[Bionic][Mod] Extended Power Menu & Baked Toggles for Deodexed JB 98.72.22
84 replies to this topic
#1 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
  • LocationDecatur, MI
  • Current Device(s):Bionic
Posted 21 April 2013 - 08:21 AM
-Mods only work on deodexed JB-
Extended Power Menu Mod for Stock JB 98.72.22
  27.79KB   342 downloads
Menu works as follows:
Power off
Short press = Shutdown
Long press = Reboot into Safe Mode
Reboot
Short press = Reboot
Long press = Hot Reboot
Recovery
Short press = Reboot into Stock Recovery
Long press = Reboot into Fastboot
Download Extended Power Menu:
Extended Power Menu Mod + Baked Toggles for Stock JB 98.72.22
Battery Icons Note: Your battery icons will be replaced when you flash the toggles mod. If you want different battery icons than what's offered request it and I will recompile the toggle mod with your requested battery.
1% Battery Note: This mod does not include 1% battery. If you want 1% then flash a mod from DLukes thread linked below and THEN flash the toggles mod.
  159.91KB   255 downloads
  72.68KB   263 downloads
  161.72KB   262 downloads
-One has a Blue status ticker and one has a White status ticker as pictured above.
-All toggles work. The brightness toggle only turns automatic brightness on and off, when brightness toggle is turned off the screen must be relocked before it changes brightness. (Im going to work on fixing this and/or possibly add multiple brightness settings)
Thick Circle: thickcirclebatteryprevi.png
Blue Ticker -
White Ticker -
Thin Circle: thincirclechargepreview.png
Blue Ticker -
White Ticker -
Bar w/Numbers: barbatterypreview.png
Blue Ticker -
White Ticker -
White Numbers: whitenumberchargeprevie.png
Blue Ticker -
White Ticker -
Binary: binarychargepreview.png
Blue Ticker -
White Ticker -
*Thick Circle now has the correct charging animation*
Credits:
eye__dea for research and help on toggles
Vtwinbmx for the information of resigning both framework and systemui apks
KrYpToNiTe for posting the deodex toggles for Razr JB here:
Edited by MarkusMcNugen, 14 May 2013 - 10:41 PM.
  • herrsmoothe, bionichillbilly, mrlolli and 3 others like this
#2 herrsmoothe
herrsmoothe
  • 33 posts
Posted 21 April 2013 - 09:58 AM
Nice, thanks a lot. I just flashed this, and while I didn't test everything out again, safe mode is now working. As I said on DLuke's thread, if you come up with any more mods, and need a tester. I am more than happy to give my time.
Sent From My Flash Machine... I mean Bionic.
#3 DLuke
DLuke
    Bionic Modder
  • 69 posts
  • LocationNor*Cal
Posted 21 April 2013 - 10:36 AM
well done... i like how you utilized the long press.. was the same idea i had in mind, had i ever gotten the time to start working on it (i hate that i barely have any time for developing anymore.. stupid real world)
  • herrsmoothe and B.E.McAllister like this
Posted Image Posted Image
**So ive always held out on adding a donate link because this is just something i do for enjoyment.. but i have received a few requests recently to add one.. so if you enjoy my work and would like to buy me a beer or put some gas in my car, that would be very much appreciated.. but please continue to freely enjoy my mods without any feeling of obligation what-so-ever.. the last thing i want by adding this is for people to stop using my mods because they fell obligated.. Thanks
#4 johnlgalt
johnlgalt
    Antidisestablishmentarianist
  • 7,296 posts
  • Location3rd Rock
Posted 21 April 2013 - 06:07 PM
Stickified
#5 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
Posted 21 April 2013 - 06:13 PM
Yeah, I forgot to change one number in the smali and it caused safe mode to not work at first. Ill keep the testing offer in mind. Its nowhere near working or prepared yet, but Im working on the baked in notification toggles. So far I have Wifi, Bluetooth, and Sound toggles working. Brightness is almost working. GPS and Data are completely broke. In a day or two I might get a toggle or two more working. We'll see.
