[How-To] [Guide] Restore Root After Installing Ics Leak
Root ICS Leak ICS
193 replies to this topic
#61 tucstwo
  • Google+:tucstwo@gmail.com
Posted 04 April 2012 - 07:49 PM
hmmm did everything as instructed no errors in terminal emulator..rebooted still dont have root hmmm? did i miss something ..now when i did the ota ics leak i did the voodoo roote keeper ...i did protect my roote but i didnt try to unroote before ics. is that a problem.
Not really an option, you can't reach root files in ES nor operate ROM Manager without root acess, so no, it's nothing you did.
#62 SlammedDime
SlammedDime
  • 43 posts
Posted 04 April 2012 - 08:05 PM
Someone wanna explain why /system is being remounted as yaffs2 when it's an ext3 filesystem?
#63 SandmanEight
SandmanEight
  • Twitter:SandmanEight
Posted 04 April 2012 - 08:58 PM
Worked for me as well after the ICS Vicious sideloader method!
#64 T3hD0gg
T3hD0gg
  • 85 posts
Posted 04 April 2012 - 09:06 PM
I initially had problems after flashing where running su in the terminal emulator would return Permission Denied after 10 seconds or so and none of my applications using root worked correctly. I had used Voodoo OTA Rootkeeper to backup my root as well and did not temporarily unroot.
Is anyone still having this problem? I've found a solution but if no one is having the problem, I don't see any reason to release it.
#65 kellogg
kellogg
  • 114 posts
  • Locationflorida
Posted 04 April 2012 - 09:09 PM
yes i still having the problem u just describe...i would love the help?
#66 T3hD0gg
T3hD0gg
  • 85 posts
Posted 04 April 2012 - 09:14 PM
I will contact you by private message as it needs to be tested by a problematic phone.
However, I have gotten it to work by hand and have tested my automated method on my phone.
If it works for you, I'll post it for anyone to use.
#67 kellogg
kellogg
  • 114 posts
  • Locationflorida
Posted 04 April 2012 - 09:18 PM
ok.....phone dieing 22hours need yo charge now
#68 ddemlong
ddemlong
  • 137 posts
  • LocationPhoenix, AZ
Posted 04 April 2012 - 10:27 PM
looking for help,
on the last set of commands I get the cp/system/su-backup/system/bin/su: not found 127[ roo@cdma_spyder: / #
Droid RAZR Rooted
#69 ddemlong
ddemlong
  • 137 posts
Posted 04 April 2012 - 11:13 PM
I am gonna try to flash back to .173 on a clean slate install voodoo again, root, and sideload ics. If I can't keep root I can wait for the official or a sure way of rooting is found.
Droid RAZR Rooted
#70 ddemlong
ddemlong
  • 137 posts
Posted 05 April 2012 - 12:20 AM
OMG FINALLY....
I re flashed, installed voodoo, went through terminal and finally got it back. I wonder if it had anything to do with my phone being plugged into a computer.
Droid RAZR Rooted
#71 mgarney26
mgarney26
  • 116 posts
  • Twitter:mgarney26
  • Locationmobile alabama
Posted 05 April 2012 - 02:14 AM
just did mine...thanls pill and dhacker!
#72 icemans2k02
icemans2k02
  • 9 posts
Posted 05 April 2012 - 05:32 AM
Thanks for the write up! Worked great.
Restored back to .174, rooted, and installed voodoo. backed up root
Installed ICS and actually did a combo of using voodoo to restore and d hackers method.
Also I did not "temp unroot" only backed up using voodoo.
Its nice having native screen shot!
#73 tucstwo
Posted 05 April 2012 - 06:12 AM
Um, help??? I just read this whole thread and saw nothing about this error. I did back up su before update, voodoo even says the back up is there and that my phone is rooted but it's not. Su-backup is on my phone as well but I keep getting this.
#74 (TSON)
(TSON)
  • 529 posts
Posted 05 April 2012 - 06:25 AM
you forgot half of the command lmao "rw,rem" isn't a command
  • PillClinton likes this
#75 sjskent
sjskent
  • 9 posts
Posted 05 April 2012 - 06:52 AM
These steps worked for me. Big thanks to PC!! I had to do it a couple of times because i missed some key spaces in the code. This sequence and the spacing is critical. Maybe this is elementry but it was the difference for me. The red _ below signify where the spaces go in the commands.
  • /system/su-backup
  • mount_-o_rw,remount_-t yaffs2_/dev/block/system_/system
  • cp_/system/su-backup_/system/bin/su
Hope this helps a bit and isnt too noob to point out.
Also, you can verify that you have the su-backup in your system folder using root explorer before starting to ensure that it exists. Might save some time.
  • bilbobaggins, dmoriarty, solo1414 and 1 other like this
#76 tucstwo
Posted 05 April 2012 - 07:01 AM
I didn't forget it, I stopped typing the command when I got the no permission error. I'm trying to figure out why that happened before I go further. This method has not worked for me yet. If anyone knows what that error means and can help me I would appreciate it.
  • RAZRblade likes this
#77 martybm5
martybm5
  • 11 posts
Posted 05 April 2012 - 08:10 AM
Worked for me ! 1st time !! Thanks Dhacker & Pill
#78 quangtran1
quangtran1
  • 243 posts
Posted 05 April 2012 - 08:40 AM
Same here, 1st try --- Thanks Pill.
#79 kellogg
kellogg
  • 114 posts
  • Locationflorida
Posted 05 April 2012 - 08:43 AM
  • /system/su-backup
GREAT eye been trying this for two days without error in terminal emulator and wasnt working....when i implied the space in the right spots IT work...good to go :D
#80 kellogg
kellogg
  • 114 posts
  • Locationflorida
Posted 05 April 2012 - 08:45 AM
That was a no go Just said cant find phone all the down the screen...but i have root now thanks for the help
Also tagged with one or more of these keywords: Root, ICS Leak, ICS
