[How-To] [Guide] Restore Root After Installing Ics Leak
Root ICS Leak ICS
193 replies to this topic
#141 PillClinton
PillClinton
    #FireGaryBettman
  • 441 posts
  • Twitter:530SharksFan
  • LocationNorCal
Posted 19 April 2012 - 06:30 PM
Mods, I'm thinking it might be useful to pin this thread, at least until there is a root method that works on ICS for our CDMA Razrs? Seems like it's worked for most people!
#142 tmccorn
tmccorn
Posted 19 April 2012 - 08:25 PM
No they're not. I just downloaded ICS DSP manager. Thanks btw lol.
Thet are fine now... thats weird. The morning i tried them, they were all reporting 404 errors. Must have been the site. This method works 100% if you fallow the OP to the t.
#143 Guest_BDH_*
Guest_BDH_*
Posted 19 April 2012 - 08:32 PM
+1, this should definitely be a sticky. It is 100% a fail proof way (unless you mistype or forget spaces) to regain root after the leak.
#144 tmccorn
tmccorn
Posted 19 April 2012 - 08:49 PM
#145 Rouxe41
Rouxe41
  • 10 posts
  • Twitter:@HandlebarGames
  • LocationMidvale, UT
Posted 20 April 2012 - 02:02 PM
so does anyone know how to get ADB to work with Windows 8? i have to keep using my laptop to use the Utility or anything that requires ADB. :/ ill keep looking on google though.
make sure its in your Path
#146 mickbmetz
mickbmetz
Posted 20 April 2012 - 10:21 PM
For those of you who WERE rooted & protected root with Voodoo, installed the ICS leak & subsequently lost root like I did,
tweeted out some helpful instructions to remedy the issue!
Disclaimers:
I did not personally use this method - before it was available, I had already RSD'd. On my second time through the process, I successfully retained root. Therefore this was unneeded (for ME!) All credit goes to
, I just wrote up the instructions! Thanks man, you're a lifesaver :D
Finally, I'm not responsible for any damage you do to your phone!! Read instructions carefully!
To Restore Root on the Ics Leak (Edited 4/2/12 @ 12:39PM PT):
  • Download
    for free from the market.
  • Enter the following commands EXACTLY as you see them listed here:
  • /system/su-backup
  • mount -o rw,remount -t yaffs2 /dev/block/system /system
  • cp /system/su-backup /system/bin/su
  • ​Exit terminal & reboot.
  • Root should be restored at this point!
Please post in this thread if it worked for you. If so, please hit the LIKE button! :)
#147 mickbmetz
mickbmetz
Posted 20 April 2012 - 10:22 PM
Awesome worked perfect after I copied and pasted
#148 theBonVoyage
theBonVoyage
  • 118 posts
  • LocationCharleston, SC
Posted 21 April 2012 - 07:17 AM
worked without a single problem. thanks to the op!
#149 NattyBee
NattyBee
  • 647 posts
Posted 22 April 2012 - 08:25 AM
This is awesome...used this method on both my Maxx's
Sent from my Razr Maxx using Tapatalk
#150 Kimo91
Kimo91
  • 148 posts
  • Google+:elton.k.sales@gmail.com
  • LocationGoose Creek, SC
Posted 22 April 2012 - 11:17 PM
I tried restoring root using this method but I keep getting "not found" and I did everything before loading leaked ICS including voodoo rootkeep and backing it up...followed everything to the letter on terminal emulator but nothing's working. Anyone got any ideas what I maybe doing wrong?
Sent from my DROID RAZR using Xparent Red Tapatalk 2
#151 Guest_BDH_*
Guest_BDH_*
Posted 23 April 2012 - 02:26 AM
The only way you could get the "not found" error is if root wasn't properly backed up.
  • PillClinton likes this
#152 MartyChubbs
MartyChubbs
  • 211 posts
  • LocationThe Ghetto, Minnesota
Posted 26 April 2012 - 06:55 AM
I have upgraded to the ICS Leak 5 times in the last 48hours...Trying to get the set up just right and learned a few things like needing and making a homemade factory cable and flashing on a low battery. I used this method in the OP 3 of the 5 times since I was starting at .173 via Matt's 1.51, root, backup root, and upgrade. 3 or the 5 times root was not restored and I followed the steps here...I was working on a script to automate it...and before the 4th time, I remembered that I did not lose root when I flashed all the way back to .744 and BINGO! See, I had to restore root going from .744 to .173. So, I just backed up and restored root the before the 4th and 5th time I upgraded from GB to ICS, root was restored and I can now forget the steps I memorized.
