487 replies to this topic
#381 geka
geka
  • 69 posts
  • Google+:gene.volchenko
Posted 13 April 2012 - 12:03 PM
I set mine up in other. After typing in my.email@mycompany.com and entering my password, I hit next. That took me to another screen that prompted me to enter my server settings.
Unfortunately it just does not sync. As much as I want to try to use ICS it does not cooperate. Does it take long to sync tyhe first time? I waited for 10-15 min.... I am running out of ideas...
Thanksa for the help anyways.
#382 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
  • LocationSchaumburg, IL
Posted 13 April 2012 - 12:14 PM
I set my exchange up using "other" and manual settings with push enabled and it works fine. Initial data download took me about an hour (because I've got something to the tune of 20k emails and i set it to "all" instead of 3 days or w/e was default) but they definitely started populating immediately.
#383 geka
geka
  • 69 posts
Posted 13 April 2012 - 12:28 PM
OK I am trying the last time. Going back to.173 via Matt tool, then factory reset, then follow instruction to get to ICS, factory reset, then go through a normal set-up, Google account first then the rest of the staff then email through "other" right?
#384 jimyv
jimyv
  • 248 posts
Posted 13 April 2012 - 12:51 PM
Rsd trust me..i finally got it right. Took a week,bout a doz total times of messing with 1.2 1.4 and1.51 i did honesty have more consistent results with rsd...now i have my own copies of my Ota files ive collected last week to side load on back up..love the utilities yes and 1.51 does break you. Back to gb but after that i advise to have your own to side load or go back and ota seems files are more complete. r something...i really dont know other than then it works out better. Im sitting in the same spot i have for months flashcrackn ththis thing and Never seen 4g here.. countryvlle Indiana and my data speeds have doubled if not tripled...! Im not touching it again until its official. Even then im keepn copies of all them now thanks to all ive learned here.
Sharing da buzz on my crackflashed rzr jimyv
#385 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
Posted 13 April 2012 - 12:59 PM
RSD will rebuild resized/altered partitions if needed. That's why it's more consistent. If you're going down from ICS don't forget to factory wipe before trying to use GB otherwise you're going to get a ton of FCs when in the GB environment.
  • jimyv likes this
#386 Vicious
Vicious
    Baddassocity in a bottle
  • 67 posts
  • Current Device(s):LG G2 VS980
Posted 13 April 2012 - 01:13 PM
SInce the leak is an update, you should setup your corporate email while on 173 and it should carry over to ics.
  • jimyv likes this
#387 jimyv
jimyv
  • 248 posts
Posted 13 April 2012 - 01:31 PM
Be super clean and updated root su binary and all so with luck and clear cache n 3e motorecovery after install before boot... shouldnt need to reset .just vodoo and let tfhis thing rest guys i didnt see my best. .benchs or data speeds until run for 72
Hours or more normal use..including one 30 sec off every24 or so. Correct me if im wrong on cache thing. Believe thats what i had better luck with ics .
#388 geka
geka
  • 69 posts
What is GB? I am bad in abbriviations....
#389 eliX84
eliX84
  • 18 posts
  • Twitter:elivaldez84
  • LocationSan Benito, TX
Posted 13 April 2012 - 01:44 PM
OK Houston we have a problem!!!! I have been trying to do this step by step but I have come up to clicking on the zip in ES and it brings a message saying:
null:/cache/"the name of the zip here"
and it doesnt do anything. Any help here????????
#390 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
Posted 13 April 2012 - 01:59 PM
Gingerbread
#391 arcanexvi
arcanexvi
    Property of Roo
  • 869 posts
ROM manager isn't installed
#392 jimyv
jimyv
  • 248 posts
Posted 13 April 2012 - 02:01 PM
Gb = gingerbread 2.3+
#393 jimyv
jimyv
  • 248 posts
Posted 13 April 2012 - 02:02 PM
Root privilege? Mounted rw?
#394 jimyv
jimyv
  • 248 posts
Posted 13 April 2012 - 02:05 PM
#395 melfunn
melfunn
  • 165 posts
  • LocationNashville, TN
Posted 13 April 2012 - 02:18 PM
Initially had issues with Root Explorer freezing up & not being able to update su binaries. RSD back to 244. Took 248 & 173 OTAs. Used Razr Utility 1.51 to root, install RazrICS Bootstrap & Voodoo Rootkeeper. DL Rom Mgr from store & then followed OP. Able to update su binaries & RE works just fine. Waiting to see if DT updates his script modifier.
  • jimyv likes this
#396 geka
geka
  • 69 posts
Posted 13 April 2012 - 04:10 PM
Hi guys, my company requires encription of the data on the phone as a part of exchange server set-up. Would that create a problem with ICS email setting? .173 works fine though...
#397 Einsteindks
Einsteindks
  • 340 posts
Posted 13 April 2012 - 05:10 PM
If motorola and verizon decide to block out the razor like they did the droid x, I will definitely sideload the ics leak for sure! !!
#398 kpeiczarek
kpeiczarek
  • 25 posts
Posted 13 April 2012 - 05:19 PM
The method for this thread.....i havent had any issues with the leak other than that....i rely on motocast for work so any help would be appreciated
i factory reset and let it sit for like an hour before i even touched anything ........and now everything works like a charm i have my motocast setup my facebook pictures are loaded for my contacts and now i have absolutely no complaints about this leak whatsoever thank you developers for all your work
#399 geka
geka
  • 69 posts
Posted 13 April 2012 - 06:30 PM
OK I gave up after 20-30 min it gives me "uknown error". I guess there is something to do with either SSL certificates or data encription... Going back to GB...
#400 eliX84
eliX84
  • 18 posts
Posted 13 April 2012 - 08:21 PM
Well actually it was installed...but i got it to update now...seems that when i RSDd back to 173 the internal sd did not get wiped...so i manually formatted and set up everything again and boom....Im having myself some Ice Cream Sandwich..pretty impressed byit till npw...everything working both cameras and all....the only thing now is the wifi tether.... tried the Sql method but it wont work....got a workaround for that?
