[KEXEC] Code Kernel 4/24/13
bytecode kexec kernel Bionic AOSP
78 replies to this topic
#1 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
  • Twitter:@BytecodeMe
Posted 24 April 2013 - 09:06 PM
This is my first released kernel ever! :)
WILL ONLY WORK ON AOSP ROMS!
Features:
Frequency slot and other CPU tweaks
Custom voltage control
ROW scheduler
Pegasusq governor
Fsync turned off with toggle
Miscellaneous I/O tweaks
Problems:
None known
To come:
More tweaks to make smoother/ better battery life
Changelog:
R2 4/23/13:
Fixed some stability issues by reverting some commits
R3 4/24/13:
The fix for min frequency being stuck at 300Mhz; is now 150Mhz
Disable GENTLE_FAIR_SLEEPERS
Entropy tweaks
Lowered CPU transition latency
Updated Targa defconfig for compiliong for them
Latest commits from upstream CM kernel
R4 4/27/13:
Modified Smartrelfex driver
OCable to 1400Mhz
CPU OC and control
Disabled some Memory debugging
Set fsync on for stability but decrease in I/O performance
Many more CPU governors
Many more Schedulers
R5 4/29/13:
Boot up at 1200Mhz still OCabe to 1.4
Disabled some governors and schedulers
Disabled some debugging
I HIGHLY RECOMMEND INSTALLING TRICKSTER MOD TO MODIFY KERNEL SETTINGS!
DO NOT TOUCH ANYTHING UNDER SMARTREFLEX OR CORE OC IT IS VERY LIKELY YOU WILL DAMAGE YOUR PHONE PERMANENTLY!!!
I AM NOT RESPONSIBLE FOR ANYTHING THAT HAPPENS TO YOUR DEVICE!
Thank you:
dhacker29
Hashcode
dtrail
franco
faux123
imoseyon
Hero_Indeed
  • neckchop, medic, mjs27541 and 3 others like this
#2 Aldroid33
Aldroid33
    Superuser
  • 766 posts
Posted 25 April 2013 - 04:48 AM
First! :)
  • BytecodeMe and upchuckle like this
Samsung S4, Rooted, Encrypted, Stock JB 4.4.3 GPE and Echo TW v.24 4.4.2
Moto Xoom WiFi-EOS Big Part 4.4.4 w/ TWRP 2.7.1. Thanks BRD & R'nH!
#3 Aldroid33
Aldroid33
    Superuser
  • 766 posts
Posted 25 April 2013 - 04:50 AM
Can you provide guidence in flashing this Kernal. Can it be used with CM 10.1 kexec builds? Is it already baked in?
Thank you for your hard work!
#4 useltonm
useltonm
  • 664 posts
  • LocationDenver, CO
  • Current Device(s):T-Mobile Galaxy Note 3,
Posted 25 April 2013 - 05:55 AM
Keeping an eye on this. ::thumbsup::
#5 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Posted 25 April 2013 - 06:14 AM
Yep can be used on CM10.1, AOKP, Pacman, Liquid can be hit and miss. Just flash the zip file like you would anything else.
#6 berndt_toast
berndt_toast
  • 29 posts
Posted 25 April 2013 - 06:39 AM
I tried this with CM 10.1 4/20 build, and it does not seem to load. After the safestrap splash screen, there is not the second kexec buzz. It sits at a black screen with the key lights on. I flashed this and wiped cache and dalvik cache. Any ideas?
#7 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Posted 25 April 2013 - 06:44 AM
Use CM nightly 4/22 and after. They reverted the kernel back to 3.0.8 on 4/22 and I made it from those sources.
  • nakedtime likes this
#8 berndt_toast
berndt_toast
  • 29 posts
Posted 25 April 2013 - 06:48 AM
Ahh, gotcha. I will wait until the sound bugs are gone to install 4/22 or after. Thanks.
#9 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Posted 25 April 2013 - 06:51 AM
Didn't know there were sound bugs lol
This kernel was made for the RAZR as that's what I own, so I'm not too in touch with what Bionic has problems with. This version specifically was compiled for Targa.
#10 berndt_toast
berndt_toast
  • 29 posts
Posted 25 April 2013 - 06:53 AM
Yeah, ringtones do not work, you cannot hear the other person in a phone call and they cannot hear you. This does look promising and I am looking forward to being able to overclock once you get that added.
#11 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Posted 25 April 2013 - 09:07 AM
How's she running for all you guys?
  • AmericanBully likes this
#12 frankemtp
frankemtp
  • 98 posts
  • LocationChicago, IL
  • Current Device(s):Bionic
Posted 25 April 2013 - 10:12 AM
I look forward to seeing what this little guy does.  I, personally have not been having sound problems with the nightlies and am presently on 25. :rolleyes:
#13 kitcostantino
kitcostantino
  • 31 posts
Posted 26 April 2013 - 02:42 AM
Maybe a dumb question, but will this work if my stock is jb ota? Obviously, not on that slot, but i was thinking about cm10.1 on slot 1,with this because it seems like it would work independently, but i dont know enough to say that for sure. Will it work? Will i brick? Thanks
#14 Aldroid33
Aldroid33
    Superuser
  • 766 posts
Posted 26 April 2013 - 04:28 AM
I have been unable to flash, perhaps bad download. Md5, please.
Sent from my Xoom using Tapatalk HD
#15 vince2796
vince2796
  • 62 posts
  • Current Device(s):Motorola Droid Bionic
Posted 26 April 2013 - 05:28 AM
anybody know an official link for pacman rom for bionic?
#16 BytecodeMe
BytecodeMe
    Private Pile
  • 2,004 posts
Posted 26 April 2013 - 05:57 AM
That'll work.
Mahhh I'm lazy :D
#17 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
  • LocationWhere I AM
Posted 26 April 2013 - 11:25 AM
PAC is posted over at the droid hive. On my mobile but you should be able to find it.
#18 csantarcangelo
csantarcangelo
  • 159 posts
Posted 26 April 2013 - 12:09 PM
Just having fun with Android!
#19 will4958
will4958
  • 63 posts
Posted 26 April 2013 - 12:17 PM
This may be a dumb question, but will this allow us to use the HDMI out connection and connect the Bionic to the TV?
#20 nobe1976
nobe1976
    I Void Warranties
  • 1,303 posts
  • Twitter:@nobe1976
Posted 26 April 2013 - 02:07 PM
Only ROMs that are moto base will have the HDMI connection feature. It is a moto thing not a AOSP thing. So if you like and do it stick with the custom ROMs that are based off of the OTA.
Bytecode
I am currently running Avatar on slot 3 with a fully stock OTA Bean on Stock slot. Will this work with Avatar or should I just try it with the ROMs that I have seen in this tread.
Also tagged with one or more of these keywords: bytecode, kexec, kernel, Bionic, AOSP
