[Buglist] Known issues for 4.2.2/CM10.1/etc ROMs
153 replies to this topic
#101 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
  • LocationSchaumburg, IL
Posted 13 May 2013 - 08:24 PM
Wipe. Dirty flashing causes this. Particularly failing to wipe system.
#102 rockstarr001
rockstarr001
Posted 13 May 2013 - 08:45 PM
Is there a cure for MMS failures too? I edited the logs using ES file explorer and added the lines in the OP but I'm still getting frequent crashes and message delivery failures
#103 Ban-Hammer
Ban-Hammer
  • 95 posts
  • Twitter:@Adam_Swint
  • Current Device(s):Droid RAZR HD, Razr M
Posted 14 May 2013 - 05:43 AM
Use a recent nightly. I've had zero problems with calls and MMS with the nightlies.
#104 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
Posted 14 May 2013 - 08:17 AM
OP has been updated to reflect issues that have been resolved more clearly.
#105 Ban-Hammer
Ban-Hammer
  • 95 posts
Posted 14 May 2013 - 11:46 AM
I clean flash everything. Every time I flash I wipe all 4 (cache, dalvik, system, data) and I wipe cache and dalvik after flashing. I know what I'm doing to flash this stuff.
Latest nightlies have broken WiFi.
#106 unchoney
unchoney
  • 77 posts
  • Twitter:droidfan1958
  • LocationQuad Cities USA
Posted 14 May 2013 - 01:09 PM
I've been running 10.1 all day on WiFi with no problems(5/9 version).
#107 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
Posted 14 May 2013 - 01:57 PM
Same. But 5/13
#108 Ban-Hammer
Ban-Hammer
  • 95 posts
Posted 14 May 2013 - 07:36 PM
Same. But 5/13
Wtf. I wiped all my $#!+ on each nightly and WiFi doesn't work. Double wiped all 4 and on the latest nightly. Im stumped
#109 Trooper
Trooper
  • 53 posts
Posted 15 May 2013 - 06:22 AM
Hi guys,
I have data drops on any rom that I run outside of stock.  Is anyone else experiencing this?  Just curious.  I've been told to try a new sim card. Does this sound feasible?
Thanks.
#110 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
Posted 15 May 2013 - 04:34 PM
Hi guys,
Thanks.
This happens a lot in lower signal strength areas. SIM probably won't fix it tbh unless there's something wrong with the contacts on it
#111 Trooper
Trooper
  • 53 posts
Posted 15 May 2013 - 07:28 PM
I seem to be in the minority then. I'm the only person I know having this issue. Guess it's not very widespread then huh? Sim sounded like a long shot I agree.
Question. When you fire up your phone. Do you get a signal right away or does it take awhile?
Thanks.
#112 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
Posted 15 May 2013 - 07:32 PM
Thanks.
First boot after rom install/update takes about 15-30 sec. Normal boots are usually sub 10
#113 chetta
chetta
  • 7 posts
Posted 21 May 2013 - 07:45 PM
Hi All,
I've seen some discussion on this board about the GPS not locking after ROM installed. Hoping to get some advise.
I have an XT926 running AXI0M. I have tried and tried to get it to lock in on the GPS and have had no luck.
Few situations i've tried....
1. Format internal sd, install ROM/gapps, & restore from Titanium backup (apps and data)
2. Format internal sd. Install ROM/gapps, & restore from Google Play backup
3. Format internal sd. Install ROM/gapps, & not do a restore but install a fresh Maps from Google Play
I'm using AXI0M-4.2.2-21MAY2013-ODEX-xt926 & gapps-jb-20130301-signed.
I've also tried GPS Fix and GPS Status & Toolbox. Neither were able to lock on to my GPS location.
Any thoughts on what to try next?
Thanks for any assistance.
#114 koftheworld
koftheworld
  • 111 posts
  • Twitter:koftheworld
Posted 22 May 2013 - 02:02 AM
Hi All,
You need to install a stock based rom, get a GPS lock, wipe normally, and then fresh install a 4.2.2 rom. Download maps from the market (doesn't have to be maps but that's what I like to do) and get a lock to check GPS.
sent from my xt926 RAZR maxx hd
#115 chetta
chetta
  • 7 posts
Posted 23 May 2013 - 04:21 AM
Thanks! Thoughts where I can get an xt926 stock based rom that installs by zip for TWRP?
#116 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 23 May 2013 - 08:44 AM
The stock ROM only needs to be first.  I've flashed between several ROMs the past few days, all AOSP based, and I lock on prior to flashing. I have been good with GPS on every new ROM I've flashed.  Just make sure you lock on FIRST.  If you've never done it with a stock ROM, then you need to restore one.  If you never backed one up, then that's an issue.  You should always have a stocker backed up, just in case.  Aftermarket ROMs can do some bad things sometimes.
#117 chetta
chetta
  • 7 posts
Posted 23 May 2013 - 02:09 PM
Ughhhh. I didnt back up my stock.... Thoughts?
#118 koftheworld
koftheworld
  • 111 posts
Posted 23 May 2013 - 02:14 PM
not an issue.either download a stock rom or stock based rom and install it.no worries.
#119 chetta
chetta
  • 7 posts
Posted 23 May 2013 - 02:25 PM
I did some searching when I was first advised to get a stock rom and couldnt find one. Is there a thread on here with a link? Will it be a zip installation that I can do in TWRP?
Thanks.
#120 chetta
chetta
  • 7 posts
Posted 23 May 2013 - 05:46 PM
Thanks.
Got it flashed back to recovery and now trying to lock the GPS! Thanks for assistance!
