487 replies to this topic
#101 wulf
wulf
    Themer
  • 929 posts
  • Twitter:@Wulf_X1
  • LocationMidwest
Posted 04 April 2012 - 08:34 PM
It isnt working for me. The installation fails every time a little less than half way through... any solutions?
Could be a bad file, maybe redownload it? Also is it named correctly?
#102 custompro98
custompro98
  • 29 posts
  • Twitter:custompro98
should rsd lite have wiped my phone entirely? i kept all my apps and whantot, gained all the bloat, and was on .744. is this normal to still keep your apps after rsdlite?
#103 jonbink16
jonbink16
  • 28 posts
Posted 04 April 2012 - 08:36 PM
should i have renamed it at all from the torrent I downloaded it from? and im trying to download it from a different place now to see if it helps at all. Thanks!
#104 wulf
wulf
    Themer
  • 929 posts
  • Twitter:@Wulf_X1
  • LocationMidwest
after fastboot its a good ideal to do a factory reset.
#105 wulf
wulf
    Themer
  • 929 posts
  • Twitter:@Wulf_X1
  • LocationMidwest
Posted 04 April 2012 - 08:39 PM
Should be named
Blur_Version.6.12.173.XT912.Verizon.en.US.crc
Blur_Version.6.12.173.XT912.Verizon.en.US.zip
#106 jonbink16
jonbink16
  • 28 posts
Posted 04 April 2012 - 08:42 PM
Should be named
yup thats what they were named before. I'm trying a new .zip file now, so I hope it works!
#107 jonstal
jonstal
  • Twitter:@jonstal
Posted 04 April 2012 - 08:43 PM
Let us know how it goes. Thinking it won't work cuz of root
#108 wulf
wulf
    Themer
  • 929 posts
  • Twitter:@Wulf_X1
  • LocationMidwest
Posted 04 April 2012 - 08:46 PM
Only difference for me is I already downloaded the files directly, no torrent, over the weekend and saved them. Hope you get it going.
#109 PsyberEMT
PsyberEMT
  • 24 posts
  • LocationCharleston, SC
Got it installed with no problems. Lost my root for some reason (did have voodoo) but it feels like a new phone. Very responsive, all of my existing apps and data are still in place. Am interested to test battery life and connectivity. Ran quadrant and got scores equivalent to what everyone else was getting...yeah...those scores kicked the GNEX's butt :-D
"No trees were killed to send this message, but a large number of electrons were terribly inconvenienced" -- Dr. Neil deGrasse Tyson
#110 tucstwo
  • Google+:tucstwo@gmail.com
Posted 04 April 2012 - 08:47 PM
Update=successful thank you Vicious and all folks involved!
#111 wulf
wulf
    Themer
  • 929 posts
  • Twitter:@Wulf_X1
  • LocationMidwest
Posted 04 April 2012 - 08:49 PM
Ppl were able to do it with root (self included), no other way to get around it.
#112 jonbink16
jonbink16
  • 28 posts
Posted 04 April 2012 - 08:52 PM
The new .zip isnt working either... the files are supposed to go directly into the /cache right?
#113 ddemlong
ddemlong
  • 137 posts
  • LocationPhoenix, AZ
Posted 04 April 2012 - 08:53 PM
weird, when I hit open with it doesnt give me an option for reboot recovry via rom manager any idea? Doesnt even show Rom manager in the list of apps to select
Droid RAZR Rooted
#114 MartyChubbs
MartyChubbs
  • 211 posts
  • LocationThe Ghetto, Minnesota
Posted 04 April 2012 - 09:08 PM
Anyone find a problem with the torrent lmk, I downloaded it when it leaked, created the torrent and been seeding ever since... Not sure when it had to be renamed, cause I never touched it...
I bricked my phone :( I only when back to .173 and that looks like the problem. going back to .744
All the available here:
I (aka Mr. Chubbs aka Marty "The Wad" Chubbs aka Knot Mehreelname ) accept no liability for the content of this post. I basically made it all up as I was typing...
#115 TwoBuells
TwoBuells
  • 153 posts
Posted 04 April 2012 - 09:26 PM
I was running Safestrap with clean 173 and Axiom ICS on the Safe side
I went to my non safe side, uninstalled safestrap, used the stock recovery and wiped data and cache.
Did the install and half way though the Android is Upgrading screen my phone stopped and booted into .173
what did I do wrong?
Better to be a Racer for a moment, Than a Spectator for a lifetime.
#116 orcsbane13
orcsbane13
  • 65 posts
Posted 04 April 2012 - 09:31 PM
Did you put the preinstall folder back to stock?
#117 TwoBuells
TwoBuells
  • 153 posts
Posted 04 April 2012 - 09:41 PM
how do you do that?
I using the windows utility to rsd back to 173, then I'll try again
#118 nix80908
nix80908
  • 149 posts
  • Twitter:nix80908
  • LocationDenver, CO - USA
Posted 04 April 2012 - 09:49 PM
Woo! Got it to work! Thanks dude.. seriously! It's flashing now.
#119 orcsbane13
orcsbane13
  • 65 posts
Posted 04 April 2012 - 09:50 PM
how do you do that?
That'll restore it. I keep a backup of the preinstall folder on my sdcard just in case I need to remove safestrap for whatever reason.
Sent from my DROID RAZR using Tapatalk 2 Beta-5
#120 ddemlong
ddemlong
  • 137 posts
Posted 04 April 2012 - 10:02 PM
Hey got this to load on ICS, trying the restore via Terminal. I seem to be getting the error that its read only like alot of others. Done it twice and same thing. Did I miss something?
Droid RAZR Rooted
