#261
Posted 07 April 2012 - 02:11 PM
- tucstwo likes this
#262
Posted 07 April 2012 - 02:49 PM
#263
Posted 07 April 2012 - 03:35 PM
As it runs it gets better... after a few reboots she flies!Ok, got the camera to work by wiping the system cache, and wiping the data from the camera app. ICS seems kinda laggy and slow to me, especially the startup.
And I'm finding battery life to be excellant... download the Chome beta browser it makes the old browser look like IE or Safari
#264
Posted 07 April 2012 - 03:51 PM
Thanks to vicious and the others who made this leak work.
#265
i tried 3 times. i couldnt get it to work.
Post a screenshot of terminal emulator with your inputs and the error
#266
Posted 07 April 2012 - 04:23 PM
#267
Posted 07 April 2012 - 04:24 PM
i did the whole process again and didnt loose root. is trhere a stock way on the leak to take screenshots?Post a screenshot of terminal emulator with your inputs and the error
#268
Posted 07 April 2012 - 04:25 PM
wipe it, then root and install vodoo. use the directions right above the video on the previous page.do I have to wipe data/cache in recovery before I install ICS? I am afraid it it deleting my Rootkeeper file.
#269
Posted 07 April 2012 - 04:26 PM
#270
Posted 07 April 2012 - 04:35 PM
i am on stock and everything is stock but i dont have anything in my root folder is there suposed to be a cache folder in the root folder?
Check out the install video a few posts back. You're missing something.
#271
Posted 07 April 2012 - 04:36 PM
i tried to find it and i made a /cache in the root. DONT! just put it in the regular /cache folderi am on stock and everything is stock but i dont have anything in my root folder is there suposed to be a cache folder in the root folder?
#272
Posted 07 April 2012 - 05:06 PM
I followed the video. It went thru the process but booted in GB.
A question about the renaming of files. When I downloaded from the hive, the only file that didnt have something different was the larger folder. I renamed it to .zip but the crc file was the same.
What did I do wrong?
cancel, it was the renaming that caused the issue. The update completed. But the CAMERA is not working.
I did too i had to do a flashboot restore three times before i got it to work.
#273
Posted 07 April 2012 - 05:10 PM
#274
Posted 07 April 2012 - 05:27 PM
Is anyone else play store not working..? It will crash every time i open it.
No but try clearing data or cache and re-launching.
#275
Posted 07 April 2012 - 05:38 PM
Never mind had to go to Ti backup and wipe its data.
Also screenshot long hold power and lower side key. (Like a reset)
#276
Posted 07 April 2012 - 05:39 PM
thanks got it.
#277
Posted 07 April 2012 - 07:29 PM
Thanks again...
#278
Posted 07 April 2012 - 08:00 PM
#279
Posted 07 April 2012 - 08:06 PM
How do you customize the lock screen apps?
WYSIWYG
#280
Posted 07 April 2012 - 08:16 PM
WYSIWYG
sigh....and that is?
