487 replies to this topic
#461 jimyv
jimyv
  • 248 posts
Posted 22 April 2012 - 05:02 PM
Yeah I just finished moving both files from my computer to my phone
Are they already named according to op?
Sent from my rooted and Sith powered Moto DROID RAZR
Sharing da buzz on my crackflashed rzr jimyv
#462 jimyv
jimyv
  • 248 posts
Posted 22 April 2012 - 05:08 PM
hmm..just checked my phone and the screen wont come on at all and i'm on the leak it been like this for about an hour now..how would i go about gettin this to work?do i have to go back to stock and do this all over again?
kinda sounds like it missed a step need to read forums on charging in apfastboot or similar keep trying to get to ap fastboot and use utilities hurry..
#463 s.cooper
s.cooper
  • 36 posts
  • Google+:unionshane@gmail.com
  • Locationsioux city ia
Posted 22 April 2012 - 05:16 PM
I need to know if all links and steps are still all good to do the ics leak? I understand most of the steps except ur told to be completely stock...my questions is when rooting with matts utility 1.51 what root method do i use?????? ROOKIE CRACK FLASHER DOWN....probally over thinking it but plzzzzzzzzzzz help
#464 Kimo91
Kimo91
  • 148 posts
  • Google+:elton.k.sales@gmail.com
  • LocationGoose Creek, SC
@jimmy yes the file names were already changed to whatever was posted in the op
#465 jimyv
jimyv
  • 248 posts
Posted 22 April 2012 - 05:23 PM
the one that says for gb only once u get to a all natural 173 have to all stock..never had boot or safe strap installed.if uve been flashing u have.use rsd?and ota up to 173?
#466 jimyv
jimyv
  • 248 posts
Posted 22 April 2012 - 05:24 PM
zip is like 458mb?
#467 Kimo91
Kimo91
  • 148 posts
Posted 22 April 2012 - 05:25 PM
zip is like 458mb?
Yep yep 458/459mb something like that
#468 jimyv
jimyv
  • 248 posts
Posted 22 April 2012 - 05:30 PM
you need both files copied and check out op screen shots if you not familiar with es file explorer
#469 Kimo91
Kimo91
  • 148 posts
Posted 22 April 2012 - 05:32 PM
Yep yep sure will after my phone charges all the way and go back to .171 using matts utility then reroot and download those apps. Thanks for your help so far.
#470 wyld
wyld
    Some Kind Of Monster
  • 845 posts
  • Google+:rramos729@gmail.com
  • LocationPortage Indiana
Posted 22 April 2012 - 05:34 PM
To .173 ? Lol
Rooted Droid Razr ICS Leak
#471 Kimo91
Kimo91
  • 148 posts
Posted 22 April 2012 - 05:45 PM
To .173 ? Lol
LOL something like that..I'm a tester and currently on .181
  • jimyv likes this
#472 jimyv
jimyv
  • 248 posts
Posted 22 April 2012 - 05:46 PM
To .173 ? Lol
yea but i. Used Rsd it seems to compile files better if uve already tried leak.. you find out for some reasons the utilities dont work as well if youve already tried the leak..1.51 does not include the radio ? But does redo file damage done by boot o safe strap
#473 Kimo91
Kimo91
  • 148 posts
Posted 22 April 2012 - 05:49 PM
I have rsd on my computer too just in case LOL
#474 s.cooper
s.cooper
  • 36 posts
Posted 22 April 2012 - 05:52 PM
Yeah i used safe strap on my razr....now i have a brand new maxx....2 concerns. 1 instructions dont really tell u when to do the recovery and make a back up. 2. The crc file download when i click it it just comes up with 10 numbers?????is that right??????
#475 jimyv
jimyv
  • 248 posts
rsd 5.6 and either of xml files available
#476 jimyv
jimyv
  • 248 posts
Posted 22 April 2012 - 05:58 PM
Yeah i used safe strap on my razr....now i have a brand new maxx....2 concerns. 1 instructions dont really tell u when to do the recovery and make a back up. 2. The crc file download when i click it it just comes up with 10 numbers?????is that right??????crc is a file package needed along with zip
not gonna be a back up no boot strap or safe strap...ull take leap fresh with only exactly apps required in op added. Some of your apps won't even be compatible with 4.0.3..u could use tb later after install to find you app backups on sd card
#477 Guest_droidpcguru_*
Guest_droidpcguru_*
Posted 22 April 2012 - 06:10 PM
My Razr does this every once in a while. I just figured it was a bug with the leak itself so I do the pwr+voldown for 10 sec reset and all is well until the next time it happens.
#478 s.cooper
s.cooper
  • 36 posts
Posted 22 April 2012 - 06:11 PM
Ok that? Is answered.......how bout when doing the crc download when i click to download it i just get 10 numbers????? Have everything ready except for this download
#479 jimyv
jimyv
  • 248 posts
Posted 22 April 2012 - 06:19 PM
your just getting the torrent? Need a torrent downloader to get files you need
#480 wyld
wyld
  • 845 posts
Posted 22 April 2012 - 06:28 PM
Right click and save as
  • jimyv likes this
