Why couldn't you just format system then name it update.zip? Just a thought but...I'm sure its not that easy like other older devices..damned RAZR.lol peace!
8-)
You've been tapped by the Drummer...
Been there done that, its a No-Go
Posted 06 April 2012 - 05:56 PM
8-)
Posted 06 April 2012 - 06:04 PM
Posted 06 April 2012 - 06:11 PM
where's P3droid when you need him.. lol He could build an all in one! LolBeen there done that, its a No-Go
Posted 06 April 2012 - 08:41 PM
Posted 06 April 2012 - 10:38 PM
Posted 07 April 2012 - 02:13 AM
Cameras working mint on mine and a lot of others.
Posted 07 April 2012 - 06:26 AM
Posted 07 April 2012 - 07:13 AM
Posted 07 April 2012 - 08:18 AM
Posted 07 April 2012 - 08:23 AM
Posted 07 April 2012 - 08:32 AM
You can but long pressing on the screen the popup for widgets will show only icons and no description, holding your finger next to each icon you can then see the description and select the one you want.Are we able to install customer launchers for this build? I have it up and running, I love it, I just need to be able to change the grid size so fit more than 4 rows of icons.
Guess I should have read above.....nevermind!
Posted 07 April 2012 - 09:03 AM
i tried matts utility with ics root, it didnt work. could someone put a detailed explanation for how to use the terminal emulator because i am having zero luck.
Edited by TwoBuells, 07 April 2012 - 03:02 PM.
Posted 07 April 2012 - 09:22 AM
Posted 07 April 2012 - 09:49 AM
i tried 3 times. i couldnt get it to work.
- Download
for free from the market.- Enter the following commands EXACTLY as you see them listed here:
- /system/su-backup
- mount -o rw,remount -t yaffs2 /dev/block/system /system
- cp /system/su-backup /system/bin/su
link......
- Exit terminal & reboot.
- Root should be restored at this point!
Posted 07 April 2012 - 09:56 AM
My suggestion is to:
) If you find that you don't have root acess. (Voodoo will tell you that you do have root acess, but run a root app, such as Root Checker to ensure you do have root.
BE having at LEAST 70% Battery and have Moto drivers on your computer (Do a search, this is easy to find)>
Use RSD lite 5.6.4 to go back to .744>
Turn off phone and boot into Android Recovery (power up phone holding Power/Both Volume Buttons)>
Wipe Data/Cache and reboot phone>
Root Phone (I used Doomlord)>
Install Voodoo Root keeper>
in Voodoo Backup SU and Temp unroot>
OTA .748>
OTA .173>
Go into Voo Doo and Restore Root>
Boot into Android Recovery (power up phone holding both volume buttons) and do a FULL data/cache wipe (for good measure)>
Reinstall VooDoo Root Keeper>
Go into Superuser App and ensure the Su Binaries are up to date (Mine weren't, VERY important)>
Install Rom Manager and ES File (And NOTHING ELSE!!!)>
In VooDoo, Protect Root (DO NOT TEMP UNROOT)>
Plug phone into computer>
Move 2 ICS Files to SD card (the one without any CWM or SS back ups on it, the one with all your app folders)>
Open Rom Manager and give it Superuser permission, check the disclaimers box then close ROM Manager>
Go into ES file and make sure you have root access checked and mount /system as writable in ES File settings>
In ES File, Move the 2 ICS files from SD into /Cache>
Click the Zip ICS file>
Select open with Rom manager>
Allow phone to reboot (if you followed directions and have no traces of CWM or SS your phone should boot into Android Recovery>
Install>
After Phone Boots, go into VooDoo Root and hit Restore root>
(Optional) Download Terminal Emulator and run the commands from this thread (
Profit!!!
I hope this helps, I tried to make this install list as idiot proof as possible. I had to install this update twice because of a few dumb mistakes that I did. So Good luck.
Posted 07 April 2012 - 11:23 AM
RAZR No Longer. Currently running the LG G2 and HTC One (M8)
Time for Moto to update the line!
Posted 07 April 2012 - 11:55 AM
Posted 07 April 2012 - 12:41 PM
Posted 07 April 2012 - 01:27 PM
Posted 07 April 2012 - 02:01 PM
I tried more then 3 and the ONLY way I was able to get root was to start over using these steps from my last post. Don't skip anything.
i re did this following all of your steps and i just rebooted. and i now have root access!!!!!!!!!! thank you guys so much!Make sure you put the spacing in the right places.
