[Utility]Flash CWM or TWRP Recovery-1 Click {UPDATED-7-11-13} V6!
#121
Posted 09 April 2013 - 05:06 AM
#122
Posted 09 April 2013 - 05:10 AM
Hey tucstwo, in V2 (which is the file I checked) there are a few things you'll want to change in the run.bat:
Each "dd" line (something like this):
adb shell "su -c 'dd if=/data/local/tmp/twrprecovery.img of=/dev/block/platform/msm_sdcc.1/by-name/twrprecovery' "
Needs the of=___ portion edited to be:
adb shell "su -c 'dd if=/data/local/tmp/twrprecovery.img of=/dev/block/platform/msm_sdcc.1/by-name/recovery' "
(there's no partition named "twrprecovery", only "recovery")
I think there's 3 total lines in the script which need that fix:
#38: adb shell "su -c 'dd if=/data/local/tmp/twrprecovery.img of=/dev/block/platform/msm_sdcc.1/by-name/twrprecovery' "
#53: adb shell "su -c 'dd if=/data/local/tmp/cwmrecovery.img of=/dev/block/platform/msm_sdcc.1/by-name/cwmrecovery' "
#67: adb shell "su -c 'dd if=/data/local/tmp/motorecovery.img of=/dev/block/platform/msm_sdcc.1/by-name/motorecovery' "
GL.
ah thank you! You're very right. I rushed through this last night and that one flew right over my head.
Like I said to everyone last night, I am going to re-do this tool this AM just so sit tight people!
- jroc and triskropf97 like this
#123
Posted 09 April 2013 - 05:19 AM
will this fix my problem??ah thank you! You're very right. I rushed through this last night and that one flew right over my head.
#124
Posted 09 April 2013 - 05:24 AM
#126
Posted 09 April 2013 - 05:29 AM
- satman80 likes this
#127
Posted 09 April 2013 - 05:33 AM
Choose Which Recovery You Want to Flash or Exit
1. Team Win Recovery
2. Clockworkmod Recovery
3. Stock Motorola Recovery
4. Exit
Chose 1, 2, 3 or 4 then press enter1
Connecting to your phone
Let's Do this
cannot stat 'twrprecovery.img': No such file or directory
/data/local/tmp/twrprecovery.img: cannot open for read: No such file or director
y
rm failed for /data/local/tmp/twrprecovery.img, No such file or directory
Complete
After which I land on dead android/exclamation
EDIT: Tried a second time (decided not to run the bat as Administrator) and it worked, rebooted the device into TWRP.
Thanks!
#128
edit: GREAT SCOTTT!! it worked!!!! Thnks tucstwo!!! and hash!
- satman80 and jtommyj like this
#129
Posted 09 April 2013 - 05:55 AM
Did you try pressing vol up and down on the dead android and the rec and if it works it will bring you to twrpTried v3 and get the following:
4. Exit
Let's Do this
y
Complete
#130
Posted 09 April 2013 - 06:58 AM
#131
Posted 09 April 2013 - 07:35 AM
I've updated the OP to version 3, the only version. It should work for everyone now.
Worked flawlessly. Thanks!
#132
Posted 09 April 2013 - 07:45 AM
Proud father of a US Marine
#133
Posted 09 April 2013 - 07:58 AM
#134
Posted 09 April 2013 - 08:23 AM
We are in new territory here now. The days of bootstrap recoveries are over. It's time now to FINALLY be rid of that silly old Motorola Recovery.
How? I'm going to show you. It's quite easy. All you need to do is download this nifty little tool I made for you and it's easy as click.
Just make sure you've got your drivers installed, USB debugging is enabled and that you have UNZIPPED this package BEFORE you run it.
Important cause some people are having trouble with EITHER method here. Grab Root Explorer or ES File Explorer, browse to /system/etc/install-recovery.sh. Long press on it and rename it to install-recovery.sh.bak so that is't not called out in the future. Then follow along with the instructions below. I was am going to consolidate everything tomorrow. So long as you follow this step, you can just run Version 2.
Be
Download Link Below
Unzip
Plug in Phone
Hit "Run"
Profit
Changelog:Click to
Thank you all for your help
You guys are making this wayyyyy to easy. Thank you!!
#135 Guest_Jolly_*
Posted 09 April 2013 - 08:32 AM
- Narffran and RoomTenONine like this
#136
Posted 09 April 2013 - 08:40 AM
OKay so let me get this straight someone wasted time making a .bat file to flash a recovery and the .bat file itself takes longer to download than the recovery of choice? Why not just get the recoveries and rename them TWRP.img and CWR.img. And teach people to type fastboot flash recovery twrp.img as opposed to spoon feeding them? Want happened to forums being a place to learn that was the purpose and what this forum was supposed to be when it started.
Did you miss a dose today, or something?
Lighten up, my friend. There are instructions out there for folks who wish to walk alone, and those who like a bit of hand-holding. As both are for the finding, why so glum? The person "wasting their time" is doing it for their own enjoyment and value add to the community - and they and others are quite good at it. And, what they do is very appreciated.
- Shenn likes this
#137 Guest_DirtyDroidX_*
Posted 09 April 2013 - 08:43 AM
*100000000000000
#138 Guest_Jolly_*
Because this is the exact opposite of what the forum was supposed to be when it started that's. Automating Fastboot commands has become Development here?
#139 Guest_Jolly_*
Posted 09 April 2013 - 08:44 AM
*100000000000000
Dave this $#!+ isn't what me, Cassy, You and Big had in mind when this place started people where supposed to learn.
#140 Guest_DirtyDroidX_*
Posted 09 April 2013 - 08:53 AM
I can see the use for one clicks but for new guys it is essential to learn the fundamentals of the Android SDK. I say this cause ppl don't no what these tools are doing. If it fails you are stuck with no knowledge to fix your phone. Having a unlocked phone is way different then owning the typical moto phone.
- Narffran and vtwinbmx like this
Also tagged with one or more of these keywords: recovery, one click, razr hd, cwm, clockworkmod
