#41
Posted 04 April 2012 - 04:52 PM
#42
Posted 04 April 2012 - 04:54 PM
Just make sure you protect root, do not temp-unroot and follow instructions. After install i was able to go back to voodo and restore root.Yeah. I did that but don't I need to protect root? If I do that won't it erase root?
#43
#44
Posted 04 April 2012 - 04:57 PM
#45
Posted 04 April 2012 - 05:01 PM
#46
#47
Posted 04 April 2012 - 05:02 PM
The torrent file in the dropbox link does not appear to be correct. I was able to download but it is only 19 KB in size which does not seem correct. Any one else having any luck with this?
There is 3 files in there. You probably were looking at the crc file or readme.
#48
Posted 04 April 2012 - 05:03 PM
You can still have root if you protect, it just makes a backup. What you dont want is temp-unrootHow do you flash in rom manager when your root is protected is what I want to know?
#49
Posted 04 April 2012 - 05:04 PM
You have to open the torrent file with you "favorite" torrent downloading program to start the download of the file(s).
#50
lol ok sorry I'm dumb.You can still have root of you protect, it just makes a backup. What you dont want is temp-unroot
#51
Posted 04 April 2012 - 05:09 PM
- rickyheferle likes this
#52
Posted 04 April 2012 - 05:10 PM
#53
Posted 04 April 2012 - 05:16 PM
Much appreciated
- W0017roid likes this
#54
Posted 04 April 2012 - 05:17 PM
- flukeshot likes this
#55
Posted 04 April 2012 - 05:18 PM
#56
Posted 04 April 2012 - 05:21 PM
Safe to assume I could RSD back to stock whenever?
#57
Posted 04 April 2012 - 05:25 PM
This did work- thank you. The torrent d/l in 10 min or so but I am on 20 mb comcast.
I'm curious myself. I've been holding off on updating to the leak until this was confirmed.
#58
Sent from my Droid RAZR (Stock Rooted 4.0.3 ICS) using Tapatalk 2 beta 5
#59
Posted 04 April 2012 - 05:26 PM
Definitely a question to ask BEFORE applying any leaked update ... but yes, I have heard that you can fastboot back to stock.
[ sent from _base2 ]
#60
Posted 04 April 2012 - 05:27 PM
Breaking my silence to thank Vicious.
Much appreciated
Glad you broke your silence lol
Bing (1)
