2013 - 05:55 PM
Can I get a link to actually download it? There's no way to download it from the link...
#5 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
Posted 27 April 2013 - 05:59 PM
For which phone?
#6 Guest_BDH_*
Guest_BDH_*
For which phone?
Any phone lol, I can port it myself.
#7 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
Posted 27 April 2013 - 06:05 PM
He pulled it from one of my first threads here on the forum. I asked which phone because they are in Bionic/Razr resolution of 960x540. Im currently doing the one he asked for now, just optimizing the pngs then its good to go, but feel free to port whatever ones you fancy.
#8 Guest_BDH_*
Guest_BDH_*
Posted 27 April 2013 - 06:14 PM
Oh ok, well if you don't mind I'd like to port it to the S3?
#9 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
Posted 27 April 2013 - 06:17 PM
Go for it. I didnt make the first two, like I said in my thread. I ported them to bionic from a deviantart.com post. Id just make sure to credit the original guy like I did in my thread for the first two animations. The third was modified from the first two by me, and the last 2 were made my me.
#10 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
Posted 27 April 2013 - 06:25 PM
I should have it for you in an hour or less. It would be sooner but Im running my super png optimze tool on it to cut the size down a lot. First 40 pngs in the boot animation optimized and already saved 400Kbs.
  • RaSuRaDoRa and shane1 like this
#11 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
Posted 27 April 2013 - 07:53 PM
Heres your boot animation. If for some reason it doesnt work let me know, it should be a simple quick fix.
Flash in recovery
#12 RaSuRaDoRa
RaSuRaDoRa
  • 132 posts
Posted 28 April 2013 - 03:05 PM
Thanks everyone for the help ! really appreciate ! :) , il flash the zip and let you know how it goes
#13 RaSuRaDoRa
RaSuRaDoRa
  • 132 posts
Posted 28 April 2013 - 03:14 PM
Flash in recovery
well it semi bricked.lol the animation doesnt show and my phone doesnt boot
EDIT; im running CM10.1 by epinter btw
#14 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
Posted 28 April 2013 - 03:36 PM
Damn. Okay, Ill fix it now.
#15 RaSuRaDoRa
RaSuRaDoRa
  • 132 posts
Posted 28 April 2013 - 03:41 PM
ok , thank god i made a backup lol
#16 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
Posted 28 April 2013 - 04:29 PM
Try this one. If this doesnt work Im pretty much out of ideas. The images are the correct resolution, and the desc.txt file has the correct dimensions and folders... not to mention all the images named in sequential numeric order.
There is no reason this should not be working...
#17 RaSuRaDoRa
RaSuRaDoRa
  • 132 posts
Posted 28 April 2013 - 04:37 PM
Worked perfectly ! thanks man. you should make a thread and port the rest of them for everyone else with a droid HD. these bootanimations are beautiful
  • MarkusMcNugen likes this
#18 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
Posted 28 April 2013 - 05:13 PM
Perhaps I will sometime soon. Just been kinda busy with the Blurry JB rom for the Bionic.
#19 Guest_BDH_*
Guest_BDH_*
Posted 28 May 2013 - 09:57 PM
Moved from "Themes" to "Themeing How-To's & Questions" as this is not a theme post.
