#301
Posted 08 April 2012 - 10:10 AM
Heard someone say they fastbooted back to 173 but was still on the ICS kernel...
[ sent from _base2 ]
#302
Posted 08 April 2012 - 10:11 AM
Ok, so I have a problem.
I can not copy the "Blur_Version.6.12.173.XT912.Verizon.en.US.zip" to the root/cache folder.
-The "Blur_Version.6.12.173.XT912.Verizon.en.US.crc" will copy though.
There is no informative error message so I tried a different program. "Root Explorer" Root Explorer told me that 3MB of 18MB is used in that folder.. I'm thinking this is the problem but what is the cause of this?
Any help would be greatly appreciated.
The zip file is about 458MB. Sounds like you're out of space.
#303
Posted 08 April 2012 - 10:15 AM
Perhaps I missed it... when I fastboot back to .173 does my kernel remain the ICS kernel or does it also revert to the stock .173 kernel?
A successful fastboot [to. 173] will revert the kernel to. 173 (radio as well)
#304
It's only just in that folder though.. I can copy it to root just fine..
#305
Posted 08 April 2012 - 10:26 AM
Thanks a lot in advance.
#306
Posted 08 April 2012 - 10:32 AM
#307
Posted 08 April 2012 - 10:35 AM
is there anyway to make the battery show its percentage without having a whole new app to display it? like in axiom?
I believe there is but if im not mistaken it still only shows increments of 10
#308
Posted 08 April 2012 - 10:41 AM
how do you do that? i went into settings but couldnt find it.I believe there is but if im not mistaken it still only shows increments of 10
#309
Posted 08 April 2012 - 10:43 AM
Thanks for the clarification superrrelaxx:) that's what I figured but just wanted to be sure.
#310
Posted 08 April 2012 - 10:44 AM
It was in the new ICS themehow do you do that? i went into settings but couldnt find it.
#311
Posted 08 April 2012 - 10:45 AM
#312
Posted 08 April 2012 - 11:51 AM
#313
Posted 08 April 2012 - 12:13 PM
anyone else have a mirror for the files, it is moving slow as hell. 2 hours left awwwwwwww
+1 ! lol
#314
Posted 08 April 2012 - 01:10 PM
I accidentally deleted mine.
#315
Posted 08 April 2012 - 02:44 PM
Sorry for being so persistant, but could you please help with issue syncing exchange emails?
touchdown
#316
Posted 08 April 2012 - 08:30 PM
Lucky you only have two hours... i had under 250 KB downloading at best. Started the download before i went to bed and wasnt done till the next day around noon.
#317
Posted 09 April 2012 - 09:42 AM
1. did the RSA back 6.12.
2. rooted, installed rom manager free and the es file manager.
3. Changed settings in ES file manager , copied the zip and crc file to the /cache directory.
4. clicked on the zip , rom manager came up and allowed it to reboot itself.
5. No stock recovery andy, boot animation comes up and it clears out the /cache directory when i'm back .
#318
Posted 09 April 2012 - 09:46 AM
#319
Posted 09 April 2012 - 12:02 PM
-ash
#320
Posted 09 April 2012 - 12:58 PM
Just wondering if you can factory reset after the upgrade process or will it have ill effects on root ?
-ash
You can do a factory reset. You will just have to redownload superuser from the market.
Sent from my DROID RAZR using Tapatalk 2 Beta-6
