[Utility]Recovery Flasher for Unlocked Bootloader Razr M V6 [1 Click] - {UPDATED 7-11-13} (Latest Recoveries)
85 replies to this topic
#21 tucstwo
  • Google+:tucstwo@gmail.com
Posted 13 April 2013 - 09:47 AM
The version in the tool. However I am on CWM now so that is good.
More important issue, however. I have lost the ability to charge. I was rooted running safestrap and the energy rom 3/18/13. Once I unlocked the bootloader, I get an exclamation point over my battery in the status bar and it will not charge on wall charger. Only charges when connected to usb very, slowly. I cannot seem to re-flash the energy rom while on recovery. I get "unable to flash energy_ROM_RAZRM_03.14.2013.zip" reason "error".
Interestingly. The charging issue cleared itself up. I must have disconnected it during some process. A reboot while attached to the pc has now fixed it. The exclamation point is gone, and it charges on both wall and pc. Weird.
It's my understanding and roms that were originally designed to be flashed with safestrap you need to first manually mount /system before you flash em.
#22 tucstwo
#23 brandon71
brandon71
  • 553 posts
  • Google+:tbd7171@gmail.com
  • LocationKodak, TN
Posted 13 April 2013 - 09:56 AM
yea that's right gotta mount before wiping and mount before flashing
  • shane1 likes this
#24 tucstwo
Posted 16 April 2013 - 12:27 PM
updated to version 2 to help those having problems with recovery sticking
  • jamminjon82 and shane1 like this
#25 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 17 April 2013 - 08:24 PM
Installed TWRP and reboted to recovery but it was stuck on the boot logo. Tried CWM and it was fine. Anyone else having this problem?
Need Help? Send me a message
#26 wapiti_j
wapiti_j
  • 33 posts
  • Current Device(s):nexus7, razrm
Posted 18 April 2013 - 06:07 AM
Yes. That very issue.
#27 tucstwo
Posted 18 April 2013 - 06:31 AM
I've heard through pm too that some people are having problems with the TWRP that's out there. I'm amazed the a recovery could be causing boot up problems. You guys have safestrap uninstalled, right? Bootloaders are unlocked? Just bouncing ideas.
#28 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 18 April 2013 - 06:38 AM
Yea it's been confusing me to death the only roms I can't flash is rage and trippin beam but everything else flashes fine for me idk what could be causing problems for other people
#29 wapiti_j
wapiti_j
  • 33 posts
Posted 18 April 2013 - 08:44 AM
Yes, safestrap uninstalled, and Bootloader Unlocked.  I am getting ready to try something else.  However, all problems started when I unlocked the bootloader and uninstalled safestrap.
#30 nprevette420
nprevette420
    BlissPop Maintainer
  • Banned
  • 1,626 posts
  • LocationNC
Posted 18 April 2013 - 09:05 AM
SafeStrap is uninstalled, bootloader is unlocked. TWRP recovery causes boot to hang. I used CWM and it worked fine. I installed CM10 4/14 build through CWM with no issues.
#31 shane1
shane1
    Droid Elite
  • 1,596 posts
  • Twitter:1shane15
  • Locationny
Posted 18 April 2013 - 04:29 PM
in order to get dst to boot i had to reboot recovery after wiping then remount system.
  • neckchop likes this
sig made by
Rinkle McBally
#32 Deacon
Deacon
  • 68 posts
  • LocationUSA
Posted 20 April 2013 - 01:37 PM
just bricked my phone using this trying to flash twrp
#33 Deacon
Deacon
  • 68 posts
  • LocationUSA
Posted 20 April 2013 - 01:38 PM
stuck on bootloader unlocked screen any help/advice
#34 Deacon
Deacon
  • 68 posts
  • LocationUSA
Posted 20 April 2013 - 01:39 PM
got it to boot with power+voil down nm
#35 Deacon
Deacon
  • 68 posts
  • LocationUSA
Posted 20 April 2013 - 03:50 PM
got twrp to install by rebooting to bootloader then flashing the image, much easier..
#36 tucstwo
Posted 20 April 2013 - 04:17 PM
I just updated the OP to version 3. I replaced the version of TWRP that was in the package. The one I had in there didn't have a matching MD5 to Hashcodes current TWRP on his Goo.im. So, hopefully that will fix ll those who had booting issues with TWRP flashes gone wrong  :)
  • shane1 likes this
#37 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 20 April 2013 - 04:20 PM
The Version in hashes goo was 2.4alpha and it's restore was buggy unless he updated it to a newer version
  • shane1 likes this
#38 tucstwo
Posted 20 April 2013 - 04:30 PM
Sure easy peasy for someone who knows how to do it. Not everyone is comfortable with a command line. And the instructions are in the OP for those who want to do so manually.
IDK, the version I had in there was causing nothing more than soft bricks. So my suggestion is for peeps to just stick with CWM at the moment if that's the case. I religiously use CWM so I am the wrong person to ask.
#39 brandon71
brandon71
  • 553 posts
  • LocationKodak, TN
Posted 20 April 2013 - 04:37 PM
The Version I'm using is 2.3.2.3 and I haven't had any problems out of it
  • shane1 likes this
#40 tucstwo
Posted 20 April 2013 - 04:38 PM
Actually no, I just confirmed. The TWRP included in version 1 and 2 was the same 2.4 TWRP that Hash uploaded on 4/8. The one that's "buggy". Only difference was that my version of it had a mismatched MD5 sum with what Hash uploaded. So even if this copy is buggy, it's at least WHAT Hash made and not a corrupt version.
If you want, PM me a link to that please and I will include it. Thanks a lot
  • shane1 likes this
