What happened to my rom? It's stuck at the loading screen.
Which one did you flash?
Posted 06 May 2013 - 06:57 AM
Posted 06 May 2013 - 09:15 AM
Posted 06 May 2013 - 09:54 AM
I was about to flash the power menu mod but I see neither a short or long press of recovery goes to safestrap.
Went with the thick circle mod from dluke and the blue notification text, and it it's so sharp! Great work on these.
Yeah, unfortunately rebooting into safestrap cant be done from the power menu. Only if we had unlocked bootloaders and could flash a custom recovery.img would it work...
Posted 06 May 2013 - 10:06 AM
Posted 06 May 2013 - 10:14 AM
Posted 06 May 2013 - 10:15 AM
This one:
Using alternative rom right now while my most stable stock is broken.
Which slot did you flash it on if you dont mind me asking?
Posted 06 May 2013 - 10:52 AM
This one:
Posted 07 May 2013 - 02:36 AM
Yeah, to avoid that scenario, i backed up stock with no mods or debloating and restored it to slot 2. Then deodexed and applied mods. is there still a link for baked toggles?
Posted 07 May 2013 - 04:10 AM
What do you mean? All the links are in the op, and they are all working. I just put a lot of options in place since the mods will replace the battery icons. So you have a few choices.
Posted 09 May 2013 - 01:04 PM
Great stuff! I flashed with no issues after deodexing. Question, is there a file out there to revert it back to stock just in case?
Posted 09 May 2013 - 03:42 PM
Posted 11 May 2013 - 02:28 AM
Thank you Markus. When you have some free time, that would be great. I may not have the Bionic much longer and I'd like to be able to revert it back to stock when I sell it. I am using the stand-alone Extended Power Menu. Thank you.
Posted 11 May 2013 - 05:03 PM
Here you go. This should set you back to 100% stock. Pay no attention to what it says when flashing it, I didnt change the updater script.
Posted 12 May 2013 - 06:16 PM
Thank you very much Markus!
Posted 13 May 2013 - 05:51 AM
Posted 13 May 2013 - 06:23 AM
Could these be flashed over a deodexed ROM such as Flying Jelly or does it need to be stock JB?
Posted 14 May 2013 - 03:22 PM
Posted 14 May 2013 - 03:37 PM
I flashed the extended power menu zip file but didn't get the pull-down-toggles. I wiped the c and dc before I flashed the zip. Did I do something worng or do I need to turn something on?
Did I do something wrong?
Posted 14 May 2013 - 04:31 PM
Extended Power Menu doesnt include toggles. You need to download one of the zips from Extended Power Menu + Toggles. If you downloaded the correct kind, tell which one you downloaded.
Posted 14 May 2013 - 05:16 PM
