[Utility]Flash CWM or TWRP Recovery-1 Click {UPDATED-7-11-13} V6!
recovery one click razr hd cwm clockworkmod
315 replies to this topic
#301 bweN_diorD
bweN_diorD
  • 69 posts
Posted 16 May 2014 - 03:38 PM
Possibly.  I don't know anything about this particular utility as I didn't write it nor have I ever used it.  Basically it just needs to reboot into AP Fastboot mode and fastboot flash the CWM recovery.  Not sure what's causing the adb issue but the causes can be numerous.
ok, thanks
i just have one quick question about the code because its been a long time since i looked at this and it just doesnt look right compared to anything i have seen.
parts of the code read like this nuladb with no space between the nul and adb command. that has to be a problem, or am i wrong?
#302 SamuriHL
  • 44,414 posts
Posted 16 May 2014 - 03:40 PM
No idea.  I haven't even looked at this util.  I know nothing at all about it.
#303 bweN_diorD
bweN_diorD
  • 69 posts
Posted 16 May 2014 - 03:42 PM
ok, thanks
#304 ibolski
ibolski
  • 535 posts
  • Twitter:iBolski
  • Google+:Ivan Samuelson
  • LocationColumbus, Ohio
Posted 11 June 2014 - 06:35 AM
btw, dhacker has released a KitKat ready TWRP for the RAZR HD. You can get it from XDA here ->
#305 chakuza
chakuza
  • 10 posts
Posted 15 June 2014 - 08:13 PM
I couldn't get my laptop to set adb fastboot and problems with my usb ports so I used( [Root) rashr) to install it. worked grate I got that from the app store oh and thank dhacker and everybody involved in anyway with development of all the code we couldn't live without
#306 smokestace
smokestace
  • 57 posts
  • LocationSparks Nevada
  • Current Device(s):droid razr
Posted 15 June 2014 - 11:58 PM
I need to RE root mine I am unlocked. How do I re root after flashing kk?
Sent from my XT1080 using Tapatalk
#307 SamuriHL
  • 44,414 posts
Posted 16 June 2014 - 02:28 AM
Install twrp and flash supersu zip in recovery.
#308 ar7point62
ar7point62
Posted 17 June 2014 - 01:36 PM
I am using V6, and no matter which option I choose, It just sits at connecting to phone. I can see it with ADB devices, and I can push items to it, for example. I am rooted, and bootloader unlocked on my XT926.
#309 smokestace
smokestace
  • 57 posts
Posted 18 June 2014 - 01:57 AM
The problem is that it won't let me install twrp unless I'm rooted. This has me puzzled. I'm really not such a noob at this either.
Sent from my DROID MAXX using Tapatalk
#310 SamuriHL
  • 44,414 posts
Posted 18 June 2014 - 02:51 AM
Sure it will. Just not with any of the methods that require root. ;) two ways to do it. Manually with fastboot, or automated using a script, but again with fastboot. I wrote an unlocked root script that will flash recovery and then sideload root. It's in my house of moto forum. Or you can manually flash recovery like this:
fastboot flash recovery recoveryfilename.img
Obviously recoveryfilename should be changed to the filename for your custom recovery. The phone must be in ap fastboot mode and connected to a USB 2 port.
#311 SamuriHL
  • 44,414 posts
Posted 18 June 2014 - 02:54 AM
Oh one more thing. Once you flash it with fastboot, immediately disconnect from USB, power off, and boot to recovery. If you let the phone boot normally without booting to recovery first, the phone will restore stock recovery overwriting what you just flashed. This part is important and leads to a lot "it didn't work" posts.
#312 silver02
silver02
Posted 28 June 2014 - 05:37 AM
First off, let me say thanks to everyone involved getting root and unlock for this device.  You all are amazing!
Now, for the problem.  I successfully rooted and unlocked using the towelroot & motopocalypse apks.  I flashed TWRP 2.7.1 using Flashify.  I thought that I was performing a factory reset in TWRP, but it seems that what I did was erase the OS.  I'm getting a message saying "No OS installed!  Are you sure you want to (power off/reboot)?"  What have I done???
#313 cmh714
Posted 28 June 2014 - 05:43 AM
Sounds like you wiped more than you wanted to do...you will need to re-flash and start over....
Flash Stock, then root, then flash TWRP. The before you do anything make a Backup of the Stock rooted rom, then after that you can flash a Custom ROM.
For that, you can use the default Wipe settings, then use Install to flash the ROM, then GApps, and SU if its not in the ROM already
  • silver02 likes this
#314 silver02
silver02
Posted 28 June 2014 - 05:59 AM
Thanks for the quick response.  I'm not completely new to flashing, but it has been a few years and it was on a different device.  Where can I find the stock firmware?
#315 cmh714
Posted 28 June 2014 - 06:11 AM
926 files here:
get Sams House of Moto here to flash it:
Make sure you read the instructions a few times
#316 silver02
silver02
Posted 28 June 2014 - 07:27 AM
I think I'm good to go now, the phone has rebooted and I'm going through the setup process.  Thank you, thank you, thank you!
  • cmh714 and RikRong like this
Also tagged with one or more of these keywords: recovery, one click, razr hd, cwm, clockworkmod
8 user(s) are reading this topic
0 members, 8 guests, 0 anonymous users
