[SOLVED]SafeStrap not going into recovery no os on phone
xt807 safestrap no os motorola droid razr m help
Best Answer tucstwo , 24 April 2013 - 07:02 PM
OK, OFFICIALLY SOLVED! This member needed the 4.1.2 Razr M FXZ files that were pre-released this evening. (I'm sure a public release in imminent). When he flashed the (edited...to confirm previous version..in his case) he was able to get his phone fully restored and booting. Case CLOSED.
To those reading. The Razr M 4.1.2 FXZ files HAVE leaked and I'm sure will be on SBF developers within hours. Cheers!
Go to the full post
107 replies to this topic
#61 aiur1
aiur1
  • 54 posts
  • LocationCalifornia
  • Current Device(s):Note 3 (SM-N900V)
Posted 24 April 2013 - 10:26 AM
So what should I do? Is it bricked beyond repair or...?
#62 milski65
milski65
  • 740 posts
  • Twitter:milski65
Posted 24 April 2013 - 10:27 AM
No offense, but if you have another pc or something, you may want to Google rsd flashing or something similar. Plenty of videos out. 5 minutes viewing that will make it easier for you to do then via posts. Won't have to wait for responses. You'll have it up and running in no time. Just a suggestion.<br /><br />Sent from my XT875 using Tapatalk 2<br /><br /><br />
#63 Aixelsyd
Aixelsyd
    Freak on a Leash
  • 640 posts
  • LocationWindy City
Posted 24 April 2013 - 10:29 AM
How do I manually send the commands through RSD ?
you dont you need to the snapdragon fastboot stuff. Here is a link to it
Unzip that to a drive on your computer and remember where it is. Once that is done unpack the full XML file. then copy the boot.img, recovery.img, and system.img to the exact folder you unzipped snapdragon-fastboots to. After you have that done open command prompt on your computer and change the drive /directory to the folder with the fastboot.exe in & the 3 *.img files.
Once you have that done put the device in AP mode and hook it up to your comp and follow these commands
fastboot flash recovery recovery.img      then press Enter. When it finishes that
fastboot flash boot boot.img                    then press Enter. When it finishes that
fastboot flash system system.img            then press Enter
When all three are done unplug from comp and press power button and it should power off. Once power off try firing it up and see what you get.
#64 Aixelsyd
Aixelsyd
    Freak on a Leash
  • 640 posts
Posted 24 April 2013 - 10:33 AM
BTW if it starts booting like you are after but does a bootloop you'll have to manually power down and get into Recovery and do Factory reset then it should boot fine.
#65 aiur1
aiur1
  • 54 posts
Posted 24 April 2013 - 10:42 AM
Alright I did that. But I think my battery is low again. I'm going to have to charge it up.
Microsoft Windows [Version 6.1.7600]
Copyright © 2009 Microsoft Corporation.  All rights reserved.
C:\Windows\system32>cd C:\Users\Aiur\Downloads\snapdragon-fastboots\Windows
C:\Users\Aiur\Downloads\snapdragon-fastboots\Windows>fastboot flash recovery rec
overy.img
sending 'recovery' (10240 KB)...
OKAY [  0.842s]
writing 'recovery'...
Battery Low!!
FAILED (remote failure)
finished. total time: 1.117s
C:\Users\Aiur\Downloads\snapdragon-fastboots\Windows>fastboot flash boot boot.im
g
sending 'boot' (10240 KB)...
OKAY [  0.802s]
writing 'boot'...
Battery Low!!
finished. total time: 1.073s
C:\Users\Aiur\Downloads\snapdragon-fastboots\Windows>fastboot flash system syste
m.img
sending 'system' (30720 KB)...
OKAY [  2.380s]
writing 'system'...
Battery Low!!
finished. total time: 2.650s
#66 aiur1
aiur1
  • 54 posts
Posted 24 April 2013 - 10:46 AM
Alright I powered it off, set it to boot normally, and now it's on the black screen charging back up because I heard it won't charge in fastboot mode. I will repeat the previous operation again once it's been charging for like an hour because I don't actually know how charged the battery is. I will repost with an update when charged
#67 aiur1
aiur1
  • 54 posts
Posted 24 April 2013 - 11:20 AM
I just flashed the stuff. Any ideas why it's saying failed on boot and system?
overy.img
OKAY [  0.804s]
OKAY [  3.102s]
finished. total time: 3.907s
g
OKAY [  0.871s]
writing 'boot'...
