[Utility]Flash CWM or TWRP Recovery-1 Click {UPDATED-7-11-13} V6!
recovery one click razr hd cwm clockworkmod
315 replies to this topic
#201 woodjc01
woodjc01
  • 38 posts
  • LocationJackson, TN
Posted 13 April 2013 - 02:41 PM
One-click recovery install worked like a charm! Thanks tucstwo for making it so easy for me!
#202 DVDDave
DVDDave
  • 66 posts
Posted 14 April 2013 - 08:06 PM
Thank You !!!!!
#203 tucstwo
  • Google+:tucstwo@gmail.com
Posted 16 April 2013 - 12:30 PM
updated to version 4, see change log. Will help those having problems with recovery sticking on reboot.
  • eogans09 likes this
#204 Moth1996
Moth1996
  • 8 posts
  • Current Device(s):RAZR HD MAXX
Posted 18 April 2013 - 04:19 PM
Will this one-click work on OSX? Any kind of terminal equivalent?
The unlock exploit I think will, but I do not know about this.
#205 MonkeyMouth
MonkeyMouth
    Boot Logo Master
  • 148 posts
  • Google+:Adriano.Badilla@gmail.com
  • LocationLaveen, Arizona
  • Current Device(s):DROID ULTRA
Posted 03 May 2013 - 05:35 PM
V4 without a hitch. Good work!
Yet again. It isn't nessacary. But if you like my work or just want to be generous. Buy me a Monster. So I can stay up:P
#206 GillRigged
GillRigged
  • 121 posts
  • Twitter:@GillRigged
  • LocationNW WI
  • Current Device(s):Droid RAZR Maxx HD, Droid RAZR M
Posted 03 May 2013 - 05:50 PM
tucstwo, Would you happen to have 2.4.4.0? Or maybe you could help me with this issue I'm having. In Mount I do not have several options. All I have is:
[] Unmount Data
[] Unmount Cache
[] Unmount SDCard
() Use external SD () Use internal SD
_________________
|Mount USB Storage |
|________________/
Any idea why this is???
Tucstwo,
  I thought maybe you might wanna know that I figured this issue out.
#207 droidcutie
droidcutie
  • Twitter:daniae
  • Current Device(s):Razr HD
Posted 15 May 2013 - 04:57 PM
Been trying to flash cwm all day. downloaded this and it took only a couple seconds to flash. Yay. Thanks Muchos
  • tucstwo likes this
#208 tucstwo
Posted 15 May 2013 - 05:43 PM
Tucstwo,
I figured it out on version 4. not sure about the theme flashing BUT...the original issue was that the script was only stoping /system/etc/install-recovery.sh and was ignoring recovery-from-boot.p (which I fixed in v4). Not sure what the themes are doing to these 2 issues, but that was the undermining cause.
  • shane1 likes this
#209 NattyBee
NattyBee
  • 647 posts
Posted 15 May 2013 - 06:42 PM
hey man...how long should this take? it's been running for...10 min or so..and the screen keeps turning on and off my Maxx HD, but that's all that's happening...
#210 NattyBee
NattyBee
  • 647 posts
Posted 15 May 2013 - 06:43 PM
nevermind.  I'm an idiot.
#211 tucstwo
Posted 15 May 2013 - 06:51 PM
Shouldn't take more than 45 seconds or so once it's starts. This is unique for sure :(
oh derp, sorry. Didnt see this. silly man, lol
#212 Guest_BDH_*
Guest_BDH_*
Posted 16 May 2013 - 08:29 PM
Ok so I decided I was gonna mess around and see if using this was possible in Ubuntu and it definitely is :)
Go into Developer Options and make sure USB Debugging is turned on.
Just download Tucstwo's zip in the OP and extract somewhere in Ubuntu and rename the folder an easy 1 word name like "tool." . (example, extracted to my Home folder in ubuntu or also known as "~" so my directory for the zip would be ~/tool)
Open Terminal in Ubuntu and navigate to wherever you extracted the zip file.
Now you're going to make sure your machine can read that your phone is connected by using this line
You should have your device ID listed, if you don't then I don't know what to say lol.
So now you're going to use this line
You should be looking at something like this now:
So now you need to use this line
Then
Then back out of shell by typing "exit" and hitting "enter." You need to do this twice.
Now you should be back to your main folder that you started out in, in this case
Now enter this line
Result should be similar to this:
Now go back into thr device with this
And enter this line
Lastly, enter this line
That's it. BINGO! TWRP installed manually via Terminal and Ubuntu :)
Now just because you're still in Terminal, just type "exit" and hit enter, then do it again. Now back again to your main directory, just type the following:
Now you're done. Your phone will reboot into TWRP and you'll be set to flash ROMs :)
NOTE:
This method was only tested on my RAZR HD. By you following these steps, you're assuming ALL responsibility for what happens after that!
  • zooyork0721 and shane1 like this
#213 tucstwo
Posted 17 May 2013 - 04:32 PM
Click to
NOTE:
Very nice stuff, gary. I found that this method works just fine with Linux. Should you want to use the "fastboot flash" method. You need to always remember to run fastboot commands as "sudo" or they won't go through. Just a tip ;)
#214 Brenardo
Brenardo
  • 81 posts
Posted 27 May 2013 - 02:20 PM
Is it possible to flash with terminal emulater? I have been thinking hard about trying it but I am a puss.
#215 zooyork0721
zooyork0721
    All Around Man
  • 979 posts
  • LocationNew York, NY
Posted 27 May 2013 - 02:25 PM
Fl;ashable, i believe these will flash fine through SS, i just made them flashable so idk
TWRP-
CWM-
They are the newest so :)
Flash and have fun!
#216 Brenardo
Brenardo
  • 81 posts
Posted 27 May 2013 - 03:44 PM
I am not talking about SS I mean the terminal emulator app. With commands and all.
Something like: "dd if=/FILE LOCATION/recovery.img of=/dev/block/mmcblk0p13"
#217 tucstwo
Posted 27 May 2013 - 03:55 PM
Yes, you have to use the dd if of method, fastboot method won't work in terminal emulator as you have to have the device booted up, obviously.
#218 zooyork0721
zooyork0721
    All Around Man
  • 979 posts
Posted 27 May 2013 - 03:59 PM
i knew thats what you meant lol but i wanted to give you a easier way if you would choose to
#219 Brenardo
Brenardo
  • 81 posts
Posted 27 May 2013 - 04:32 PM
I do not currently have a PC. Or even home internet for that matter. SO.... it is phone and Tablet for me.
#220 CellZealot
CellZealot
  • 24 posts
Posted 29 May 2013 - 06:46 AM
Using dd from terminal emulator works perfectly well to write the recovery without a PC.
If you place the recovery image on the root of your external sdcard and rename it twrp.img for simplicity, then use the following commands in terminal.
su
dd if=/storage/sdcard1/twrp.img if=/dev/block/platform/msm_sdcc.1/by-name/recovery bs=4096
exit
All done!
Edit: The forum is making that 2 lines but its just a single line with a space between /twrp.img and if=/
  • tucstwo and Brenardo like this
Also tagged with one or more of these keywords: recovery, one click, razr hd, cwm, clockworkmod
