[Utility]Recovery Flasher for Unlocked Bootloader Razr M V6 [1 Click] - {UPDATED 7-11-13} (Latest Recoveries)
85 replies to this topic
#81 Ethan82691
Ethan82691
  • 113 posts
  • Google+:blindside7x@gmail.com
  • LocationIdaho
Posted 02 November 2013 - 05:03 AM
When I was running CM10 with SS, I always had the camera issues and weak WiFi. If I needed the camera or WiFi, I would just boot on the stock side. Take a look at Xposed Framework. It can be used to theme and tweak the stock ROM. You can also allow Init.d support on your stock ROM so that you can start adding tweaks if you would like.
Awesome that is definitely something I will look at ! Can you help me better understand what the two are and where I would find them? I suppose the Xposed Framework is something I can download or flash? ? But I don't know anything about Init.d . When I had the original droid razr I used to tweak the roms and make my own themes for them and what not , so I should know what you are talking about ! But I don't lol
Sent from my SCH-I545 using Tapatalk
Ethan82691
#82 Rampartt
Rampartt
Posted 29 November 2013 - 11:35 PM
For some reason I can't get it to stick? After the initial setup, whenever I want to go back into clockwork (turning the phone off then holding down both the power and both volumes) it just boots up normally when I select recovery.
#83 Ethan82691
Ethan82691
  • 113 posts
  • LocationIdaho
Posted 23 February 2014 - 07:08 PM
Does this work for all Droid Razr M's? I am running 98.30.1 and when i flash a recovery, it shows as sucessful, but gets stuck in AP Fastboot with a flash failure. Any ideas??
Thanks!
Ethan82691
#84 livinginkaos
Posted 23 February 2014 - 07:45 PM
It works on all UNLOCKED RAZR M's. If your device is not unlocked you cannot flash a custom recovery. And before the question is asked, no, that version cannot be unlocked.
You would need to reflash stock recovery and install Safestrap if you want to flash blur based roms.
Sent From My DEV X
#85 Ethan82691
Ethan82691
  • 113 posts
  • LocationIdaho
Posted 23 February 2014 - 07:48 PM
Sent From My DEV X
Thank you !!! i Appreciate it!
Ethan82691
#86 SamuriHL
  • 44,375 posts
Posted 13 October 2014 - 08:19 AM
Depracating this thread since it hasn't been updated in a long time.
