TWRP Installation on Unlocked BL RAZR HD/MAXX
Posted 12 April 2013 - 09:53 AM
1) Unlock your bootloader if you have not already done so. Instructions . - Note: This will VOID YOUR WARRANTY - Credit Dan Rosenberg
1a) Delete or rename install-recovery.sh found in the system/etc folder (Some people have encountered an issue where they can't boot into recovery. I haven't encountered the issue but this resolves it.)
2) Download file - (This is the most current vanquish recovery available at the time of this post) - Credit: Hashcode
3) Boot your phone into fastboot mode (with the phone off hold all 3 power/volume + and - until your see the boot screen and select fastboot or alternatively open up a terminal with the phone booted and run "su" to gain root access then "reboot bootloader")
4) Plug your phone into your computer (duh).
5) Open a command prompt and have your fastboot and file downloaded above in the same folder (easiest way is to shift right click the folder you have them in and open command prompt so you don't have to manually navigate there).
6) Run the following command: fastboot flash recovery twrp-2.5.0.0-recovery-vanquish.img
7) Run the following command (or press power to power down the phone): fastboot reboot
8) Profit
Now whenever you boot into recovery you'll be greeted with TWRP 2.5.0.0
Note: If you get an unknown command error during fastboot grab the fastboot executable from Dan's bootloader unlock file. That's the one that works for modern Snapdragon devices if you didn't already have it.
Thank you big time to Dan Rosenberg, Hashcode and the rest of the development community for your hard work on these devices.
- ArcaneXVI
- tucstwo, Xelios and smokestace like this
Posted 12 April 2013 - 10:36 AM
Posted 12 April 2013 - 12:19 PM
i'm having a problem where in the terminal on the phone when i put in "su reboot bootloader" it replies with "sh:bootloader: not found" and also when i go into fastboot mode and in the cmd prompt on the computer when i try step 6 it says that fastboot is not a recognized command...i'm on safestrap and have tried it on both the rom i'm running and the stock slot, on the fastboot screen on the phone it says "device is UNLOCKED, status code 3"
Sorry that should have been 2 separate commands to work on some versions of terminal.
Posted 12 April 2013 - 12:31 PM
Since there's no thread detailing how to do this yet (although many of us know how) I'll make a quick post detailing how to install TWRP on your HD/MAXX. This obviously works on anything with an unlocked bootloader but the file I'll be linking to is for the RAZR HD/MAXX.
8) Profit
- ArcaneXVI
You might want to add that you need to delete or rename install-recovery.sh to install-recovery.sh.bak or twrp will not boot and you will still be in stock android recovery. install-recovery.sh is found at /system/etc/install-recovery.sh
Posted 12 April 2013 - 12:53 PM
Posted 12 April 2013 - 01:15 PM
Is it suppose to recognize as an XT925 on a XT926 phone?
Shouldn't be an issue. I haven't encountered any problems with mine. Flashed CM 10 (not 10.1 due to the camera problems) and it's running without any major problems. Bluetooth media audio doesn't get passed through and the lock screen is wonky but otherwise fine. Nothing related to the recovery.
Posted 12 April 2013 - 01:16 PM
Hmm. I haven't encountered this issue. Can anyone else verify that this might be a necessary step?
Posted 12 April 2013 - 01:35 PM
Posted 12 April 2013 - 01:43 PM
So my Razr Maxx HD is unlocked. however when I go into the cmd window and type fastboot devices, my phone is not displayed. Basically it tells me fastboot in not a internal or external command. any suggestions on how to flash this to my phone?
Fastboot drivers aren't installed properly or the fastboot.exe file isn't in the directory you're trying to execute from. Not sure what the exact error message is that you're seeing but fastboot commands are not adb commands. Read: NOT "adb fastboot blah blah blah"... If you need the fastboot executable you can just run it from the folder where you unpacked Dan's apocolypse bootloader unlock as the file is in there. Just make sure you drop the downloaded recovery file in the same folder if you're going to use that one. (I'm lazy like that )
Posted 12 April 2013 - 02:09 PM
Yeah I tried it twice and the only way I could get twrp to install and stay as the main recovery was to delete that file or rename it. I think this is something new with Jelly Bean, I had to do the same thing with my nexus 7 and Gnex
Posted 12 April 2013 - 02:42 PM
Posted 12 April 2013 - 02:44 PM
NO this is how to install twrp Recovery on the unlock bootloader on the Droid Razr HDSo this will unlock the bootloader for my RAZR maxx??!
Posted 12 April 2013 - 07:33 PM
Sent from my DROID RAZR HD using Xparent Cyan Tapatalk 2
- rogerwt123 likes this
Posted 12 April 2013 - 07:50 PM
Also confirming that it is indeed necessary. I was running 4.1.2 rooted.Hmm. I haven't encountered this issue. Can anyone else verify that this might be a necessary step?
Thanks for this guide though. I stepped away from these forums for a few days and here I come back with major news about the bootloader, and felt so lost haha. Got everything running so far and I'm installing CM10 as I type this. You rock!
Posted 12 April 2013 - 08:06 PM
Video on how to install TWRP with these steps for Noobs
- JJT211, sb8636 and cizco962 like this
Posted 12 April 2013 - 09:37 PM
Posted 12 April 2013 - 10:15 PM
Posted 13 April 2013 - 03:26 PM
EDIT
this probably belongs in the QA section. sorry
Posted 13 April 2013 - 06:00 PM
i had given over to the thought of having a stock phone with my razr maxx hd, and never bothered to root. i installed the OTA 4.1.2. the new exploit from djrbliss gave me root but didn't unlock my bootloader. has anyone else with the problem figured it out yet? i'm a beggar so i ain't choosin, but i'm wondering if i just sit on my rooted/locked bootloader for now or if there's a better answer...
EDIT
It's 2 separate exploits you need. The root exploit is just that. Once rooted you can use the bootloader exploit. This thread pertains to getting TWRP on your device.
- spartandmd likes this
Posted 13 April 2013 - 06:01 PM
