last week i downloaded jellybean and manually updated. used voodoo, retained root. all is good.
did a factory reset yesterday. lost root. thought i could re-root with
motochopper did not do the job. so like a dummy i went ahead with trying to flash back by using
These instructions are based on Windows Users, there are common similarities for Mac/
. EXTRACT THE .ZIP TO YOUR DESKTOP FOR BEST RESULTS (if successful should see a single file folder holding all the contents on the desktop.) Make sure that USB Debugging is enabled (check this setting in> Settings> Developer Options> USB debugging, also check to ensure your computer is connected via USB cable and your device is displayed and appears in .) Open the folder for UTILITY and…1. Find DROID_RAZR_HD_UTILITY.bat perform a single right-click and Run as Administrator.
2. Program will open and go into MattLGroff’s the “Batman Screen” press any key to continue, which leads to “Options 1-4”
3. Start by putting your device in NOTE Device must be in "AP Fastboot" mode, to do this begin by Rebooting your device, HOLD [Power + Volume Down (-)] at the same time, continue to HOLD through the screen print snapshot, RELEASE when SCREEN IS BLACK. AS SOON AS IT IS BLACK HOLD [Power + Volume Up (+)] at the same time, release when menu appears. Use Volume down (-) to highlight [AP Fastboot] + Volume Up to select. Once in AP Fastboot, continue with the first option “Fastboot Restore 0.6.25 <ICS 4.0.4 Official Software>” this will delete ALL YOUR SETTINGS and ANYTHING STORED ON THE INTERNAL MEMORY. You will need to press any key during this downgrade, just watch the screen for the prompts and directions.
4. Your device will
5. UPDATE 3.6.13, the 0.7.2, which is an 6MB File Download is functioning, if it does not pop-up automatically. Then it can be accessed via Settings> About phone> System updates, once it downloads GO AHEAD and Install Now. The phone will Reboot> you’ll see the Red Dot> then the Android with the Blue Spinning Cube in his Chest with Blue Line below.
which bricked the phone.
any help?
