[SOLVED]SafeStrap not going into recovery no os on phone
xt807 safestrap no os motorola droid razr m help
Best Answer tucstwo , 24 April 2013 - 07:02 PM
OK, OFFICIALLY SOLVED! This member needed the 4.1.2 Razr M FXZ files that were pre-released this evening. (I'm sure a public release in imminent). When he flashed the (edited...to confirm previous version..in his case) he was able to get his phone fully restored and booting. Case CLOSED.
To those reading. The Razr M 4.1.2 FXZ files HAVE leaked and I'm sure will be on SBF developers within hours. Cheers!
Go to the full post
107 replies to this topic
#21 neckchop
neckchop
    pluh!
  • 477 posts
  • Locationatlantic City
Posted 23 April 2013 - 05:22 PM
I did the exact same thing you did, trying to put eclipse on stock. Wiped system and rebooted with no os. Then I did a restore with matt's utility, and did the exact same thing again. Haha. I had screaming kids everywhere and got in a rush in both cases. I powered downy phone, and did the three finger combo, power &volume up &volume down to get to the boot loader menu. Scrolled down to fast boot, selected it with the volume up button, plugged in and ran option 1 on both occasions. Brought me back to stock and good to go. Make sure you're using the RAZR M 1.10 utility. You might have issues if you run the older utility as it only had ICS restore, and not jelly bean. Also, if you hadn't already plugged your phone into the computer, you may not have the needed drivers. I'm not sure if it would go as far as you Id previously in the restore option, just a throwing ideas out there. Also, when running the restore option, you'll get most of the way through it and then it'll hang for a few moments. Don't panic, it didn't freeze. :-). Made me pretty nervous the first time at that point. Lol. I just wanted to chime in ticket you know I made the exact mistake you did, not once, but twice, and that your device isn't completely hosed. Don't stress yet!
  • shane1 and aiur1 like this
#22 aiur1
aiur1
  • 54 posts
  • LocationCalifornia
  • Current Device(s):Note 3 (SM-N900V)
Posted 23 April 2013 - 05:48 PM
Thanks man. I really hope this all works too. This download is painfully slow. It's like 128kbs. I wish there was just a torrent for it with a billion seeds :(
  • neckchop likes this
#23 aiur1
aiur1
  • 54 posts
Posted 23 April 2013 - 05:50 PM
But i guess the fact of the matter is I guess since I have the ability to get into fastboot my device would never get fully bricked, right? Because worst case you could go back in and reflash the stock rom
  • neckchop and shane1 like this
#24 aiur1
aiur1
  • 54 posts
Posted 23 April 2013 - 06:38 PM
Alright I tried flashing through RSD Lite, and I tried flashing and it came back with this:
For 4.1.1
Failed flashing process: 1/19 flash partition "gpt_main0.bin" > Phone returned FAIL
For 4.0.4
Failed flashing process: Unknown fastboot command. (getvar)
#25 brandon71
brandon71
  • 553 posts
  • Google+:tbd7171@gmail.com
  • LocationKodak, TN
Posted 23 April 2013 - 06:43 PM
Matts utility should work fine and its easier than rsd
#26 aiur1
aiur1
  • 54 posts
Posted 23 April 2013 - 06:49 PM
Here is what came out when I tried doing Matt's Utility:
[*] Simple Razr Restore
[*] Windows Version
[*] Created by mattlgroff
[*] Before continuing, ensure your Razr is in the
[*] "AP Fastboot" mode and connected via USB.
[*]--- Also press the keys after the screen flashes back on when asked---
[*] If your battery is low do NOT run this program Charge Charge Charge!
sending 'sbl1' (100 KB)...
OKAY [  0.019s]
writing 'sbl1'...
Battery Low!!
FAILED (remote failure)
finished. total time: 0.276s
sending 'sbl2' (126 KB)...
OKAY [  0.022s]
writing 'sbl2'...
Battery Low!!
sending 'sbl3' (512 KB)...
OKAY [  0.051s]
writing 'sbl3'...