Yeah, the real world often gets in the way. Luckily I do have a lot of free time when Im not in school so I can work on these things for hours at a time. Well, at least when the girlfriend isnt here bothering me lol.
  • johnlgalt and herrsmoothe like this
#6 jcwilliams
jcwilliams
  • 97 posts
  • Locationohio
Posted 22 April 2013 - 07:00 PM
I'm problems here lol
I'm trying to install a battery mod and this mod for the menu. I'm getting stuck at the boot animation. I've narrowed it down to this mod. Both mods should get along right?
#7 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
Posted 22 April 2013 - 07:35 PM
Yes they should. The power menu mod changes framework-res.apk and android.policy.jar. While the 1% battery changes SystemUI.apk and services.jar. There is absolutely no reason why they shouldnt work with eachother. Ill double check the power menu mod and see if there is any reason it wouldnt work.
What order did you install the mods?
#8 Tattooz305
Tattooz305
  • 120 posts
Posted 23 April 2013 - 02:27 AM
Thank you, thank you. Been looking for this
Sent from my JB Bionic
#9 jcwilliams
jcwilliams
  • 97 posts
  • Locationohio
Posted 23 April 2013 - 02:37 AM
At first I installed battery mod first then power mod. Reboot and got stuck. Then I installed just the battery mod and it booted but still had 10% increments. Then flashed power mod again and got stuck again.
#10 herrsmoothe
herrsmoothe
  • 33 posts
Posted 23 April 2013 - 05:26 AM
Did you already flash the deodex.zip?
#11 jcwilliams
jcwilliams
  • 97 posts
  • Locationohio
Posted 23 April 2013 - 05:57 AM
Yes I flashed that first. I need to right? I'll try again here at work and I'll report back
#12 herrsmoothe
herrsmoothe
  • 33 posts
Posted 23 April 2013 - 12:34 PM
Flash the deodex.zip... Wipe cache/dalvik... Reboot... Flash the battery... Reboot... Flash the extended power menu... Reboot... Sometimes if you try doing to much at one time nothing seems to take.
#13 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
Posted 23 April 2013 - 03:59 PM
OP updated for baked in toggles
  • herrsmoothe and jcwilliams like this
#14 jcwilliams
jcwilliams
  • 97 posts
  • Locationohio
Posted 23 April 2013 - 04:04 PM
Ok I'm going to try doing it right now...I'll report back.
#15 jcwilliams
jcwilliams
  • 97 posts
  • Locationohio
Posted 23 April 2013 - 04:05 PM
Now I'm going to have to add these in there lol
#16 jcwilliams
jcwilliams
  • 97 posts
  • Locationohio
Posted 23 April 2013 - 05:08 PM
Got it done. Does the toggle/battery/power mod include 1% increments?
Edit: they have 10% increments. Anyway to make them 1%?
#17 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
Posted 23 April 2013 - 05:22 PM
I didnt include the 1% in this since its already included in DLukes battery mods. I can make one with 1% included and PM you with the link. Or you can flash one of DLukes battery mods and then flash these mods on top it.
I only mentioned the battery because the toggles mod works with the same apk as the battery mods. So if someone did have a custom battery already flashed it would be changed.
  • herrsmoothe likes this
#18 herrsmoothe
herrsmoothe
  • 33 posts
Posted 23 April 2013 - 05:26 PM
Confirmed working, all toggles function as specified. Did notice that when text pops up in the notification bar, it is blue, I believe that stock was white. Nothing else appears different so far. Nice job! Thanks a lot!
#19 MarkusMcNugen
MarkusMcNugen
    Blurred Effectz
  • 277 posts
Posted 23 April 2013 - 05:30 PM
Well thats a lesson learned for me. Dont theme and mod at the same time lol. Ill fix it and edit the OP in a few.
#20 jcwilliams
jcwilliams
  • 97 posts
  • Locationohio
Posted 23 April 2013 - 05:32 PM
So I can flash one of dlukes over your toggle mod and be good?
I just misread you lol I'll try that. Great work by the way. Looks great.
