487 replies to this topic
#481 Kimo91
Kimo91
  • 148 posts
  • Google+:elton.k.sales@gmail.com
  • LocationGoose Creek, SC
Posted 22 April 2012 - 10:30 PM
you need both files copied and check out op screen shots if you not familiar with es file explorer
Damn didnt realize it was going to be as easy as it was...but somehow i lost root...how do i regain root again?
Sent from my DROID RAZR using Xparent Red Tapatalk 2
#482 Guest_BDH_*
Guest_BDH_*
Posted 22 April 2012 - 10:54 PM
#483 Kimo91
Kimo91
  • 148 posts
Posted 23 April 2012 - 08:23 AM
Well i figured out how i screwed up: the only step i screwed up on was forgetting to go to the market and download the latest version of superuser. RSD this morning back to .173 and retraced my steps and made sure every rooted app I downloaded was updated before moving forward. I retained root the 2nd time around and loving ICS now :D
#484 Guest_BDH_*
Guest_BDH_*
Posted 23 April 2012 - 09:03 AM
Cool! Glad you got it working!
  • jimyv likes this
#485 jimyv
jimyv
  • 248 posts
Posted 23 April 2012 - 12:50 PM
I had to flash back rsd and ota up for warranty ...soooo forgot what stock 173 does to this phone;( been 10 hours operation time..this morn..flashed last night and pluged in. Phone completely dead at1:30 with med.to light use..;(. Recharged having beer. Already down to 75percent and fadeing fast...I FN HATE STOCK BLUR ON MY RZR..!!USELESS!!!
Sharing da buzz on my crackflashed rzr jimyv
#486 kernelhappy
kernelhappy
  • 90 posts
Posted 09 June 2012 - 08:57 AM
ok I need HELP!
I've tried this over a dozen times, fastbooted back to .181 3-4 times. I do not install any boot strap/safe strap. I've used the ics 0.3 tool, I've manually copied the files to the /cache directory. Nothing is working. I tried installing the zip files from the card, bricked the phone, fastbooted back. While it was bricked I noticed something in stock recovery a install from cache option. After I fastbooted back I tried looking for it again, it's just not there. no matter what I do I cannot get it to kick off the install. I tried renaming the CWM directory out of the way, I've tried setting it with Rom manager and thne hard powering down in case something was clearing the files from the cache before rebooting. I've tried manually putting them there without rom manager and hard powering down. I've tried everything.
how do I get .79 to install!?!?!?
thanks
#487 theonlycosmic
theonlycosmic
  • 470 posts
  • LocationCalifornia
Posted 09 June 2012 - 02:29 PM
ok I need HELP!
thanks
Lol don't use the ics installer just follow this tutorial. Not hard. Fastboot back to. 181 first though
#488 GlassEyedPete
GlassEyedPete
  • 18 posts
Posted 21 June 2012 - 07:09 PM
Well, I'm pretty screwed right now. I was going from gingerbread's motorola recovery and trying to install this. Apparently, there is a better motorola recovery to use from 6.16.206. The problem now is that my phone's battery is too low to program fastboot and it won't boot normally. I'm not sure I can even charge it. I guess we'll see, but I may have a very high tech paper weight.
    Bing (1)
