#401
Posted 14 April 2012 - 02:17 AM
#402
Posted 14 April 2012 - 02:21 AM
#403
Posted 14 April 2012 - 04:34 AM
#404
Posted 14 April 2012 - 04:38 AM
I followed the instructions in the OP to the letter. I even RSDed again and re-started from scratch, same result. If your going to tell me it's a bad download, can you please give me the MD5s because I downloaded the files 4 times and keep getting the same result...
#405
Posted 14 April 2012 - 06:05 AM
So you weren't on .173 as the OP stated.I'm not sure what I'm doing wrong but I can't get this installed for some reason... Every time it starts to install in stock recovery, the install icon changes to the triangle with the ! and then my phone reboots and i'm still on Ginger...
#406
It looks like the problem was that I was trying to install the leak from .744. I took the OTA to .173, re-rooted, re-updated binaries, re-protected root and the install worked after that.
#407
Posted 14 April 2012 - 06:26 AM
Yes I am on the ICS leak with the webtop 3.0 beta.
#408
Posted 14 April 2012 - 08:06 AM
Sent from my DROID RAZR MAXX
#409
Posted 14 April 2012 - 08:29 AM
Been lurking and reading all posts since i got my razr last friday. Just thought i would post to say thanks to all here for this update, Im not a noobie to flashing and rooting and wanted to say thanks for all the tools here and on other topics. Im loving ICS, and i havent had the same problems some people have had except a few apps not working properly (ie. temple run and so on). Keep up the great work guys and i will be donating to the devs as soon as i get a little extra cash.
HunterH116, Have you tried the terminal emulator app to regain root, I know this fixed my root access, im not sure what page of this thread it is on or it may be another but it has worked for me and countless others.
again thanks all and keep up the good work! you all rock :-)
#410
Posted 14 April 2012 - 11:39 AM
I was in the same boat....what i did to finally get it was the following
First....i RSDd back to. 173
Then..... formatted the internal sd to start from scratch
Then......rooted with motofail
Then......signed into account and installed ES explorer, Rom Manager and OTA Root protector
Then......protected root within Voodoo OTA
Then...... opened ES explorer and went into settings to mount as RW and allow to get to root of system
Then......copied files into the cache folder make sure they are named correctly..
Then....updated binary even if it said it was up to date
Then.....went into the cache folder and clicked on the update file and chose rom manager to install
Then....let it do its thing.....
#411
Posted 14 April 2012 - 11:46 AM
#412
Posted 14 April 2012 - 12:51 PM
I can assure everyone this method works. Lost root and cannot regain it ,however, but still loving me some ICS! Thanks guys.
Use the methods linked in my thread and you'll retain root.
#413
Anyone using webtop? I picked up the HD dock so I can use my flatsceen TV & webtop app. Most everything works fine, but I was expecting the Firefox browser to be there & some of the other functions like the dual pane screen don't seem to be present. Do I need it paired to a keyboard for these to be enabled?
It's still beta but I love that it's ICS instead of a linux environment
#414
Posted 14 April 2012 - 01:10 PM
Correct. I was reading both threads. The other thread says .744 or .173. That's what tripped me up
#415
Posted 14 April 2012 - 01:22 PM
#416
Posted 14 April 2012 - 02:44 PM
The other thread clearly states "but are on an otherwise stock COMPLETELY UNMODIFIED installation of 173."
The reference to 744 is in regards to which restore files I personally use to start over.
#417
Posted 14 April 2012 - 03:44 PM
#418
Posted 14 April 2012 - 04:06 PM
So we are told to not reboot so it won't screw up the battery stats. What if we stuck at 100% for almost 5 hours? What to do lmao.
Reboot it so it starts reporting a lower value or just let it die if you want. Once it starts reporting lower than 100% just charge it to full and it should work fine. It won't get stuck @ 100%. I honestly have never experienced this issue so I'm tempted to believe it's related to restoring data from GB since I've never done so but I have no way of proving that.
#419
Posted 14 April 2012 - 04:12 PM
#420
Posted 14 April 2012 - 04:15 PM
I've had this since the leak and never restored GB data. Its funny.
Edit: I think Im gonna take advantage of this screen shot show it to my iphone lovers and tell them in your face.......lmao
