[Bionic][MODs] Deodex & 1% Battery Mods for Stock JB 98.72.22
bionic deodex 1% battery
64 replies to this topic
#61 eye__dea
eye__dea
    Developer
  • 814 posts
  • LocationWisconsin
Posted 11 July 2013 - 05:54 PM
Ahh that makes sense. I've been using it and didn't even know:) thanks
Nice. Where u looking for a base ROM or something?
  • AmericanBully likes this
#62 Eiht
Eiht
  • 132 posts
  • Current Device(s):Bionic
Posted 12 July 2013 - 12:07 PM
No I was having some issues with my stock where nothing from rom toolbox would restore to it. Meaning my working copy of FalconPro won't restore. So I went in search of deodex stuff thinking maybe that was the reason so then I found the link for your old flashable deodex but didn't realize it became Blurry which I have on slot 3:-)
#63 bigv5150
bigv5150
  • 150 posts
  • LocationDirty Jerzey
  • Current Device(s):Droid Maxx
Posted 14 July 2013 - 06:45 AM
I have a ? I want to put this deodexed stock rom on my unsafe slot I have tried several times but everytime I lose root.  I can't reroot because of safestrap so I fxz and it roots fine.  So I tried to put just the deodexed JB without safetrap activated.  It still will not root I have to fxz back and reroot.  Is there anyway to run the deodexed build in this thread on the unsafe side rooted. If your wondering why I want to do this it's because the roms all start to have issues after a few days they get laggy and reboot etc. so I can get the 1% mod and the power menu with this deodexed build and I am fine with that.
Do you think it is the superuser that is already installed in the deodexed build causing it not to root?
#64 B.E.McAllister
B.E.McAllister
    Paint by Number Master
  • 355 posts
  • LocationUT, PA
Posted 14 July 2013 - 07:58 AM
Your not doing a factory reset first are ya? This shouldn't cause you to lose root, it's only deodex files it doesn't contain the os.
#65 bigv5150
bigv5150
  • 150 posts
Posted 14 July 2013 - 08:09 AM
yes are you saying that I should just install the deodexed zip over my stock unsafe slot containing the rooted sock jb
Nevermind I just read the op which I should have done in the first place it's not a complete os as you said.
Well it is always good to brush up on re rooting :)
  • B.E.McAllister likes this
Also tagged with one or more of these keywords: bionic, deodex, 1% battery
