[How-To] [Guide] Restore Root After Installing Ics Leak
#101
Posted 06 April 2012 - 07:07 PM
#102
Posted 07 April 2012 - 03:13 AM
Be sure your keyboard is not automatically placing a space after the slash in the command line. It took me two times following the instructions very carefully and on the second go round I noticed the extra space being placed after the slashes where there should be none.
Works great Pill
- PillClinton likes this
#103
Posted 07 April 2012 - 05:08 AM
#104
Posted 07 April 2012 - 07:12 AM
#105
Posted 07 April 2012 - 09:08 AM
#106
Posted 07 April 2012 - 09:13 AM
I can now debloat this bloated beast.
#107
Posted 07 April 2012 - 05:52 PM
#108
Posted 07 April 2012 - 05:55 PM
any chance of getting root access after ics updated?4got to back up root.For those of you who WERE rooted & protected root with Voodoo, installed the ICS leak & subsequently lost root like I did, tweeted out some helpful instructions to remedy the issue!Disclaimers: I did not personally use this method - before it was available, I had already RSD'd. On my second time through the process, I successfully retained root. Therefore this was unneeded (for ME!) All credit goes to , I just wrote up the instructions! Thanks man, you're a lifesaver Finally, I'm not responsible for any damage you do to your phone!! Read instructions carefully! To Restore Root on the Ics Leak (Edited 4/2/12 @ 12:39PM PT):
- Download
for free from the market.- Enter the following commands EXACTLY as you see them listed here:
- /system/su-backup
- mount -o rw,remount -t yaffs2 /dev/block/system /system
- cp /system/su-backup /system/bin/su
Please post in this thread if it worked for you. If so, please hit the LIKE button!
- Exit terminal & reboot.
- Root should be restored at this point!
- thenowherekid and Smooth like this
#109
Posted 07 April 2012 - 06:03 PM
#110
Posted 07 April 2012 - 06:42 PM
ics is great and all but i now live with a bloated cow! idk how i didnt back up root!thanks in advance for helping out.
You can disable some bloat thru stock "Apps" application, otherwise you'll need to start over
#111
Posted 07 April 2012 - 08:53 PM
#112
Posted 08 April 2012 - 03:12 AM
#113
Posted 08 April 2012 - 09:22 AM
#114
Posted 08 April 2012 - 09:49 AM
#115
Posted 08 April 2012 - 11:44 AM
#116
Posted 08 April 2012 - 10:56 PM
#117
Posted 09 April 2012 - 06:02 AM
#118
Posted 09 April 2012 - 06:39 AM
#119
#120
Posted 09 April 2012 - 07:10 AM
Also tagged with one or more of these keywords: Root, ICS Leak, ICS