Preflash validation failed
finished. total time: 1.151s
m.img
OKAY [  2.386s]
writing 'system'...
finished. total time: 2.693s
#68 aiur1
aiur1
  • 54 posts
Posted 24 April 2013 - 11:22 AM
Physical phone screen after manual flash:
fastboot reason: boot menu selected
usb connected
partition (boot) security version Downgraded
preflash validation failed for boot
partition (system) security version downgraded
PIV black validation for system failed
#69 tucstwo
  • Google+:tucstwo@gmail.com
Posted 24 April 2013 - 11:27 AM
I've seen that error before. It's almost like you're flashing the wrong files?
Sent from my HTC6435LVW using Tapatalk 2
#70 brandon71
brandon71
  • 553 posts
  • Google+:tbd7171@gmail.com
  • LocationKodak, TN
Posted 24 April 2013 - 11:28 AM
I got the first 2 errors when downgrading but mine worked
#71 aiur1
aiur1
  • 54 posts
Posted 24 April 2013 - 11:31 AM
Here is exactly what I am doing:
I have the boot.img, system.img, recovery.img from C:\Program Files (x86)\Motorola\RSD Lite\VZW_XT907_4.1.1-9.8.1Q-27-2-4_1FF.xml\VZW_XT907_4.1.1-9.8.1Q-27-2-4_1FF.xml
and I put it in the snapdragon folder, you can pretty much see from my outputs from cmd
Any suggestions? Maybe a link to another package to try and flash from?
#72 tucstwo
Posted 24 April 2013 - 11:42 AM
Hang on one min, I am converging with the geniuses at the moment. I'll be back in a few.
  • Aixelsyd, neckchop and shane1 like this
#73 tucstwo
Posted 24 April 2013 - 12:29 PM
Just an update for everyone who's been helping in this thread. I wish I could add [SOLVED] to the title, but it wouldn't be fair to the OP as though his problem is solved, his phone is still broken. I'll explain:
Ok, so after some messing around in the chat room, the realization came up that the OP was already flashed to the latest 4.1.2 system. I didn't know that. At the moment, we only have at our disposal 4.0.4 and 4.1.1 fastboot files. We also found out that this started after wiping all the slots in his safestrap and then accidentally rebooting without any system installed. We were running into all these errors because his secure version updated with 4.1.2, his bootloader was yet to be unlocked and we all know you can't downgrade once your secure version updates.
Our last ditch effort was to flash the 4.1.2 OTA (that
provided me earlier in the week, thanks for that, btw), but it failed right away at file_getprop: failed to stat "/system/build.prop":no such file or directory So, as there was no system. That option was not going to work.
Sadly, until Razr M 4.1.2 fastboot files leak out, there's very little we can do for the OP at this moment. This is a reason that makes it vital to have your bootloaders unlocked. Had it been done on this phone already, 4.1.1 would have flashed with no problems and we'd have been done last night. The FB files have been leaking rather quickly lately. So hopefully, the OP won't be stuck for too long.
  • Aixelsyd, Nanniepoo, neckchop and 2 others like this
#74 Aixelsyd
Aixelsyd
    Freak on a Leash
  • 640 posts
Posted 24 April 2013 - 12:36 PM
^^^ Dam i wish i had known 4.1.2 was on it already as well.
  • neckchop likes this
#75 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 24 April 2013 - 01:03 PM
Just Say NO !!!!! To OTA's
  • brandon71 likes this
sig made by
Rinkle McBally
#76 aiur1
aiur1
  • 54 posts
Posted 24 April 2013 - 05:04 PM
How long does it generally take for FB files to leak? Like a general timeframe? How fast have they been leaking lately?
#77 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 24 April 2013 - 05:40 PM
I would say all the Moto phones have been pretty quick lately but you know how that goes when you want it then it's not quick enough.
#78 aiur1
aiur1
  • 54 posts
Posted 24 April 2013 - 05:50 PM
I mean, how long did it take between 4.0.4 to 4.1.1?
#79 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 24 April 2013 - 05:52 PM
I was going to say...the fxz for the JB Bionic build was pretty quick. Was a matter of a few days. Hopefully this will be the same scenario here. I have been keeping an eye out for them so if I notice them up I will post if nobody else has at the time.
  • shane1 likes this
#80 tucstwo
Posted 24 April 2013 - 05:53 PM
Dude, I have tried you on Gtalk, Email, Private Message, every method known to man! The freaking Razr M 4.1.2 Fastboot FXZ file leaked today! You's a lucky guy. Get at me so I can get em to you, dang it! You're a hard guy to get a hold of, LMFAO!
I got EM! Dude man needs to read his peripherals!
  • milski65, neckchop and tmyinc like this
Also tagged with one or more of these keywords: xt807, safestrap, no os, motorola droid razr m, help
