487 replies to this topic
#281 superrelaxx
superrelaxx
  • 921 posts
  • Twitter:jasNwa
  • LocationSeattle, Washington
Posted 07 April 2012 - 08:19 PM
sigh....and that is?
What you see is what you get.
#282 thelastbill
thelastbill
  • 27 posts
Posted 07 April 2012 - 08:43 PM
i understand. when I first loaded the leak onto my phone, im pretty sure a message was on the lock screen saying you could put different apps there. maybe I was mistaken
#283 kbuck13
kbuck13
  • 105 posts
Posted 07 April 2012 - 08:55 PM
Has anyone successfully installed safestrap or bootstrap with working nandroid backups?
#284 superrelaxx
superrelaxx
  • 921 posts
  • Twitter:jasNwa
Posted 07 April 2012 - 08:57 PM
No
Sent from my DROID RAZR using Tapatalk 2 Beta-5Edit: DH has a working Bootstrap for the leak but no mounting USB
#285 kbuck13
kbuck13
  • 105 posts
Posted 07 April 2012 - 09:02 PM
No
Well that figures, but then again we have only had this for a short time.
#286 kbuck13
kbuck13
  • 105 posts
Posted 07 April 2012 - 09:05 PM
I saw wolf has a theme out already but wanted to back up before I started install any yet.
#287 ssmaynv
ssmaynv
  • 243 posts
  • LocationLas Vegas
Posted 07 April 2012 - 09:27 PM
I haven't tried to restore but bootstrap 2.0 did make a 1.8gb nandroid on my phone.
Also, his theme installs just fine.
#288 kbuck13
kbuck13
  • 105 posts
Posted 07 April 2012 - 09:30 PM
OK thanks, I may go ahead and try it, it looks nice.
#289 emburybrett
emburybrett
  • 13 posts
Posted 07 April 2012 - 10:16 PM
I think so as well but i skiped it all to get to homescreen... that will teach us but you can have your own sms app the icon wont change but its a start!
#290 geka
geka
  • 69 posts
  • Google+:gene.volchenko
Posted 07 April 2012 - 11:36 PM
Hi guys, do any of you have problem setting exchange email after ICS update? I cannot get mine work. Can you help? It does not show error just does not sync. Also there is no client certificate, should it be like that?
#291 rexboe
rexboe
  • 30 posts
Posted 08 April 2012 - 08:35 AM
I have a mirror to do a dowload that's not a torrent for these files zip file here
CRC file here
#292 geka
geka
  • 69 posts
Posted 08 April 2012 - 09:42 AM
I am not sure what would make corporate email not sync, I have tried multiple times to flash and reflash ICS have performed factory reset, cleared cache, rooted not rooted etc. Most of the stuff on the phone workes fine except corporate (exchange) sync. Do you guys have any suggestions???
#293 Shinare
Shinare
  • 235 posts
Posted 08 April 2012 - 09:43 AM
Still no way to download leak other than a torrent file? :( No torrent allowed here.
#294 superrelaxx
superrelaxx
  • 921 posts
  • Twitter:jasNwa
Posted 08 April 2012 - 09:44 AM
CRC file here
Still no way to download leak other than a torrent file? No torrent allowed here.
^^^^ that
#295 Shinare
Shinare
  • 235 posts
Posted 08 April 2012 - 09:50 AM
CRC file here
the file name says .173 in it?
#296 wyld
wyld
    Some Kind Of Monster
  • 845 posts
  • Google+:rramos729@gmail.com
  • LocationPortage Indiana
Posted 08 April 2012 - 09:55 AM
Im not a noob to rooting and flashing. I had a DroidX that was rooted. But there are alot of new methods and files with the newer phones. Ok so whats the CRC file for? Lol
#297 superrelaxx
superrelaxx
  • 921 posts
  • Twitter:jasNwa
Posted 08 April 2012 - 09:58 AM
That's correct (moto's naming convention).
#298 Shinare
Shinare
  • 235 posts
Posted 08 April 2012 - 10:08 AM
thanks!
#299 superrelaxx
superrelaxx
  • 921 posts
  • Twitter:jasNwa
Short for cyclic redundancy check, a common technique for detecting data transmission errors.
#300 DeusAphor
DeusAphor
Ok, so I have a problem.
I can not copy the "Blur_Version.6.12.173.XT912.Verizon.en.US.zip" to the root/cache folder.
-The "Blur_Version.6.12.173.XT912.Verizon.en.US.crc" will copy though.
There is no informative error message so I tried a different program. "Root Explorer" Root Explorer told me that 3MB of 18MB is used in that folder.. I'm thinking this is the problem but what is the cause of this?
Any help would be greatly appreciated.
