[Buglist] Known issues for 4.2.2/CM10.1/etc ROMs
153 replies to this topic
#141 ripper2860
ripper2860
  • 137 posts
  • Current Device(s):Motorola Droid Razr HD Maxx
Posted 08 September 2013 - 07:33 AM
Release Candidate 2 of the "Official" Cyanogenmod 10.1 (4.2.2-based) ROM for XT926 is out and available here:
Running smooth with all working so far.  If you are Running a Sktrilax (or DHacker) build it should be a simple flash w/ Dalvik and Cache wipe only.  I flashed over my Skrilax CM10.1 ( 8/08 ) Nightly and all is working great.  If you want a solid ROM that is on its way to being Officially supported, this is one you should try.
Motorola Razr HD Maxx
Root and Unlocked Bootloader | Blurry 1.2 HD  | Nova Launcher | CrossBreeder MOD
#142 Anon5978
Anon5978
  • 54 posts
  • LocationU.S.A.
Posted 08 September 2013 - 05:04 PM
Just in case anyone has problems trying to download from that link-- It wouldn't download correctly on my phone using Chrome but it worked perfect when I used Firefox.
Sent from my XT926 using Tapatalk 4
#143 mrf582
mrf582
  • 44 posts
Posted 09 September 2013 - 02:07 PM
Does this new RC2 still have the same signal strength bug?
#144 bjoostema1933
bjoostema1933
  • 122 posts
  • LocationNorth Carolina
  • Current Device(s):Razr HD Maxx /Nexus 7
Posted 15 September 2013 - 07:25 PM
the low audio on recorded video fix seems to only work on slim and slim based firmware.  I can't get it to work on Caron and CM without losing the ability to view recorded videos.  Works like a charm on slim though!
#145 EliC
EliC
  • 54 posts
Posted 16 September 2013 - 08:00 AM
Speaker phone is now fixed, at least in 10.2
#146 ripper2860
ripper2860
  • 137 posts
Posted 19 September 2013 - 02:05 PM
CyanogenMod 10.1.3 RC2 bug --    Seems that Google Voice Search will not work while docked.  Works fine when undocked, but as soon as it is docked -- cannot open microphone.  :/   Dirty flashed Skrilax CM10.1 Nightly ( 8/08 ) and it works fine both docked and undocked.  Go figure.
  • tomv5314 likes this
#147 tomv5314
tomv5314
  • 243 posts
  • LocationMass.
  • Current Device(s):One Plus 7Pro 8GB Ram - 256 GB Rom - Pixel 2 XL- 128GB - Nexus 6P- 128GB - LG G3- LG-G2 -Razor Maxx HD unlocked- Bionic- Samsung Galaxy Tab S3--SM-T820
Posted 28 September 2013 - 08:29 PM
I have just had that today with final version .Been driving me nuts lol    Went back to my flying jelly  rom. I will try downloading with scrillax final nightly. I need my dock working completely as I spend a lot of time in car
One Plus 7 Pro --  8 GB Ram - 256 GB Rom
#148 ripper2860
ripper2860
  • 137 posts
Posted 28 September 2013 - 09:11 PM
Post up on how the last Skrilax worked for you.  I don't use the dock often, but when I need to use it is for NAV and Voice Search with NAV is critical for me.
#149 tomv5314
tomv5314
  • 243 posts
  • LocationMass.
Posted 29 September 2013 - 01:15 AM
see below
#150 tomv5314
tomv5314
  • 243 posts
  • LocationMass.
Posted 29 September 2013 - 01:18 AM
Just got through setting up and testing and and dock is turning on the mic. Yay...  It is now functioning properly.  I downloaded Scrilax last nightly.  CM 10.1 20130821 nightly xt 926 Scrillax
#151 tomv5314
tomv5314
  • 243 posts
  • LocationMass.
Posted 29 September 2013 - 06:37 PM
I want to thank you for catching this. I have been running the Skrilax last nightly.  Used the dock all day for nav  and all is working  properly .mic is turning on in google ,search, nav and voice commands.
  • ripper2860 likes this
#152 ripper2860
ripper2860
  • 137 posts
Posted 29 September 2013 - 08:23 PM
Flashed Skrilax's last 10.1 Nightly (8/21) over my Skrilax  Nightly 8/08 and all is good.  Worked great with 8/08 and continues to do so with 8/21.  Strange how Official CM10.1.3 RC2 and STABLE don't work in Dock but the older Skrilax nightlies work.  :/
#153 tomv5314
tomv5314
  • 243 posts
  • LocationMass.
Posted 30 September 2013 - 09:46 PM
Something else I just noticed is DSP Mgr is not having any effect . on CM 10.1 stable and the last nightly we are using for dock. If you are playing music say Pandora for example  enable and unable no difference > custom eq all maxes and all pushed to bottom no difference.  Had DSP baked into 4.1.2 rom (flying jelly) and  eq enabled and unenabled was quite a difference . Curious if others have noticed this.
#154 ripper2860
ripper2860
  • 137 posts
Posted 03 October 2013 - 05:27 PM
I've only gotten it to work with Google Play. No luck with anything else. Even then it is touch and go.
