I'll ask the next obvious question...how does one fix such an issue should it occur on their phone (not saying it has on mine)?<br /><br />Sent from my DROID RAZR MAXX HD<br /><br />
You would need to use the utility to fastboot back to stock.
Posted 14 May 2013 - 03:31 PM
Posted 15 May 2013 - 06:38 AM
So i finally successfully rooted and unlocked BL. Where do I begin lol? Whats the advantage of having a unlocked phone?
Posted 18 May 2013 - 08:45 PM
the advantages are endless. you can flash anything. the only problem is you can flash stuff thats not meant for you phone and that can be an issue. so now that your free please read before you flash. and not just the op the whole thread
Posted 28 May 2013 - 07:53 PM
Im new to this rooting stuff. sorry in advance guys & girls.
im trying to do this on a mac running 10.7.5 - my droid razr maxx hd on 4.1.2
im not good at the computer language like you guys are. I think im doing this correctly as far as opening up a terminal window & typing in the command - no luck. i tried dragging the run.sh onto the terminal window. either way it says: command not found
what am i missing or doing wrong?
is there any easy instructions or a link to a video for us non rooting pro's?
Posted 31 May 2013 - 04:27 PM
Posted 07 June 2013 - 07:50 PM
- ok so i got a hold of a windows 7 ULT. 64 bit laptop
- downloaded the motochopper.zip file
- extracted it
- usb debugging check
- i run the batch file - hit enter
- it says: abd not recognized
what does that mean & how do i fix it??
i posted the quoted question on this topic & another topic on this forum site, not 1 person responded. c'mon i need some help.
Posted 08 June 2013 - 06:52 AM
- extracted it
Okay let's check some stuff off... Phone in MTP mode? Using USB cable that came with your phone. Try a different USB port? Also is your phone booted into the OS and not fastboot when doing this? All else fails you can use the utility to fastboot back to fresh stock and go from there.
Posted 08 June 2013 - 09:00 AM
> thanks for the reply Memnoch73 <
- yes phone was in MTP mode
- yes i used the usb cable that came w/ the phone.
- yes i did try another usb port
- it was booted normally.
- so if all this is correct, you are saying for me to wipe the phone & start all over? I really don't want to do that.
my head is spinning from ready so many pages on this & another forum site. i have read other people have trouble & found a way to fix it & get rooted, but i haven't seen anyone w/ the same problem as mine.
- i also cleared the cache before doing this for the 19th time.
i really don't know what else to do.
Posted 22 June 2013 - 08:53 AM
Do you have access to a pc that natively runs windows?
Posted 22 June 2013 - 08:58 AM
No i think that's the problem.
i spent so much time the other night downloading the SDK stuff & i still got the same results - nothing.
I think i have to buy a windows laptop just to do this.
This sux.
Posted 22 June 2013 - 09:02 AM
Posted 22 June 2013 - 09:08 AM
Did you try extracting to is own folder on your desktop?
yes i did. im never lucking when it comes to this stuff.
i had an HTC vivid last yr & it refused to get rooted. The htc bootloader unlock from htc didn't even work.
- is there anyone in the NJ area that can root this phone for me?
Posted 07 August 2013 - 05:01 AM
Hi, i need some help, i have the xt926,with stock rom 4.1.2 version 9.18.79 rooted, but i can't unlock the bootloader,i always get the same error:
TrustZone write failed: -11.
Can some one give me a hand.
Posted 07 August 2013 - 05:06 AM
You have updated to the latest update. You can no longer unlock your bootloader
Posted 07 August 2013 - 05:15 AM
thanks for your quick response, and there is no option to downgrade an earlier version??
Posted 07 August 2013 - 05:17 AM
You can downgrade in order to root but not to unlock.
Posted 07 August 2013 - 05:26 AM
bad luck for me, thanks anyway
Posted 07 August 2013 - 06:11 AM
Posted 07 August 2013 - 06:51 PM
Bad luck for a LOT of us.
Posted 07 August 2013 - 07:09 PM
Can't he use SafeStrap Though with root?
