487 replies to this topic
#161 timeto1953
timeto1953
  • 28 posts
Posted 05 April 2012 - 06:32 AM
I have tried twice know and it just keeps re-loading .173 I downloaded the file re- named the file and copied to my cache folder then used rom manager to extract zip but it doesn't load ics the fiel size is 470,000 kb so I know it's the correct file
did you copy both files to cache and root
#162 timeto1953
timeto1953
  • 28 posts
Posted 05 April 2012 - 06:36 AM
I had the same problem but I copied and renamed both files put two files in cache and two in root folder went back to cache and tapped and used rom manger and it installed with no problems
#163 wulf
wulf
    Themer
  • 929 posts
  • Twitter:@Wulf_X1
  • LocationMidwest
Posted 05 April 2012 - 06:38 AM
I'm a newbie and I think you will find both root and cache on your SD internal and not the SD-ext try looking at your SD in ES file explorer and you will find it there both root and cache in ES if I remember it will be the second one from the top
This is when you first open es
  71.43KB   11 downloads
This is when you press back button(if proper settings are checked)
  65.25KB   12 downloads
And this is when you open cache folder.
  37.49KB   10 downloads
Hope this helps :)
#164 etrorteepe
etrorteepe
    Not a Belieber
  • 221 posts
  • Current Device(s):Nexus 5
Posted 05 April 2012 - 06:41 AM
I'm puzzled about being able to fastboot back to .173 after flashing this. My understanding so far has been that the .fxz fastboot file does not contain a kernel. And I have to assume that the ICS leak contains an updated kernel. So when you fastboot back to .173 is the ICS leak kernel being left behind on the phone?
#165 chefed24
chefed24
  • 64 posts
  • Twitter:@EdSadler
  • LocationAustin Texas
Posted 05 April 2012 - 06:51 AM
well I wasn't placing the files in both root and cache so trying this after I let my phone charge. Come on Ice cream ( just like cheech from NICE DREAMS)
#166 rexboe
rexboe
  • 30 posts
Posted 05 April 2012 - 06:58 AM
I don't know the answer to this but I have been on ICS and fastbooted back it seems to work fine. What is your kernal and I can check mine to see if it is the right one but am pretty sure it is.
#167 chefed24
chefed24
  • 64 posts
  • Twitter:@EdSadler
Posted 05 April 2012 - 07:17 AM
tried with files in both root and cache and still nothing, damn the luck
#168 iDroidGuy
iDroidGuy
    :D Taco!
  • 650 posts
  • Twitter:iDroidGuy
  • Google+:Stephen Wilmot-Doxey
  • LocationHopewell, VA
Posted 05 April 2012 - 07:21 AM
I renamed the .zip and the .crc file to Blur_Version.6.12.173.XT912.Verizon.en.US.zip and Blur_Version.6.12.173.XT912.Verizon.en.US.crc
Why do you have to rename the files?
If you'd like to buy me a Mountain Dew just PM me for my PayPal info. Thanks :)
#169 bigben
bigben
  • 34 posts
Posted 05 April 2012 - 07:36 AM
Not sure about the download. The files are very small - would have expected them to be much larger. Anyone got a size on the files?
thanks
#170 chefed24
chefed24
  • 64 posts
  • Twitter:@EdSadler
Posted 05 April 2012 - 07:39 AM
right around 470,000 kb for the zip and 19 kb for crc
#171 etrorteepe
etrorteepe
    Not a Belieber
  • 221 posts
Posted 05 April 2012 - 07:42 AM
Baseband version: CDMA_N_04.06.00R LTEDC_U_.07.1F.00
Kernel Version: 2.6.35.7-g6133522 mqr374@nj05lnxdroid05 #2
build number: 6.5.1-167_DHD-14_M2-5
#172 bigben
bigben
  • 34 posts
Posted 05 April 2012 - 08:00 AM
Thanks for the quick response.
That is the size I expected. When I try to download, all files are 19KB. Which file from the original post is the 470M file? I used Opera to download as a torrent and then I get the error that the file is not available.
Believe or not I am not a noobie (well maybe a little on the Torrent side) - just need to have someone point in correct general direction.
Thanks again.
#173 rexboe
rexboe
  • 30 posts
Posted 05 April 2012 - 08:13 AM
Yep that is exactly what I have so I guess fastbooting restores it back correctly.
#174 cardidark09
cardidark09
  • 68 posts
  • Twitter:cardi4life
Posted 05 April 2012 - 08:20 AM
Thanks again.
. After u download the torrent files get a torrent download program like u torrent to download the files
#175 Vicious
Vicious
    Baddassocity in a bottle
  • 67 posts
  • Current Device(s):LG G2 VS980
Posted 05 April 2012 - 08:22 AM
Thanks again.
You have to open that file with a torrent program like Bittorrent or utorrent to download the the files.
#176 Vicious
Vicious
  • 67 posts
Posted 05 April 2012 - 08:27 AM
I was trying everything possible yesterday to get this to work. It was just one of the steps I took. Arcanexvi said the filename shouldn't have to be changed.
#177 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
  • LocationSchaumburg, IL
Posted 05 April 2012 - 08:29 AM
The RAZR doesn't use traditional FXZ files. They include kernel information allowing us to roll back completely.
  • PillClinton likes this
#178 smiznith
smiznith
  • 5 posts
Posted 05 April 2012 - 08:30 AM
Running this ics build tahnks a bunch Big V... looks like the camera doesnt work...
#179 bigben
bigben
  • 34 posts
Posted 05 April 2012 - 08:36 AM
Thanks again to all for the help. The advise on torrent downloading was spot on.
#180 wulf
wulf
    Themer
  • 929 posts
  • Twitter:@Wulf_X1
  • LocationMidwest
Posted 05 April 2012 - 08:40 AM
Whats not working?
Both camera and ffc appear to work fine for me.
