[Utility]Flash CWM or TWRP Recovery-1 Click {UPDATED-7-11-13} V6!
recovery one click razr hd cwm clockworkmod
315 replies to this topic
#281 BionicMan69
BionicMan69
    Android Scientist
  • 142 posts
  • Twitter:@BionicMan_69
  • LocationCookeville, TN
  • Current Device(s):Motorola Droid Razr Maxx HD, Motorola Droid Bionic, Motorola Xoom, HTC Flyer
Posted 15 November 2013 - 05:33 AM
Just a question, when you tried flashing the 4.1.2 ROMs did you mount system first? Also wiped data, cache, dalvik cache and internal storage? I also make sure system is mounted during all them wipes too. I do that for every rom i flash or backups. Never have had a problem taking them steps.Sometimes formatting data helps. But if wipe internal and format data if you have anything you want to keep better transfer it all to external first. Just trying give suggestions which you may have already tried.
#282 newskate9
newskate9
    Older Than You
  • 514 posts
  • LocationCentral PA
Posted 15 November 2013 - 07:11 AM
Downloading now........does this flash the latest version of TWRP for the HD?
EDIT:  I see it has 2.6.  Followed instructions, worked flawlessly!  Thanks!
Proud father of a US Marine
#283 bweN_diorD
bweN_diorD
  • 69 posts
Posted 15 November 2013 - 11:59 AM
the latest version is here
@tucstwo was going to update the op but it seems he forgot.
  • newskate9 likes this
#284 cmh714
Posted 15 November 2013 - 12:36 PM
@blameTucs is the forum motto ;)
  • RikRong likes this
#285 bweN_diorD
bweN_diorD
  • 69 posts
Posted 16 November 2013 - 05:18 AM
at least in this case there is justification  ;)
#286 newskate9
newskate9
    Older Than You
  • 514 posts
Posted 18 November 2013 - 09:41 AM
Thank you!
  • bweN_diorD likes this
#287 newskate9
newskate9
    Older Than You
  • 514 posts
Posted 18 November 2013 - 05:32 PM
So, I installed the latest, and can't make a back up. Tried wiping caches, rebooting several times. No deal.
Any thoughts?
#288 RikRong
RikRong
    Cap'n Slow
  • 2,117 posts
  • LocationNoDak
  • Current Device(s):Pixel 7
Posted 18 November 2013 - 05:53 PM
Any thoughts?
Change/shorten the name that's auto-generated.  The name that's generated is too long and it won't allow a backup to be created.
#289 newskate9
newskate9
    Older Than You
  • 514 posts
Posted 18 November 2013 - 06:37 PM
Ha, that was too easy! Thank you!
#290 Tquetski
Tquetski
  • 156 posts
Posted 23 November 2013 - 04:38 AM
Tried this, Still getting unable to mount E:/Data on some rom flashes lol......
#291 strydersound
strydersound
  • 9 posts
  • Current Device(s):Razr Max / Razr Maxx HD
Posted 28 November 2013 - 03:12 AM
I have redone everything three times, still no WiFi and my Bluetooth won't hold a pair with more than one device at a time. Kernel issue maybe? Sent from my XT926 using Tapatalk
#292 bweN_diorD
bweN_diorD
  • 69 posts
Posted 28 November 2013 - 04:06 AM
not sure what your issue has to do with the "recovery flasher" thread you posted under...
#293 cristaldi89
cristaldi89
  • 9 posts
Posted 08 December 2013 - 01:12 PM
Hi, I was recently using TWRP touch recovery, and I had started running into errors trying to install some Roms. I think that roms developed on newer android versions wont flash using some older versions of TWRP, which would require an update to TWRP. I did some searching and noticed the errors are only with TWRP so I wanted to use CWM recovery. I originally installed TWRP via this thread, and had to do it the longer route, ie not through the 1 click method. I tried the 1 clock method and it would hang during connection. I realized that my phone would not connect due to outdated versions of adb in the download link.
Solution- follow the download link for the complete SDK package - DOWNLOAD
unzip, and go to SDK/PLATFORM-TOOLS, in this folder you should see the adb file along with (2) adb xxx .dll files. Replace the 1 click adb files with the ones from the freshly downloaded SDK files. Or, the nice developer who made this beautiful utility could update it with new adb files, I simply dont know how to compile or I'd help.
Also, for those of us who liked the touch feature of TWRP, CWM does have a touch version floating around, and it is easy to use this one touch utility to flash that CWM touch version. Thanks to all those developers making sweet roms and utilities.
  • cmh714 likes this
#294 bweN_diorD
bweN_diorD
  • 69 posts
Posted 08 December 2013 - 03:38 PM
so you are saying all you had to do was swap the old adb file with a new one from a sdk setup?
thats an easy fix.
if you upload the adb file you used and post a link for me, i will update the tool.
afterwards, perhaps you could test it. i would appreciate it.
thanks
#295 cristaldi89
cristaldi89
  • 9 posts
Posted 14 December 2013 - 09:19 AM
Actually the adb file I used came from the link in your original post. You provided a link to the whole android SKD download. When clicking that link, it takes you to the most recent skd package available.
#296 bweN_diorD
bweN_diorD
  • 69 posts
Posted 14 December 2013 - 01:53 PM
actually im not the developer (op), im just maintaining it.
ill see what i can do about getting the files switched out asap.
#297 JiMoto
JiMoto
Posted 15 December 2013 - 08:31 AM
Just trying to get to newest twrp? Why not just download and flash using flashify
#298 cristaldi89
cristaldi89
  • 9 posts
Posted 21 December 2013 - 05:27 PM
Never heard of flashify.  I was actually switching from TWRP to CWM anyway. Thanks though I will check that out.
#299 bweN_diorD
bweN_diorD
  • 69 posts
Posted 16 May 2014 - 02:44 PM
@samurihl
im not a scripologist, i just do simple maintenance to tools like this.
when i update it to the kk recoveries it just sits there "connecting to device" and wont connect and start.
i checked in adb and i can see my phone, is there a simple fix for this like i need to update the adb file or something?
thanks
#300 SamuriHL
  • 44,416 posts
Posted 16 May 2014 - 03:26 PM
Possibly.  I don't know anything about this particular utility as I didn't write it nor have I ever used it.  Basically it just needs to reboot into AP Fastboot mode and fastboot flash the CWM recovery.  Not sure what's causing the adb issue but the causes can be numerous.
Also tagged with one or more of these keywords: recovery, one click, razr hd, cwm, clockworkmod
