[Utility]Flash CWM or TWRP Recovery-1 Click {UPDATED-7-11-13} V6!
#61
Posted 08 April 2013 - 04:52 PM
#62
Posted 08 April 2013 - 04:53 PM
yup same hereTried first one and V2...neither on is working. I get this with V2:
Choose Which Recovery You Want to Flash or Exit
1. Team Win Recovery
2. Clockworkmod Recovery
3. Stock Motorola Recovery
4. Exit
Chose 1, 2, 3 or 4 then press enter1
Connecting to your phone
Let's Do this
rm failed for /system/etc/install-recovery.sh, No such file or directory
5059 KB/s (7516160 bytes in 1.450s)
14680+0 records in
14680+0 records out
7516160 bytes transferred in 0.209 secs (35962488 bytes/sec)
Complete
#63
Posted 08 April 2013 - 04:54 PM
Has this been answered yet? I sure would LOVE to know as well!
Why would you guys NOT want to start fresh?? Might as well uninstall safestrap so you are not flashing 1 recovery over the next. Of course it should still work fine but why not if it's just a second to hit the uninstall button. I have flashed recovery multiple times on my DNA but those recoveries all work the same.
As for Roms again just start fresh since this one works differently than Safestrap. There's a chance it may still work fine but why open yourself up to weird issues.
- vtwinbmx likes this
#64
I renamed 'install-recovery.sh' to append a '.bak' to the end of it. Then tried the original link again and I now have TWRP!Just tried to install this recovery and it seemed to go through alright. Then I powered off the phone and held Power + Vol Down to enter the bootloader menu. Then tried to enter Recovery and it resulted in an Android icon with a red exclamation mark.
Thanks OP!
- tucstwo likes this
#65
Posted 08 April 2013 - 04:56 PM
Sorry, was a problem with the zip, I fixed itI just downloaded the Recovery Flasher V2.zip and it seems corrupt but MD5's match any ideas?
the problem im having is it isn't extracting.
MD5 changed cause of extraction problemI just downloaded it again and now the new one has a new MD5 it may have still been uploading when i tried the first time.
Old MD5: AFD4D1CC0106CF654780B94211DF8B34
New MD5: F02EE95135812F93984E90AB8794769E
v2 is a no go for me
eventually we will figure out why SOME people are having problems, its so weirdTried both versions of this batch and I get the dead android whether I try TWRP or CWM install.
FYI, I unlocked this morning on a rooted 4.1.2 OTA.
4. Exit
Let's Do this
14680+0 records in
14680+0 records out
Complete
yup same here
This is EXACTLY what you should be seeing. All that "No Such File or Directory" error means is that you don't have the file on your phone that rewrites recoveries. I wish I could offer more help. I'm at a loss at the moment. If you guys having problems want to PM me, I will attempt to walk you through flashing manually.
At this point, Im just gonna add this step to the OP just to be safe. It's weird that the Version 2 script removed that file, but people are still having problems.I renamed 'install-recovery.sh' to append a '.bak' to the end of it. Then tried the original link again and I now have TWRP!
Thanks OP!
- jroc likes this
#66
- satman80 and BootAnimator like this
#67
Posted 08 April 2013 - 05:01 PM
where do i find this?? and how shud it look after im done?? sorry im a noober!I renamed 'install-recovery.sh' to append a '.bak' to the end of it. Then tried the original link again and I now have TWRP!
Thanks OP!
edit: after im done renaming that is
#68
Posted 08 April 2013 - 05:02 PM
i tried that.. no go..The dead android you all are referring to is the screen before recovery. If i'm not mistaken, if you press both the volume up and down at the same time it will go the recovery. It is also surprising that none of you can use google.
#69
It's the stock recovery... it wouldn't go to that if it was TWRP or Clockwork
- triskropf97 likes this
#70
Posted 08 April 2013 - 05:06 PM
I added instructions in the OP for it.where do i find this?? and how shud it look after im done?? sorry im a noober!
If it's not there, we have a different set of problems then
#71
Posted 08 April 2013 - 05:10 PM
Np, thanks for the help. I will try it manually with the directions from XDA and see what happens. I just got finished setting up the adb environment for my PC, so pushing to my phone should be a breeze. That shouldnt have been a problem, right? I set up adb after I tried to use these tools. I had a feeling I was gonna have to do some manual pushing.
I updated my other post. I have a install-recovery.cfg file, no install-recovery-sh file.
#72
Posted 08 April 2013 - 05:18 PM
#73
Posted 08 April 2013 - 05:30 PM
Still having the same issues. And there is no install-recovery.sh file in system/etc, just install-recovery.cfg
this is my dilemma also
#74
Posted 08 April 2013 - 05:33 PM
- jroc and vtwinbmx like this
#75
Posted 08 April 2013 - 05:34 PM
#76
well if you like you can manually install the recovery too or give some time he is trying to fix everything moto isnt used to being unlocked so this world is a new start and has its speed bumps and its only the first 12 hours of unlocked for public
Of course. Just giving the guy some feedback in attempt to help. No rush tucstwo!
#78
Posted 08 April 2013 - 05:37 PM
Boot, system and data is already checked.
#79
Posted 08 April 2013 - 05:38 PM
10 hours
It takes 15 posts to PMJust tried to PM him...not enough posts... I will just hang out and try to help until I have enough posts.
Also tagged with one or more of these keywords: recovery, one click, razr hd, cwm, clockworkmod
