487 replies to this topic
#201 smiznith
smiznith
  • 5 posts
Posted 05 April 2012 - 02:46 PM
Whats not working?
Both camera and ffc appear to work fine for me.
my apologies, i mean the camera app does not work on mine. i guess i need to do another hard reset.
#202 Assassin
Assassin
  • 12 posts
Posted 05 April 2012 - 03:27 PM
ok, i was on stock .173 rooted. I did the update & everything is fine, rooted and all except my visual voicemail wont work(keeps dialing) & the camera wont open at all it just says unfortuneitely the camera has stopped & even though i have the pattern unlock set it doesn`t ask me for it when unlocking the phone. should i boot into recovery & do a factory wipe. would this fix the issues i`m having or maybe factory wipe& reinstall. hope i can get those fixed i hate to go back to .173
#203 snives
snives
  • 947 posts
Posted 05 April 2012 - 03:37 PM
Can't speak for the rest, but for the unlock... what is your delay set to? It defaults to 10 minutes, so it won't ask for any unlock beyond sliding until that time has passed with it sleeping.
#204 UnknownIntention
UnknownIntention
  • 43 posts
Posted 05 April 2012 - 03:40 PM
Followed Instructions ........and SUCCESS! Thanks for the Leak :D
#205 kbuck13
kbuck13
  • 105 posts
Posted 05 April 2012 - 03:44 PM
I had all the files and when touching the file, pick rom manager the phone rebooted every time right back into GB. Also every time I set temp un-root then rom manager told me it had to have root to continue.
After reading vast amounts of threads someone (sorry can not recall and thank you!) said that rom manager premium users need the free version. What I did was to uninstall the key and free rom manager then deleted the CW folder, installed the free version and it worked the first time. Also when into root keeper and now I have full root.
#206 Assassin
Assassin
  • 12 posts
Posted 05 April 2012 - 03:46 PM
got the unlock to work. but the camera wont even launch & my visual voicemail doesnt work. should i try a factory reset or will that wipe out my root? and what about a hard reboot & how do i do that? thanx
#207 jonbink16
jonbink16
  • 28 posts
Posted 05 April 2012 - 03:55 PM
Follow the new instructions on the OP. it worked for me.
I did and when I tried to install i got an error in the recovery:
Verifying current system...
assert failed: apply_patch_check("/preinstall/KnowYourDevice/Motorola_XT912_BatterySave.3gp", "2d331a46601d4786ea21beb615b35c0a1ffd35fd", "5a74492521dad916f9bee09a6559901c542b76ea")
E:Error in /cache//Blur_Version.6.12.173.XT912.Verizon.en.US.zip
(Status 7)
Installation aborted.
anyboday know what this means?
#208 makav3ll1
makav3ll1
    TheMuffStuff
  • 11 posts
  • Twitter:TheMuffStuff
Posted 05 April 2012 - 06:14 PM
Might do this when I get my razr tomorrow. Is it buggy or is it pretty stable?
#209 dmauldin74
dmauldin74
  • 43 posts
Posted 05 April 2012 - 06:22 PM
Super stable. Minor bugs, as you would expect from a soak test leak, but no worse than any other rom.
#210 theonlycosmic
theonlycosmic
  • 470 posts
  • LocationCalifornia
Posted 05 April 2012 - 08:55 PM
(Status 7)
Idk but you should try restoring to again via Matt's Utility and see if maybe you weren't completely stock.
#211 tyrthas
tyrthas
    CassDroid's Personal Stalker
  • 455 posts
  • Twitter:@tyrthas
  • Google+:Ron Becker
  • LocationMissouri
Posted 05 April 2012 - 09:12 PM
I second this. I use his utility on Linux, but before this leak I always had to do it twice to fully fastboot and be able to update.
#212 Guest_droidpcguru_*
Guest_droidpcguru_*
Posted 05 April 2012 - 10:04 PM
Working 100% here ! :D Thanks a million to everyone who has made this happen!
#213 garywojdan81
garywojdan81
  • 633 posts
  • Twitter:gwojdan_81
Posted 06 April 2012 - 03:30 AM
Thanks Vicious, this worked perfectly for me. Followed your write up & had absolutely no issues.
#214 shaggie821
shaggie821
  • 131 posts
Posted 06 April 2012 - 04:10 AM
(Status 7)
Ur missing some preinstall videos. I have no idea y u would need them 4 update but wont work if not in right place. Use Matts Utility 1.51 i think. 1.41 worked 4 me as well.
#215 Papasmurf
Papasmurf
  • 135 posts
Posted 06 April 2012 - 04:52 AM
What exactly is not working in this build? Does someone have a drop box link?
Sent From My DROID RAZR MAXX
If DROID DOES..... then iDroid
#216 shaggie821
shaggie821
  • 131 posts
Posted 06 April 2012 - 05:05 AM
Only bug I've seen is no widget names under drop down menu. No biggie tho. I can see pics.
P.S. Camera works fine & camcorder 2 record! No other problems. No wipe & have 84 personal apps installed. Pretty d good running leak!!
Sent from my DROID RAZR using Tapatalk--EDIT-- Auto setting 4 brightness doesnt always work properly but again no biggie i set my own brightness level.
#217 kbuck13
kbuck13
  • 105 posts
Posted 06 April 2012 - 05:50 AM
I had this also when I installed Nova Launcher, running stock launcher now.
#218 quangtran1
quangtran1
  • 243 posts
Posted 06 April 2012 - 06:21 AM
You can also see the text if you tap and hold the icon, you just can't let go or that widget will be placed on the home screen. I just scroll the widget list up/down to prevent that.
The only goofy thing I've seen has to do with battery level after a reboot. My phone shows normal battery discharge as long as I don't reboot it. However, after a reboot, it can go from 65% to 35% all of a sudden.
#219 tucstwo
  • Google+:tucstwo@gmail.com
Posted 06 April 2012 - 06:30 AM
this is how i rock the ics
What clock widget is that?
#220 tucstwo
Posted 06 April 2012 - 06:31 AM
if you press your finger on the widget the text appears.
