Updated OP to include Matts most up to date version of CWM, 6.0.3.2
[Utility]Flash CWM or TWRP Recovery-1 Click {UPDATED-7-11-13} V6!
#221
Posted 29 May 2013 - 06:22 PM
#222
Posted 30 May 2013 - 10:21 AM
Said No such file or directory for CWM. Flashing TWRP instead then. Meerrrr, these reboots are unnerving coming from a nexus.
Annnndddd we're back... with the stock recovery. Try #2!
Manual method with CMD. Doesn't recognize "mount" for me either. With the entire SDK set up.
#223
Posted 07 June 2013 - 01:27 PM
Thanks for all your hard work on this solution. I was running SSv3 on my XT926 consumer edition before I knew of a way to unlock the bootloader. After uninstalling SS and flashing back to the stock Moto recovery, I was able to flash TWRP v2.5.0.0 with no problems.
#224
Posted 28 June 2013 - 01:47 PM
when i use the one click meathod, i chose any of the recovery options and it says adb not recognised. i have read it might have something to do with sdk but i rooted just fine just a few days ago. any help would rock. im running razr maxx hd, 4.1.2 jb rooted original os
#225
Posted 28 June 2013 - 02:16 PM
Have you unzipped the zip file using WinRar?? Some use 7-zip and it does not extract correctly. USB debugging on? Using the moto USB cable??
#226
Posted 29 June 2013 - 04:33 PM
I've rooted my phone and unlocked bootloader. Tried using the one click to install recovery and that gave me a failed flash on fastboot. Did the manual method using adb and twrp is installed. I have flashed rage hd, awesome btw, and everything seems to be working fine.....other than everytime it powers up it goes to fastboot mode. Ive tried everything, a successful flash, tried to adb motorecovery which only gave me the droid with his chest open. Still on rage....everything works fine other than the fastboot on power up. The reason is flash failure. Any help would be gratefully accepted. I am on a razr maxx hd running rage hd. Ive made sure usb debugging is on...drivers are all up to date, phone hooks up to computer just fine and can read files transfer whatever i want. Run everything as admin.....at a complete loss here.
#227
Posted 11 July 2013 - 12:00 PM
that was fast! soak released yesterday v 6 today!
#228
Posted 11 July 2013 - 12:07 PM
#229
Posted 11 July 2013 - 12:18 PM
- shane1 likes this
#230
Posted 11 July 2013 - 02:17 PM
Sent from my CM 10.1 XT926
#231
Posted 13 July 2013 - 10:28 AM
worked perefect for me, nice to be able to wipe internal from wipe menu now
#232
Posted 14 July 2013 - 07:13 PM
Anyone tried this with the 9.18.79 update that is rolling out? Currently unlocked, rooted with stock recovery and debating about putting TWRP on my xt926.
#233
Posted 14 July 2013 - 07:38 PM
#234
Posted 15 July 2013 - 08:49 PM
Sent from my XT926 using Tapatalk HD
#235
Posted 16 July 2013 - 11:37 PM
- Tucknology likes this
One Plus 7 Pro -- 8 GB Ram - 256 GB Rom
#236
Posted 17 July 2013 - 06:54 PM
Finally got it worked out. Matt's utility was the only thing that worked. Seem s bin file was gone maybe?
#237
Posted 20 July 2013 - 06:02 PM
How did you get it to work? I have the same exact situation.
Took update lost root still unlocked this will not work for me I get system/bin/sh:su:can't execute:permission denied. Tried the process in your how to section. tried that that got to adb shell su got same thing. tried both ways phone and fastboot. left a reply in other post. my su binaries seem to be gone help in fastboot it says device is unlocked status code 3 seems I am still unlocked but cannot load recovery or restore root
#238
Posted 20 July 2013 - 06:54 PM
Fixed it. See here for instructions:
#239
Posted 26 July 2013 - 10:13 PM
Thanks ji... Now my RazrMAXX_HD is rocking with CWM Recovery...
- tucstwo likes this
#240
Posted 05 August 2013 - 05:59 PM
Hello. i have a xt926 and am trying to update CWM but once i select the option 2 it just sits there.i tried running through adb and it says offline. Appreciate any input. thanks
Edit: got it working
Also tagged with one or more of these keywords: recovery, one click, razr hd, cwm, clockworkmod
