[ROM][JB] 98.72.22 Deodexed for Safestrap
38 replies to this topic
#21 voodoodaddy
voodoodaddy
  • 5 posts
Posted 16 May 2013 - 11:40 AM
You can take the zip, open it, go under system/apps delete what you don't want, also under vendor/apps, do the same. Then install.
Didnt know that, thanks for the info. Will give it a go.
#22 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
  • LocationDecatur, MI
  • Current Device(s):Bionic
Posted 16 May 2013 - 05:54 PM
How hard would it be to make, or is there any interest in making a stripped, clean, debloated "stock" version of JB? I had problems with the OTA making my phone laggy. Ive rooted and installed blurry and have similar issues, phone is just not very responsive.
Blurry is pretty much debloated. All vendor apps are removed and most bloat from system/app is removed as well. I doubt its the bloat apps that are making your phone laggy. Im not sure what exactly it could be though...
#23 nitephlight
nitephlight
  • 82 posts
Posted 18 May 2013 - 08:09 PM
i have the exact same issue, blurry runs beautifully for a few hours then things are getting laggy... then open chrome and perma-stunned gg.
did you flash any of the blurry zips? try running it vanilla for a bit and see if the same thing happens
#24 slave13
slave13
Posted 19 May 2013 - 10:43 AM
hi i can't use this unless i'm on jelly bean i want to use this as a update at some point
#25 the4cris
the4cris
  • 9 posts
Posted 23 May 2013 - 08:31 PM
HELP..... i did not backup anything and did a factory reset in safestrap 3.11 and now it says if have no OP system and it will not let the phone start up PLEASE HELP ME.....
Chris
#26 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
Posted 23 May 2013 - 08:37 PM
Chris
FXZ back to JB with RSD Lite.
Then after doing this you will need to reroot.
#27 the4cris
the4cris
  • 9 posts
Posted 23 May 2013 - 08:59 PM
can you explain some im new to all this stuff and im freaking out...lol
#28 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
Posted 23 May 2013 - 09:02 PM
Im in chat...
#29 the4cris
the4cris
  • 9 posts
Posted 24 May 2013 - 11:16 AM
when im AP Fastboot Flash Mode (S) 0a.78/ RSD cant find my phone, trying to flash jelly bean, RSD will find my device in BP SBF flash mode (S).....what should i do....
#30 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
Posted 24 May 2013 - 11:43 AM
I guess try using House of Bionic
Also, make sure you have the correct drivers installed. Just in case. I couldnt get mine to work until I installed the drivers that came on the phone itself. I tried downloading all sorts of drivers for Motorola phones...
#31 the4cris
the4cris
  • 9 posts
Posted 24 May 2013 - 02:46 PM
OK i got Fastboot to kinnda work after i got the right drivers but now  it RSD will start but then fails saying "Failed Flashing Process.5/24 oem fb_mode_set-> P... i dont know what to do...i NEED HELP....
#32 ktnemec
ktnemec
  • 28 posts
  • Twitter:@parsnip2
Posted 24 May 2013 - 03:04 PM
I tried this and got a "Status 6" error. Is there some trick to re- zipping it?
#33 B.E.McAllister
B.E.McAllister
    Paint by Number Master
  • 355 posts
  • LocationUT, PA
Posted 24 May 2013 - 03:26 PM
Hmmm, never had to resigned it anytime I did it. Not sure, I only take out small stuff like gmail and chrome. Never had that problem. I've even inserted stuff like there 4.2 keyboard and stock browser. Not sure, sorry. Do you maybe have a bad download to begin with?
#34 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
Posted 24 May 2013 - 05:26 PM
"If you tried the 98.72.22 fxz and received a OEM_fb_mode error use this file
it is the full 98.72.22 with the 2 fb_mode lines removed."
#35 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
Posted 24 May 2013 - 05:32 PM
Isnt a status 6 error related to updater-script? Thats what Ive always seen anyways.
#36 jp1044
jp1044
    DEVELOPER
  • News Writer
  • 1,104 posts
  • Twitter:@jp1044
  • Google+:jp1044@gmail.com
  • LocationColorado
Posted 24 May 2013 - 07:34 PM
I would try your download again. The updater-script should be fine.
#37 the4cris
the4cris
  • 9 posts
Posted 24 May 2013 - 09:21 PM
THANKS, THAT ONE WORKED..... IM BACK UP AND RUNNING
  • MarkusMcNugen likes this
#38 ktnemec
ktnemec
  • 28 posts
  • Twitter:@parsnip2
Posted 28 May 2013 - 05:31 AM
Not really sure what it was, other than I tried to do the same thing under linux (same rom file) and it worked fine.  I guess I will just avoid using windows.  Thanks for the help.
  • B.E.McAllister likes this
#39 jjkoolaid
jjkoolaid
  • 31 posts
  • Current Device(s):bionic
Posted 25 September 2013 - 08:11 PM
For running this in the stock slot, what about booting this up, uninstalling safe strap, reboot and reinstall safe strap to think this is the stock?
