Fix for all Stock ROMs to be installed with TWRP/CWM
23 replies to this topic
#1 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
  • Twitter:@timpohladthomas
  • Current Device(s):MOTO X
Posted 22 April 2013 - 01:03 PM
Ladies and gentleman, I have found the holy grail for getting ROMs made for safestrap to Install using TWRP/CWM.
To being with I want to Thank:
Mhous33 (for the scripts)
Alright, here goes...
To fix the ROMs you need unzip the ROM zip.
Unzip the Needed Files .zip
Insert the attached files (Updater-Script, Updater-Binary) into the ROM you would like to fix
Files go in /META-INF/com/google/android
Zip the ROM folder
Use AutoSigner to sign the zip (
Flash the ROM like you would any other ROM (Mount everything, wipe everything TWICE, mount everything, flash)
Profit
PM me with any questions...
  • neckchop, jamminjon82, T3T3droid and 7 others like this
#2 T3T3droid
T3T3droid
    D3v3lop3r/Th3m3r/Machin3
  • 1,115 posts
  • Google+:t3t3droid@gmail.com
  • LocationConnecticut
  • Current Device(s):Droid Bionic, Droid Razr M, SGS4
Posted 22 April 2013 - 01:19 PM
Good job man! Thanks! and...first :)
  • timpohladthomas likes this
Sig by Bama
If you like our work please consider
Donating towards
Phones and Site costs :D Thanks!!
#3 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 22 April 2013 - 01:52 PM
If anything needs to be explained better in the OP just let me know and I will edit it.
#4 s.dubs
s.dubs
    Team Rage Developer
  • 83 posts
  • Twitter:@sdubs317
  • Locationcuse
  • Current Device(s):RAZR M
Posted 22 April 2013 - 05:41 PM
Just a thought, correct me if I'm wrong, but if using 7 zip, you should be able to open the archive and replace the necessary files then flash away. Be a little quicker if it works. I'd try but I'm not near a computer...
Help Support & Donate!
#5 Deacon
Deacon
  • 68 posts
  • LocationUSA
Posted 22 April 2013 - 10:41 PM
testing now.
#6 Aixelsyd
Aixelsyd
    Freak on a Leash
  • 640 posts
  • LocationWindy City
Posted 24 April 2013 - 07:43 AM
yes that will work fine doing it that way as i've done it in the past.
I am questioning why this is needed to be done tho. i've had a Dev Edition M since release day and I've been able to flash  ROMs to my M using TWRP even with them being made for SS and have never touched these 2 files.
#7 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 24 April 2013 - 07:50 AM
Lots of other people are having problems...so for them...there is this.
#8 Aixelsyd
Aixelsyd
    Freak on a Leash
  • 640 posts
Posted 24 April 2013 - 10:18 AM
makes sense i guess. However that said I'll bet most folks problem is they Mount /system in TWRP then wipe stuff to then try flashing, BAD plan as you will have problem. Ppl need to Wipe stuff first, then reboot recovery, then Mount System followed by flashing ROM
  • timpohladthomas and jayubbs like this
#9 Zeklandia
Zeklandia
    Developer
  • 75 posts
  • Twitter:@Zeklandia
  • Google+:+Asher Wood
  • LocationThe Internet
Posted 24 April 2013 - 12:46 PM
For all of you Linux users out there:
Paste that into a file, then do
in a terminal window/TTY.
As of right now, Java is returning an error about manifest files.
Asher Wood
Linux, Android, Java, C/C++ Developer.
Google+ | Github
#10 scottocs
scottocs
  • 29 posts
Posted 28 April 2013 - 06:38 PM
I tried this with Energy ROM and it wouldn't install. One time I tried and it said it installed, but when I went to reboot it said there was no OS installed, then another time I tried, it had an error while installing.
Am I doing something wrong?>
#11 AK47sForAll
AK47sForAll
  • 50 posts
Posted 10 May 2013 - 03:03 AM
Where in the ROM folder do we put those files?
#12 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 10 May 2013 - 03:37 AM
In...
#13 AK47sForAll
AK47sForAll
  • 50 posts
Posted 10 May 2013 - 03:43 AM
Ah ok. You might want to add that to the tutorial for the clueless ones like me lol.
#14 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 10 May 2013 - 03:59 AM
OP fixed.
#15 AK47sForAll
AK47sForAll
  • 50 posts
Posted 10 May 2013 - 04:10 AM
Didn't work for me anyway. :/
#16 timpohladthomas
timpohladthomas
    OSE DEVELOPER
  • 1,428 posts
Posted 10 May 2013 - 04:19 AM
Did you sign it with auto signer?
#17 AK47sForAll
AK47sForAll
  • 50 posts
Posted 10 May 2013 - 04:45 AM
Yup. Still nothing. I was trying it with Energy. Going to try Eclipse now...
#18 jco23
jco23
  • 414 posts
Posted 10 May 2013 - 05:27 AM
what else could work is to install the ROM on your stock slot (as described in this thread:
), then make a nandroid via TWRP/CWM.
as for me, I have successfully installed a ROM to my stock slot via SS, unlocked bootloader, installed TWRP, uninstalled SS.  after uninstalling SS, my phone booted up as normal and works well as previously.
however, I believe that the next update of the energy ROM (and any ROM going forward) will be TWRP/CWM flashable, so this could be obsolete soon (if not already).  hope this helps.
ROM: OSE KitKat 4.4.2
#19 eroupe117
eroupe117
  • 25 posts
Posted 11 June 2013 - 03:11 AM
H
#20 eroupe117
eroupe117
  • 25 posts
Posted 11 June 2013 - 03:22 AM
So I should not mount and wipe system before flashing? My steps would be to wipe cache, dalvik cache, factory reset, reboot recovery, mount everything, flash energy zip, reboot system?