Battery Low!!
finished. total time: 0.303s
sending 'rpm' (140 KB)...
OKAY [  0.022s]
writing 'rpm'...
Battery Low!!
sending 'tz' (192 KB)...
OKAY [  0.028s]
writing 'tz'...
Battery Low!!
finished. total time: 0.278s
sending 'aboot' (256 KB)...
OKAY [  0.031s]
writing 'aboot'...
Battery Low!!
finished. total time: 0.284s
rebooting into bootloader...
OKAY [  0.008s]
finished. total time: 0.008s
 Waiting for a moment...
< waiting for device >
sending 'partition' (32 KB)...
OKAY [  0.019s]
writing 'partition'...
Battery Low!!
OKAY [  0.020s]
writing 'sbl1'...
Battery Low!!
finished. total time: 0.273s
OKAY [  0.022s]
writing 'sbl2'...
Battery Low!!
finished. total time: 0.279s
OKAY [  0.050s]
writing 'sbl3'...
Battery Low!!
finished. total time: 0.304s
OKAY [  0.022s]
writing 'rpm'...
Battery Low!!
finished. total time: 0.270s
OKAY [  0.026s]
writing 'tz'...
Battery Low!!
finished. total time: 0.286s
OKAY [  0.031s]
writing 'aboot'...
Battery Low!!
finished. total time: 0.282s
sending 'boot' (10240 KB)...
OKAY [  0.808s]
writing 'boot'...
Battery Low!!
finished. total time: 1.065s
sending 'system' (30720 KB)...
OKAY [  2.405s]
writing 'system'...
Battery Low!!
finished. total time: 2.660s
sending 'recovery' (10240 KB)...
OKAY [  0.816s]
writing 'recovery'...
Battery Low!!
sending 'modem' (30720 KB)...
OKAY [  2.408s]
writing 'modem'...
OKAY [  0.802s]
sending 'modem' (17576 KB)...
OKAY [  3.021s]
writing 'modem'...
OKAY [  0.966s]
finished. total time: 7.198s
sending 'devtree' (512 KB)...
OKAY [  0.050s]
writing 'devtree'...
Battery Low!!
finished. total time: 0.302s
erasing 'modemst1'...
OKAY [  0.587s]
finished. total time: 0.587s
erasing 'modemst2'...
OKAY [  0.846s]
finished. total time: 0.846s
sending 'fsg' (2794 KB)...
OKAY [  0.226s]
writing 'fsg'...
Battery Low!!
finished. total time: 0.474s
erasing 'cache'...
OKAY [  0.949s]
finished. total time: 0.950s
erasing 'tombstones'...
OKAY [  0.795s]
finished. total time: 0.795s
 It is recommened to wipe data, especially if you were on a custom rom.
 If you don't you will probably bootloop and have to wipe anyway...
 Press any key to Wipe the phone's data (might wipe internal SD card!)
 or exit the utility.
erasing 'userdata'...
OKAY [  2.325s]
finished. total time: 2.325s
OKAY [  2.431s]
writing 'modem'...
Battery Low!!
finished. total time: 2.711s
OKAY [  0.724s]
finished. total time: 0.725s
OKAY [  0.854s]
finished. total time: 0.854s
rebooting...
finished. total time: 0.006s
 You are now on stock JB 4.1.1.
 Your device will now reboot and install radio files, then fully boot normally.
Please make a selection or hit ENTER to return:
#27 aiur1
aiur1
  • 54 posts
It rebooted but after safestrap it still goes to a black screen, so is it safestrap?
#28 tucstwo
  • Google+:tucstwo@gmail.com
Posted 23 April 2013 - 06:54 PM
Oh man. That's trouble. Battery too low. You need either a "factory" or a flashing adapter at this point. I'm sorry. You're SOL with a dead battery. Without those hardware tools, there's very little we can do to help you at this juncture.
Sent from my HTC6435LVW using Tapatalk 2
#29 aiur1
aiur1
  • 54 posts
Posted 23 April 2013 - 06:59 PM
So what can I do...? I can't plug it in anywhere to charge? Can I take it back to verizon and get a new phone? What if I say it was stolen or some $#!+...? Like, what are my options?