Now I just:
1. Start with .173 via Matt's 1.51
2. Root
3. Voodoo
4. Backup root
5. Temporarily Unroot
6. Restore root
7. Upgrade to ICS
8. Restore root
So, if you restore root before you upgrade to ICS, YOU WILL NOT LOSE ROOT!
+1 on the pin
Please test and like this if it works...
Also, my torrent client appended loaded to the torrents and that gave a 404...I turned off load from directory and edited the torrents...so I broke and fixed the problem...sorry for the mystery :D
Edited by MartyChubbs, 26 April 2012 - 08:04 AM.
I (aka Mr. Chubbs aka Marty "The Wad" Chubbs aka Knot Mehreelname ) accept no liability for the content of this post. I basically made it all up as I was typing...
#153 Nox Aeris
Nox Aeris
Posted 26 April 2012 - 11:43 PM
i did the voodoo method and that kept SU, and im getting SU permissions. went from new in box right to ICS leak. but when i looked into voodoo it doesnt have all boxes checked. i did this trick and bam all boxes checked. cleared cache in AP mode right after.
#154 Guest_BDH_*
Guest_BDH_*
Posted 27 April 2012 - 12:05 AM
Now I just:
2. Root
3. Voodoo
4. Backup root
6. Restore root
7. Upgrade to ICS
8. Restore root
+1 on the pin
Step 5 and Step 6 are not needed.
#155 pasinato
pasinato
  • 49 posts
  • Twitter:tonypasinato@hotmail.com
Posted 27 April 2012 - 05:13 PM
Went back to 173 with Matt's program
Did the OTA to 181
Rooted with Matt's program
Installed Vodoo and protected root
Loaded the ICS Leak
Used terminal commands to restore root.
Rockin and rolling now.... Thanks for the Leak.
#156 londonfire93
londonfire93
Posted 29 April 2012 - 11:54 AM
just open an adb shell in a command prompt and copy and paste commands no reboot necessary
#157 odeveca30
odeveca30
  • 9 posts
  • Twitter:eli_ace
Posted 29 April 2012 - 05:33 PM
worked flawlessly on emulator. im on .85 leak and @ least for now I have full root. Thanks
#158 smdinsf
smdinsf
  • 6 posts
Posted 01 May 2012 - 08:50 PM
Right ON! It worked for me, Thank You so much! :D
I did it again today on a friends RAZR. Just small tweak instead of using the terminal emulator on the phone I used Matt's Tool (thanx dude) utilizing option # 13 ADB Shell. That made it very easy to just cut and paste those commands. Below is the output from my session. Thanx again....
Don't use this unless you know what you are doing.
Make sure your phone has Debugging mode enabled.
Type in "exit" without the "" to exit from shell.
shell@cdma_spyder:/ $ /system/su-backup
/system/su-backup
root@cdma_spyder:/ # mount -o rw,remount -t yaffs2 /dev/block/system /system
root@cdma_spyder:/ # cp /system/su-backup /system/bin/su
root@cdma_spyder:/ # exit
shell@cdma_spyder:/ $ exit
Edited by smdinsf, 02 May 2012 - 08:03 PM.
#159 pdiddy1906
pdiddy1906
  • Twitter:rodneyking06
  • Google+:rodneyking06
Posted 05 May 2012 - 08:20 AM
Follow the directions and everything worked for me. Doing the Ed Lover's dance.
#160 xlightwaverx
xlightwaverx
    CrackFlasher
  • 409 posts
  • Twitter:xlightwaverx
  • LocationEast Coast
  • Current Device(s):XT912, Kindle Fire HD
Posted 05 May 2012 - 08:58 AM
Not sure what's going on, I sent Matt a new ICS root utility I found on the XDA thread. Once you have ICS installed you can root your ICS installation without having prior root access in .181. Just figured I would chime in since people still seem to be worrying about maintaining it via RootKeeper.
X
Also tagged with one or more of these keywords: Root, ICS Leak, ICS
