See previous reply. Edit the xml file and remove those oem lines and flash again. Done.
![Photo](http://www.gravatar.com/avatar/6d819063875b48c1fd7355b0e9a8978e?s=100&d=http%3A%2F%2Fwww.droidrzr.com%2Fpublic%2Fstyle_images%2Fdark_matter%2Fprofile%2Fdefault_large.png)
Brick after JB reboot
#21
Posted 24 April 2013 - 04:07 PM
#22
Posted 24 April 2013 - 04:12 PM
Got thru to step 10... "10/22 Flash lbl "lbl"-> phone returned fail
#23
Posted 24 April 2013 - 04:15 PM
My first time to edit an xml file, but the edit must be clean, as the total of steps reduced by the 2 I deleted.
#24
Posted 24 April 2013 - 04:20 PM
There is an lbl file in the folder...
#25
Posted 24 April 2013 - 04:21 PM
My advice at this point is to simply use my House of Bionic. Download the 10.1 installer, the rsd installer (I know you have rsd installed...this is a custom version specifically for the HoB), and you already have the 98.72.22 FXZ zip file. Read through the HoB OP to learn how to install it. Then once it's installed and set up, put your phone in AP Fastboot mode and use the FXZ FULL option in the HoB.
#26
Posted 24 April 2013 - 04:23 PM
will report back. Thanks
#27
Posted 24 April 2013 - 04:39 PM
So I can't do all the steps, can't set USB to charge only...
#28
Posted 24 April 2013 - 04:42 PM
also, can't remove safestrap...
#29
Posted 24 April 2013 - 05:02 PM
6 minutes now I'm hung on;
Flashing HouseOfBionic_RADIO.xml
1 file(s) copied.
#30
Posted 24 April 2013 - 05:08 PM
I don't know what to tell you. I used it to flash my Bionic the other day. Had zero issues. You can try changing flash mode to fastboot and see if that works. Otherwise, I have no more ideas.
#31
Posted 24 April 2013 - 06:26 PM
Success! took more time to edit the xml file, then re-zip the package. I also went into safestrap and did wholesale deletion of files, so that safestrap was unavialable. Probably also some system files? I just used your RSD and flashed, without errors. Onto the root process on linux... Thanks for your help, It made a difference.
- SamuriHL likes this
#32
Posted 25 April 2013 - 09:10 PM
#33
Posted 26 April 2013 - 03:48 AM
Sent from my Xoom using Tapatalk HD
#34
Posted 26 April 2013 - 05:56 AM
I wasn't able to get through the flash process. Once I did, there were no errors. If you are getting a successful flash, I doubt that the edited file I did will help you. PM sent. Another thought... I had to do the full and erase all data (+internal SD). Are you trying to preserve your data?
#35
Posted 26 April 2013 - 03:21 PM
#36
Posted 26 April 2013 - 03:59 PM
Then I need to see the SWDL.txt log file from RSD. Otherwise we'll just keep wasting time guessing as to what could be wrong and I don't have time for guessing games.
#37
Posted 26 April 2013 - 08:26 PM
I found the SWDL file. It only exists in the HoB RSD folder... I can see the earlier fails, and then success.
#38
Posted 27 April 2013 - 04:22 AM
#39
Posted 27 April 2013 - 06:49 AM
#40
Posted 27 April 2013 - 06:52 AM
But you didn't do what I asked you to do in my last post...