#30 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 23 April 2013 - 07:06 PM
You need to order a factory adapter from TeamBlackHat.  Just search Google, it should be the first option that pops up.  I ordered one last night, just to have one on hand.
I am seeing a common trend now.  There is a reason that every developer says to make sure the phone is fully charged, before attempting to flash/modify anything.
#31 aiur1
aiur1
  • 54 posts
Posted 23 April 2013 - 07:18 PM
Alright I'll be ordering
 within the next week. I will get this phone fixed. If this thread gets closed or pruned before I get the adapter I will make a new thread if needed. The thing is, once I get it, and i flash the stock rom successfully, will it overwrite safestrap? or how can I reflash the stock recovery?
#32 coleam
coleam
  • 21 posts
  • Current Device(s):Moto XT907
Posted 23 April 2013 - 07:26 PM
Actually, I had this exact same problem.  Completely identical, down to the low battery failure when running Matt's utility.  I left my phone plugged into a wall charger on the black screen for the day and it charged enough to run the utility no problems.  You can order the adapter just in case (it's only $10), but try leaving it plugged in for a few hours before you do anything drastic.
#33 tucstwo
Posted 23 April 2013 - 07:27 PM
+1, charged up is the most important factor. What u do from here is your choice based on your ethics. But its not repairable without an adapter or replacement, if you think toy can convince them that the error is a defect on materials and workmanship. I can't make ur mind up for you though. But be assured, there is definitely no "immediate" solution.
#34 AK47sForAll
AK47sForAll
  • 50 posts
Posted 24 April 2013 - 12:09 AM
God, this exact thing happened to me too. Luckily my battery was high enough since I had it in the whole time that the RSD flashing worked. Good luck man.
#35 netizenmt
netizenmt
  • 150 posts
Posted 24 April 2013 - 05:37 AM
question: Do you need the cable AND the adapter, or just can the adapter be used with the stock cable in place of the factory cable?
#36 Nanniepoo
Nanniepoo
  • 298 posts
  • LocationDetroit, MI
Posted 24 April 2013 - 05:39 AM
Unless you unlocked your phone, your stock recovery is still there (actually just an option or two below fastboot). Safestrap kind of just bypasses it, I'm not entirely sure how it works. I believe Matt's utility also wipes your data, so yes, you'll lose safestrap, but it's easily re-installed.
#37 tucstwo
Posted 24 April 2013 - 05:57 AM
No, an adapter can just be put in line with a regular cable. You don't need both.
It uses a hijack during the booting process. This is why it's referred to as a bootstrap recovery. And you are correct unless the bootloader is unlocked, the factory recovery always remains I'm it's partition unless it becomes corrupted. In that situation, fastboot or RSD could flash only a signed copy of the original file. The fastboot files as we call them.
  • shane1 likes this
#38 lowvolt
lowvolt
  • 478 posts
Posted 24 April 2013 - 06:01 AM
When you get it fixed I would suggest getting rid of safe strap and just unlock the boot loader.
#39 netizenmt
netizenmt
  • 150 posts
Posted 24 April 2013 - 06:19 AM
OK, just ordered my adapter - don't need it now, but who wants to wait until you do? :)
@lowvolt - if I uninstall Safestrap, I'd lose my custom recovery, so what would I do for backing up my ROM, etc? Ummm. dumb question, I suppose. There's probably a way to install a recovery without Safestrap, I'd guess. Or it's something you can do once you are unlocked. Never been unlocked before in the same way.
Never mind - of COURSE - you can flash a custom recovery to the recovery partition using fastboot. Doh! - I need to go to bed for a while lol.
  • milski65 likes this
#40 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 24 April 2013 - 06:26 AM
After you unlock you can install a real custom recovery like TWRP which is just like s's or cwm which is kinda like stock recovery
Also tagged with one or more of these keywords: xt807, safestrap, no os, motorola droid razr m, help
