Seems like one more try at fixing the GPS did the trick, it's working great now.
I tried to make the buildprop edits but ES File Explorer crashed when saving the file and hosed it up. I pulled the one from the AOKP zip, edited it then put it in the system folder but I must have screwed up the permissions because the phone wouldn't boot. :
I ended up wiping everything but data and reinstalling the rom and gapps. I guess I should install root explorer and try again. Does it matter where the new lines are added to the buildprop?
What buildprop changes did you make to correct the GPS issue?
