[How-To] [Guide] Restore Root After Installing Ics Leak
#121
Posted 09 April 2012 - 08:36 AM
- PillClinton likes this
#122
Posted 09 April 2012 - 09:15 AM
#123
Posted 09 April 2012 - 10:37 AM
#124
Posted 09 April 2012 - 03:01 PM
#125
Posted 10 April 2012 - 08:08 AM
#126
Posted 10 April 2012 - 09:00 AM
Watch the typos and spaces guys.
+1
#127
Posted 10 April 2012 - 02:31 PM
#128
Posted 11 April 2012 - 07:32 AM
#129
Posted 11 April 2012 - 09:20 PM
Attempted to update binary today (current version before/after is 3.0.3.2, SU v3.0.7(41) ), but I'm greeted with "downloading manifest.....FAIL".
DL'd SU update fixer, it can't find any problems, when I forced the update, it seemed to remove root until I DL'd SU from the market again.
Any ideas?
#130
Posted 11 April 2012 - 09:32 PM
The method detailed in the OP worked for me!
Everything you need or may need one day:
- tmccorn likes this
#131
Posted 12 April 2012 - 03:00 AM
Has anyone else ran into a failed issue when updating the binary in SU? I got a replacement phone Saturday due to an epic fail of the battery (stopped charging after a full discharge), rooted the replacement via Motofail, backed up with Voodoo, installed ICS on Saturday. When I used TiBU to restore apps, it asked to correct an issue with SU which I allowed. That was after restoring root w/ Voodoo.
Any ideas?
I just got this error last night and I am fresh stock rooted so I don't think it has anything to do with the leak or any rom that you may be running. If i happen to come across something that fixes it I'll let you know. Maybe someone here already knows how to correct the situation too.
#132
Posted 12 April 2012 - 05:44 AM
#133
Posted 12 April 2012 - 08:14 AM
I'll post up anything that I find out too- I'll check on the XDA thread to see if anybody there has experienced it and any suggestions.
#134
Posted 12 April 2012 - 07:39 PM
I had tried what the OP suggested as far as terminal emuluator- had no problems there, but I still get the message when attempting to update the binaries.
Connection issue. Got it to work today.
Mine is a refurb that's had connectivity issues from a dig. Nothing like getting somebody elses rebuilt junk to replace a phone that's <2 months old.
#135
Posted 14 April 2012 - 02:52 PM
- sjskent likes this
#136
Posted 14 April 2012 - 08:05 PM
What ended up working is:
1 Use RSD to go back to 744
Use Mot Recovery to factory reset
Use Mot Rec to install 748 patch
Use DRU to root
Update SU via market
Install Busybox via market
Install Voodoo via market
Update SU binaries
Backup with Voodoo
Use ES n RM to install ICS
Voodoo fails
Term works(finally on like the 5th different way I tried)
#137 Guest_BDH_*
Posted 15 April 2012 - 12:15 AM
Followed this forum and it worked on one of my Razr Maxx's. On the second one I tried everything.
Use DRU to root
Update SU binaries
Backup with Voodoo
Voodoo fails
Not sure if you missed a step or not but you're supposed to be on .173 before installing
#138
Posted 16 April 2012 - 05:10 AM
#139
Posted 16 April 2012 - 05:12 AM
I am getting the same error.
All your links are reporting 404...
#140
Posted 19 April 2012 - 04:41 PM
No they're not. I just downloaded ICS DSP manager. Thanks btw lol.
Also tagged with one or more of these keywords: Root, ICS Leak, ICS
