[How-To] [Guide] Restore Root After Installing Ics Leak
#181
Posted 19 May 2012 - 03:21 PM
#182
Posted 19 May 2012 - 03:36 PM
#183
Posted 21 May 2012 - 11:36 AM
#184
Posted 28 May 2012 - 05:02 PM
And then I managed to get this to work, by using wifi on my phone and copying and pasting the commands in to the emulator one at a time,
After the second and third line nothing seemed to happen but i rebooted the phone like the instrunctions said and sure enough i had full root access!
I hope this helps.
#185
Posted 01 June 2012 - 10:30 PM
Another sucess coming from .181 sbf to .79 leak. Now to flash me some KOA!
#186
Posted 03 June 2012 - 06:56 AM
#187 Guest_BDH_*
Posted 04 June 2012 - 02:03 AM
Can I reach the conclusion here that Voodoo is not good when you go to leaks?
Voodoo works just fine for some people, but not for everyone. Which is why these terminal commands are needed.
#188
Posted 19 June 2012 - 07:03 PM
thanx so much
#189
Posted 21 June 2012 - 10:47 PM
no access to data or cache
came from .181 strait to .211 could not side load.....had to do the cache method for the leak to work
can't root my phone with any device.....it's not giving permission.......abd is connecting just fine....i don't get it
#190
Posted 23 June 2012 - 05:27 PM
completely loss root
after hitting restore root in voodoo root keeper - still no root
tried this method and it worked GREAT! now i have root on .211
#191
Posted 24 June 2012 - 07:00 PM
#192
Posted 25 June 2012 - 08:19 AM
Voodoo also did not work correctly for me, to restore root...that's what I tried originally, but it failed. This works like a charm.
#193
Posted 06 July 2012 - 07:41 AM
For those of you who WERE rooted & protected root with Voodoo, installed the ICS leak & subsequently lost root like I did, tweeted out some helpful instructions to remedy the issue!
Disclaimers:
I did not personally use this method - before it was available, I had already RSD'd. On my second time through the process, I successfully retained root. Therefore this was unneeded (for ME!) All credit goes to , I just wrote up the instructions! Thanks man, you're a lifesaver
Finally, I'm not responsible for any damage you do to your phone!! Read instructions carefully!
To Restore Root on the Ics Leak (Edited 4/2/12 @ 12:39PM PT):
- Download for free from the market.
- Enter the following commands EXACTLY as you see them listed here:
- /system/su-backup
- mount -o rw,remount -t yaffs2 /dev/block/system /system
- cp /system/su-backup /system/bin/su
- Exit terminal & reboot.
- Root should be restored at this point!
Please post in this thread if it worked for you. If so, please hit the LIKE button!
thanks man worked for me. If people can unlock there phone your instructions are fine. i guess you have to tell them to hit ENTER after they type in the dos commands
#194
Posted 06 July 2012 - 01:10 PM
cant find my su backup anywhere
I'm having the same exact issue, and I wish I wasn't at work so that I could run adb and stuff.
Also tagged with one or more of these keywords: Root, ICS Leak, ICS
