[Utility]Flash CWM or TWRP Recovery-1 Click {UPDATED-7-11-13} V6!
#101
Posted 08 April 2013 - 06:42 PM
I installed TWRP, booted into recovery, made a backup and rebooted. Never any issues.
#102
Posted 08 April 2013 - 07:07 PM
#103
Posted 08 April 2013 - 07:11 PM
and pushed it using fastboot. when I rebooted into recovery, Twrp came up.
- KaChow and zooyork0721 like this
#104
Posted 08 April 2013 - 07:12 PM
Just did this in fastboot mode:
C:\Users\Axem\Downloads>fastboot flash recovery twrp-2.5.0.0-recovery-vanquish.img
And that worked just fine after downloading the TWRP file and Fastboot files from
- zooyork0721 likes this
#105
Posted 08 April 2013 - 07:14 PM
#106
Posted 08 April 2013 - 07:28 PM
And thanks to tucstwo for the 1-click.
- jroc likes this
#107
Posted 08 April 2013 - 07:38 PM
This may help you guys but I is the TWRP in that thread the 2.5.0.0 that Hash posted up tonight?
Yup it is. It wasnt at his site when I tried the tools you posted. I saw it after I decided do it manually, and just chose the newest one.
#108
Posted 08 April 2013 - 08:08 PM
Connecting to your phone
Let's Do this
rm failed for /system/etc/install-recovery.sh, No such file or directory
cannot stat 'twrprecovery.img': No such file or directory
/data/local/tmp/twrprecovery.img: cannot open for read: No such file or director
y
rm failed for /data/local/tmp/twrprecovery.img, No such file or directory
Complete
And end up with the Android/Exclamation ......any thoughts?
#110
Posted 08 April 2013 - 08:15 PM
#111
Posted 08 April 2013 - 08:43 PM
Is the twrprecovery.img there after extracting the zip?
#112
Posted 08 April 2013 - 08:47 PM
#113
Posted 08 April 2013 - 10:01 PM
Each "dd" line (something like this):
adb shell "su -c 'dd if=/data/local/tmp/twrprecovery.img of=/dev/block/platform/msm_sdcc.1/by-name/twrprecovery' "
Needs the of=___ portion edited to be:
adb shell "su -c 'dd if=/data/local/tmp/twrprecovery.img of=/dev/block/platform/msm_sdcc.1/by-name/recovery' "
(there's no partition named "twrprecovery", only "recovery")
I think there's 3 total lines in the script which need that fix:
#38: adb shell "su -c 'dd if=/data/local/tmp/twrprecovery.img of=/dev/block/platform/msm_sdcc.1/by-name/twrprecovery' "
#53: adb shell "su -c 'dd if=/data/local/tmp/cwmrecovery.img of=/dev/block/platform/msm_sdcc.1/by-name/cwmrecovery' "
#67: adb shell "su -c 'dd if=/data/local/tmp/motorecovery.img of=/dev/block/platform/msm_sdcc.1/by-name/motorecovery' "
GL.
- trikotret, tucstwo, vtwinbmx and 3 others like this
#114
Posted 09 April 2013 - 02:45 AM
Originally had both install-recovery.sh and install-recovery.cfg files in /system/etc/. Changed the install-recovery.sh to install-recovery.sh.bak
xt926 consumer, rooted 4.1.2 OTA (no SS), unlocked bootloader
Wil try to push TWRP as per XDA and others posts above
[update] Successfully pushed TWRP via fastboot commands
#115
Posted 09 April 2013 - 03:42 AM
#116
Posted 09 April 2013 - 04:14 AM
Net- this post adds no value. You've been warned!!!!!
- tucstwo and vtwinbmx like this
Proud father of a US Marine
#117
Posted 09 April 2013 - 04:46 AM
#118
Posted 09 April 2013 - 04:51 AM
so im trying to do it manually and wen i type in fastboot devices lik said its says its not a proper command or something..help?
Looks like he forgot to add fastboot.exe in the second zip, download the 1st link, and copy fastboot.exe into the V2, not sure if he has uploaded the .bat file yet also...
- triskropf97 likes this
#119
Posted 09 April 2013 - 04:59 AM
OK sounded easy enuf but still get the rm failed for /system/etc/install-recovery.sh, no such file or directory.. ???Looks like he forgot to add fastboot.exe in the second zip, download the 1st link, and copy fastboot.exe into the V2, not sure if he has uploaded the .bat file yet also...
#120
Posted 09 April 2013 - 05:00 AM
Also tagged with one or more of these keywords: recovery, one click, razr hd, cwm, clockworkmod
