[ROM][JB] 98.72.22 Deodexed for Safestrap
38 replies to this topic
#1 jp1044
jp1044
    DEVELOPER
  • News Writer
  • 1,104 posts
  • Twitter:@jp1044
  • Google+:jp1044@gmail.com
  • LocationColorado
Posted 22 April 2013 - 03:20 PM
The title says it all. This is just a Deodexed build of JB that can be flashed in Safestrap. It is mostly meant to be a base for devs but can be used as a ROM if you want it to. This build isn't debloated, just deodexed and pre-rooted.
Enjoy!
You must be on the jelly bean update for this to boot!
Download:
  • mrlolli, braum and CrimsonKnight13 like this
#2 Bama
Bama
    Needs Beer
  • 582 posts
  • Locationsalem,al
Posted 22 April 2013 - 03:36 PM
first....ah man i thought i had some flying jelly to download haha
#3 Aldroid33
Aldroid33
    Superuser
  • 766 posts
Posted 23 April 2013 - 05:10 AM
Thanks, I guess this is the first step!
Samsung S4, Rooted, Encrypted, Stock JB 4.4.3 GPE and Echo TW v.24 4.4.2
Moto Xoom WiFi-EOS Big Part 4.4.4 w/ TWRP 2.7.1. Thanks BRD & R'nH!
#4 customizeme73rs
customizeme73rs
  • 30 posts
Posted 23 April 2013 - 08:47 AM
gonna wait a while like ics
alot  of roms still tanks
#5 jp1044
jp1044
    DEVELOPER
  • News Writer
  • 1,104 posts
  • Twitter:@jp1044
  • LocationColorado
Posted 23 April 2013 - 09:12 AM
stuck in a bootup screen
running ics is that why
 do i need to be on jelly
if so hwo to keep root
Yes you need to be on jelly bean
#6 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
  • LocationDecatur, MI
  • Current Device(s):Bionic
Posted 23 April 2013 - 04:59 PM
jp1044, you should link DLukes and my mods for this from the development section in the OP.
#7 jp1044
jp1044
    DEVELOPER
  • News Writer
  • 1,104 posts
  • Twitter:@jp1044
  • LocationColorado
Posted 24 April 2013 - 05:44 AM
You mean put links in the OP or put them in this Rom or flyingjelly?
#8 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
Posted 24 April 2013 - 06:23 AM
I meant put links in the OP. You can do whatever you want with them though lol.
#9 jp1044
jp1044
    DEVELOPER
  • News Writer
  • 1,104 posts
  • Twitter:@jp1044
  • LocationColorado
Posted 24 April 2013 - 08:02 AM
Yeah sure I can put the links in the OP. Just didn't know what you meant lol
#10 eanes_87
eanes_87
  • 113 posts
Posted 24 April 2013 - 02:10 PM
quick question. I screwed up and accidentally wiped my stock JB rom. i tried restoring with my backup onto the stock slot in SS and i can hear the bionic bootup sounds but the screen stays black. i restored the same backup to slot 2 and it works perfectly. tried re-applying the backup to the stock slot and still had the same result. i really don't want to fxz and go through the hassle of rooting, so would this rom be sufficient to run in my stock slot?
and just to clarify, i wiped system, cache, etc before attempting to install the stock jb backup. i have no clue why it successfully boots on a regular slot but not the stock.
#11 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
Posted 24 April 2013 - 04:29 PM
Also, I dont know if this would work but I or someone here could upload our nandroid and you could try to restore that... I think that might work.
I would think you could give it a go but I wouldnt get your hopes up. I mean, if you have the nandroid backup you should be able to at least safely try it since you can restore the nandroid if it doesnt work. Even if your nandroid doesnt work, it obviously restores enough files for you to boot another rom in a custom rom-slot.
I may be mistaken but I believe you try restoring someone elses JB OTA nandroid and see if that works. But Im not entirely sure.
#12 eanes_87
eanes_87
  • 113 posts
Posted 24 April 2013 - 05:03 PM
I'm just running this rom in slot one now. It wouldn't install into stock, and my backup doesn't work in stock either. I guess this will do, just wanted to have my "stock" slot working.
#13 Marty
Marty
  • 70 posts
  • LocationSLC
Posted 27 April 2013 - 07:30 PM
Enjoy!
Download:
Does the safestrap slot matter?
#14 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
Posted 27 April 2013 - 07:36 PM
Shouldnt make a difference
  • Marty likes this
#15 Marty
Marty
  • 70 posts
  • LocationSLC
Posted 27 April 2013 - 08:36 PM
I lost my stock rom so was hoping to run it in stock slot, will that work???
#16 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
Posted 27 April 2013 - 08:46 PM
No. Do not try it. Safestrap shouldnt let you flash over it, and bootstrap will kill your root access. Best to just stick with a ROM Slot.
#17 Marty
Marty
  • 70 posts
  • LocationSLC
Posted 27 April 2013 - 08:50 PM
I tried it before I read your reply and it didn't work but I got lucky and still have root.  I did work in slot 2.
Thanks,
Marty
#18 B.E.McAllister
B.E.McAllister
    Paint by Number Master
  • 355 posts
  • LocationUT, PA
Posted 27 April 2013 - 09:07 PM
What if he did a backup of slot two then a restore of it in slot one? Not even sure if that's possible in ss<br />
#19 voodoodaddy
voodoodaddy
  • 5 posts
Posted 16 May 2013 - 11:03 AM
How hard would it be to make, or is there any interest in making a stripped, clean, debloated "stock" version of JB? I had problems with the OTA making my phone laggy. Ive rooted and installed blurry and have similar issues, phone is just not very responsive.
#20 B.E.McAllister
B.E.McAllister
  • 355 posts
  • LocationUT, PA
Posted 16 May 2013 - 11:18 AM
You can take the zip, open it, go under system/apps delete what you don't want, also under vendor/apps, do the same. Then install.
