[Bionic][Mod] Extended Power Menu & Baked Toggles for Deodexed JB 98.72.22
#21
Posted 23 April 2013 - 05:33 PM
#22
Posted 23 April 2013 - 05:37 PM
80.84KB 66 downloads
Sent From My Flash Machine... I mean Bionic.
#23
Posted 23 April 2013 - 05:38 PM
#24
Text in the pull down is still white. :-D
#25
Posted 23 April 2013 - 05:40 PM
- herrsmoothe likes this
#26
Oh gotcha. I like it actually lol I never even noticed
I like it too. More eye catching.
- jcwilliams likes this
#27
Posted 23 April 2013 - 05:43 PM
- MarkusMcNugen likes this
#28
Posted 23 April 2013 - 05:52 PM
So I can flash one of dlukes over your toggle mod and be good?
I just misread you lol I'll try that. Great work by the way. Looks great.
You would have to flash one of DLukes battery mods, then flash the toggle mod. You will lose the custom battery icons, but keep 1%. If you want a custom battery icon back I will have to modify the toggle mod with whatever battery icons you want.
#29
Posted 23 April 2013 - 06:08 PM
Edit: it worked. Thanks!
#30
Posted 23 April 2013 - 07:59 PM
Confirmed, if you try to flash another battery mod over the toggles & power menu mod, the battery mod will remove /replace them.
Also, trying to install other battery icons with Rom Toolbox Pro will cause a systemui force close which makes you lose your status bar. This can't be fixed with your backup in RTB or Titanium Backup.
#31
Posted 23 April 2013 - 08:30 PM
So the power menu is only power menu with out the baked toggles correct? BTW power toggles in play store is fully editable.. with different color schemes and you can choose different toggles. put it in systems folder and will stay on top all the time.
#32
Posted 23 April 2013 - 08:42 PM
I prefer my toggles baked directly into the ROM UI, and why would you ever need different toggles than these? Also these are fully editable if you decompile SystemUI.
- herrsmoothe and jcwilliams like this
#33
Posted 24 April 2013 - 09:14 AM
#34
Posted 24 April 2013 - 11:17 AM
I am a big fan of DLuke's thin circles battery mod which I had before I flashed the toggles, so I had to make a choice. Is there any way you would be willing to make a zip so I can have the thin circle battery icon back and the toggles?
Yeah, no problem. Thats why i said Id take requests in the OP. Ill add them to the OP as I get the requests. Anyways, Ill get to it later tonight because I have class in an hour. Expect it probably around 11PM or Midnight.
#35
Posted 24 April 2013 - 08:00 PM
OP updated with thin circle battery and I fixed the charging animation for thick circle batteries. I made a stupid mistake that made it weird. Crap... I think I may have used a different stat_sys_battery_charging.xml... I may have to fix this again later...
Edited by MarkusMcNugen, 24 April 2013 - 08:47 PM.
#36
Posted 24 April 2013 - 08:37 PM
OP updated with thin circle battery.
Looks/ works great. Think I'll stick with this one for a bit. :-) Thanks a lot man!
#37
Posted 28 April 2013 - 12:01 PM
Any chance you could do it with the following battery?
"DLuke 1% Battery Mod White Numbers - JB-98.72.22.zip"
Would be much appreciated! Thanks!!
#38
Posted 30 April 2013 - 03:32 AM
OP is updated with your battery request as well as Bar w/Numbers and Binary.
#39
Posted 30 April 2013 - 10:23 AM
Thanks a lot Markus! Much appreciated.
#40
Posted 06 May 2013 - 06:43 AM
What happened to my rom? It's stuck at the loading screen.
